rdk-project-showcase
#81
Posté 22 juillet 2026 - 13:02
#82
Posté 22 juillet 2026 - 13:05
#83
#85
Posté 25 juillet 2026 - 16:31
My latest project is finally live! In this video, I show how to combine the RD-03D mmWave Radar, an ESP32-C3, and the D-Robotics RDK X5 to build several practical and interactive applications.
In this video, I demonstrate:
This project shows how easy it is to use an ESP32-C3 to handle the radar communication, allowing the RDK X5 to focus on running higher-level applications.
If you're interested in RDK X5, Edge AI, Python, computer vision, or mmWave radar, I'd love to hear your thoughts and feedback.
Thank you to the D-Robotics team and this community for building such a great platform for developers. I hope you enjoy the project!
#86
#87
Posté 09 août 2026 - 07:51
Just finished a build that pairs mmWave radar with ChatGPT (GPT-4o), running entirely on the RDK X5. No wake word, no button - the moment the radar detects someone in the room, the RDK X5 triggers the assistant and it starts talking.
Once active, it uses the RDK X5's USB camera input to capture and send frames to GPT-4o for real scene understanding - not limited to a fixed object list like COCO. It correctly picked up on someone hiding behind a cupboard just out of direct view, which honestly surprised me too.
The RDK X5 is also handling GPIO output in this build - voice commands control an LED directly through the board, so it's not just a chatbot, it's actually driving hardware in real time.
Stack:
#88
Posté 09 août 2026 - 07:52
#89
Posté 07 septembre 2026 - 14:26
In my latest project, I'm using the LD19 LiDAR and RDK X5 to build a real-time sensing system that can see in complete darkness, track moving people and objects, calculate speed, predict movement, detect potential collisions, find safe paths, and even generate steering commands for future autonomous systems.
I also built an interactive 3D visualization to see everything happening in real time.
But getting it all working wasn't exactly straightforward.
The LD19 would start spinning normally, run for about two seconds... and then suddenly stop when connected to the RDK X5.
After some troubleshooting, I found the actual problem and figured out a simple solution.
And by the end of the project, the entire system was running directly on the RDK X5 - no laptop required.
This project was a great example of how much you can do with an affordable LiDAR when you combine raw sensor data with the right software.
#90
#91
Posté 21 septembre 2026 - 13:28
The project combines AI-assisted underwriting, risk analysis, evidence, investigation, and privacy-aware document processing into one workflow. The RDK X5 performs local OCR, sensitive-field detection, redaction, and tokenization.
Check the project: https://devpost.com/...jkkajYwJGwwJGgw
GitHub: https://github.com/YoshiBoiy/lloyd
11oyd_.png 113,38 Ko
0 téléchargement(s)
#92
Posté 21 septembre 2026 - 13:26
Powered by the D-Robotics RDK dev kit, builders at Hack The North
created projects in just 36 hours!
Meet Goostriever, a voice-controlled retrieval robot built by @zrax1n
team.
"Bring me my bottle."
So they built a robot that can actually do it.
Give it a command. It identifies the right object, plans a route around the room, drives over, picks it up, and brings it back.
Under the hood: vision, navigation, an LLM planner, and an RDK S100 running ACT inference locally for the grasping action.
Check the project: https://devpost.com/...jQkajI1JGwwJGgw
For more details: https://github.com/d...-the-north-2026
#93
Posté 23 septembre 2026 - 08:58
#94
Posté 07 octobre 2026 - 08:32
https://robomotic.com/
#95
Posté 12 octobre 2026 - 08:35
I brought over the ESP32 pixel avatar UI and added chat captions, hold-to-talk input and TTS for replies. It uses LVGL/SDL and a Python backend connected to the Muse Linux SDK. Muse runs in the cloud; the X5 handles the screen, audio and device commands.
Text chat, touch controls, reconnection and boot startup are working on the board. The code and installation instructions are on GitHub:
https://github.com/s...-x5-muse-gadget
Image_Oct_12_2026_03_29_13_AM.jpg 645,95 Ko
0 téléchargement(s)
#96
Posté 12 octobre 2026 - 08:36
