rdk-technical-support
1110 réponses à ce sujet
#721 _awlad
_awlad
  • 11 messages
Posté 03 janvier 2026 - 02:03
try to first run pydev mipi camera code to check that the camera detected success fully
#722 pysome
pysome
  • 13 messages
Posté 03 janvier 2026 - 03:08
u need to wait for atleast 3-5 min on 1st bootup
#723 pysome
pysome
  • 13 messages
Posté 03 janvier 2026 - 03:36
i fAced same issues @d-robot @Ansh @Awlad after running mipi.py with successfull camera connection
#724 _awlad
_awlad
  • 11 messages
Posté 03 janvier 2026 - 03:59
is mipi.py not showing anything?
#725 pysome
pysome
  • 13 messages
Posté 03 janvier 2026 - 06:15
returns Nonetype object
#726 _awlad
_awlad
  • 11 messages
Posté 03 janvier 2026 - 06:16
check the proper connection with i2cdetect
#727 daddy_salad
daddy_salad
  • 22 messages
Posté 03 janvier 2026 - 10:48
Yeah i did
#728 koushikdeb7860
koushikdeb7860
  • 2 messages
Posté 04 janvier 2026 - 05:17
WIFI driver is creating issue frequently. Even after booting properly it creates issue.
Please give some solution.
My PuTTY screenshot shows the problem clearly:
sdio_err:<aicwf_sdio_sleep_allow,1365>: reg:2 write failed!
txrx_err:<aicwf_sdio_wakeup,1312>: sdio wakeup fail
The WiFi driver (aicwf_sdio) is crashing during boot, which prevents the network interface from coming up properly. When the network interface doesn't start:
SSH daemon can't bind to port 22
VS Code tries to connect but gets timeout (connection refused)
Even though the RDK is running, SSH is not listening Fichier joint  WIFI_Module_Issue_On_Boot.PNG   62,58 Ko   0 téléchargement(s)
#729 koushikdeb7860
koushikdeb7860
  • 2 messages
Posté 04 janvier 2026 - 05:21
Fichier joint  image.png   6,76 Ko   0 téléchargement(s)
#730 pysome
pysome
  • 13 messages
Posté 04 janvier 2026 - 12:10
using : ./test_yolov5.py , asks write permission. Fichier joint  image.png   97,5 Ko   0 téléchargement(s)
#731 _awlad
_awlad
  • 11 messages
Posté 04 janvier 2026 - 12:33
use sudo python3
#732 nebula_moose_12014
nebula_moose_12014
  • 12 messages
Posté 04 janvier 2026 - 12:34
Hi anybody know how to fix this issue?? Fichier joint  IMG-20260103-WA0005.jpg   114,34 Ko   0 téléchargement(s) Fichier joint  IMG-20260103-WA0004.jpg   78,42 Ko   0 téléchargement(s) Fichier joint  WhatsApp_Image_2026-01-02_at_10.39.25_AM.jpg   96,62 Ko   0 téléchargement(s)
#733 pysome
pysome
  • 13 messages
Posté 04 janvier 2026 - 12:51
@Awlad
0 vse0 0 10 0 3 0 0 0
========================= END ===========================
Opened DRM device: /dev/dri/card0
No suitable display method found.
Running without preview window
2000/01/01 09:02:21.641 !INFO [BindTo][0088]BindTo_CHN:-1
2000/01/01 09:02:21.641 !INFO [BindTo][0093]m_prev_module_chn:1
Traceback (most recent call last):
File "/app/pydev_demo/03_mipi_camera_sample/mipi_camera.py", line 406, in <module>
img = np.frombuffer(img, dtype=np.uint8)
TypeError: a bytes-like object is required, not 'NoneType'
sunrise@ubuntu:/app/pydev_demo/03_mipi_camera_sample$ i2cdetect -y -r 4
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
#734 _awlad
_awlad
  • 11 messages
Posté 04 janvier 2026 - 12:54
your camera is not connected either connection issue or hardware issue
#735 pysome
pysome
  • 13 messages
Posté 04 janvier 2026 - 01:12
@d-robot **[mipi_cam-1] [WARN] [0946685728.195250986] [mipi_cam]: [init]->cap imx219-30fps init success.**
i'm connecting rdkx5 with putty to my laptop
Last login: Sat Jan 1 08:02:06 CST 2000 on ttyS0
sunrise@ubuntu:~$ ros2 launch mipi_cam mipi_cam.launch.py mipi_video_device:=IMX219 mipi_camera_calibration_file_path:=/opt/tros/humble/lib/mipi_cam/config/IMX219_calibration.yaml
-bash: ros2: command not found
sunrise@ubuntu:~$ source /opt/tros/humble/setup.bash
[INFO] [launch]: All log files can be found below /home/sunrise/.ros/log/2000-01-01-08-15-22-918702-ubuntu-3950
[INFO] [launch]: Default logging verbosity is set to INFO
config_file_path is /opt/tros/humble/lib/mipi_cam/config/
Hobot shm pkg enables zero-copy with fastrtps profiles file: /opt/tros/humble/lib/hobot_shm/config/shm_fastdds.xml
Hobot shm pkg sets RMW_FASTRTPS_USE_QOS_FROM_XML: 1
env of RMW_FASTRTPS_USE_QOS_FROM_XML is 1 , ignore env setting
[INFO] [mipi_cam-1]: process started with pid [3975]
[mipi_cam-1]
[mipi_cam-1] [WARN] [0946685728.195762778] [mipi_cam]: Enabling zero-copy
[mipi_cam-1] [WARN] [0946685728.196984446] [mipi_node]: get camera calibration parameters failed
#736 pysome
pysome
  • 13 messages
Posté 04 janvier 2026 - 01:16
the camera connector cable not rightly connected, flip & connect
#737 _awlad
_awlad
  • 11 messages
Posté 04 janvier 2026 - 02:16
from srpi-config go to interface options and then on v4l2
#738 anirudh071132
anirudh071132
  • 3 messages
Posté 04 janvier 2026 - 07:41
Hi everyone I'm benginer robotics engineering student help me
#739 nebula_moose_12014
nebula_moose_12014
  • 12 messages
Posté 05 janvier 2026 - 07:15
@Awlad Fichier joint  WhatsApp_Image_2026-01-05_at_11.44.52_AM.jpeg   91,8 Ko   0 téléchargement(s)
#740 daddy_salad
daddy_salad
  • 22 messages
Posté 06 janvier 2026 - 02:19
Has anyone in this server actually managed to do their own project using the rdk? Im not talking about running the demos they provided, but an actual work that they want to do. For example drone detection. If anybody has please text me because i have hit a brick fuckin wall
