Vigibot Pi arduino Serial Communication Example
6 réponses à ce sujet
#1 Mike118
  • 12 871 messages
Posté 03 décembre 2019 - 03:30
This is a simple code example for serial communication between pi and arduino or other board with vigibot protocole with default remote configuration :
 * Vigibot Pi to Arduino Uart default remote configuration example by Mike118
// Meta Type :
typedef struct {
 union {
  struct {
   int16_t x;
   int16_t y;
  int16_t coordonnees[2];
  uint8_t bytes[4];
} Point;
typedef struct {
 union {
  struct {
   int8_t x;
   int8_t y;
   int8_t z;
  uint8_t bytes[3];
} Vitesses;
// CONFIG
#define PISERIAL Serial
#define NBPOSITIONS 2
#define FAILSAFE 250 // ms
// TTS
#define TTSBUFFERSIZE 255
uint8_t ttsBuffer[TTSBUFFERSIZE];
uint8_t ttsCurseur = 0;
// TX
#define TXFRAMESIZE (NBPOSITIONS * 4 + 17)
typedef struct {
 union {
  struct {
   uint8_t sync[4];               // 4
   Point positions[NBPOSITIONS];  // NBPOSITIONS * 4
   uint16_t val16[2];             // 2 * 2
   uint8_t choixCameras;          // 1
   Vitesses vitesses;             // 3
   uint8_t interrupteurs;         // 1
   uint8_t val8[4];               // 4
  uint8_t bytes[TXFRAMESIZE];
} TrameTx;
// RX
#define RXFRAMESIZE (NBPOSITIONS * 4 + 9)
typedef struct {
 union {
  struct {                       // Sizes
  uint8_t bytes[RXFRAMESIZE];
} TrameRx;
TrameTx trameTx;
TrameRx trameRx;
uint32_t lastTrameTimestamp = millis();
  PISERIAL.begin(115200);
  // add all your init here
  if(readPiSerial()) {
    // each time we receive a full trame run repeatedly:
    // use values inside trameRx to tell your robot how to move ...
    // trameRx.vitesses.x , trameRx.vitesses.y, trameRx.vitesses.z
    // trameRx.positions[i].x trameRx.positions[i].y  etc....
    writePiSerial();
  if( millis() - lastTrameTimestamp > FAILSAFE ) {
    // Stop the robot in case the robot lost connection with the Pi
  } else {
    // put your main code here, to run repeatedly:
    // avoid abstacle, run speed ...
bool readPiSerial() {
 uint8_t current;
 static uint8_t lastType = 0;
 static uint8_t n = 0;
 static uint8_t frame[RXFRAMESIZE];
 while(PISERIAL.available()) {
  current = PISERIAL.read();
  switch(n) {
   case 0:
    if(current == '$')
     n = 1;
    break;
   case 1:
    if(current != 'T' && lastType == 'T')
     writeTtsBuffer('\0');
    if(current == 'S' || current == 'T') {
     lastType = current;
     n = 2;
    } else
     n = 0;
    break;
    default:
    frame[n++] = current;
    if(n == RXFRAMESIZE) {
     if(lastType == 'T') {
      for(uint8_t i = 4; i < RXFRAMESIZE; i++) // Do not send the 4 sync data in tts
       writeTtsBuffer(frame[i]);
     } else if(lastType == 'S') {
      for(uint8_t p = 0; p < RXFRAMESIZE; p++)
       trameRx.bytes[p] = frame[p];
     n = 0;
     return true;
 return false;
void writePiSerial() {
 // Header, do not modify
 trameTx.sync[0] = '$';
 trameTx.sync[1] = 'R';
 trameTx.sync[2] = ' ';
 trameTx.sync[3] = ' ';
 // modify the feedback according your need. By default we copy the trameRx content ...
 for(uint8_t i = 0; i < NBPOSITIONS; i++) {
  trameTx.positions[i].x = trameRx.positions[i].x;
  trameTx.positions[i].y = trameRx.positions[i].y;
 trameTx.val16[0] = 0;   // Voltage (will be updated by Raspberry pi)
 trameTx.val16[1] = 0;   // Percent (will be updated by Raspberry pi)
 trameTx.choixCameras = trameRx.choixCameras;
 trameTx.vitesses.x = trameRx.vitesses.x;
 trameTx.vitesses.y = trameRx.vitesses.y;
 trameTx.vitesses.z = trameRx.vitesses.z;
 trameTx.interrupteurs = trameRx.interrupteurs;
 trameTx.val8[0] = 0;   // CPU load (will be updated by Raspberry pi)
 trameTx.val8[1] = 0;   // Soc temp (will be updated by Raspberry pi)
 trameTx.val8[2] = 0;   // link (will be updated by Raspberry pi)
 trameTx.val8[3] = 0;   // RSSI (will be updated by Raspberry pi)
 for( uint8_t i = 0; i < TXFRAMESIZE; i++)
  PISERIAL.write(trameTx.bytes[i]);
void displayTtsBuffer (uint8_t * ttsBuffer, uint8_t bufferSize) {
// you should modify this function to display text on a screen depending on your hardware...
/* if using an arduino with a second Serial different from the PISERIAL example SERIAL1 you can do this :
  for( uint8_t i = 0; i < bufferSize; i++)
    Serial1.write(ttsBuffer[i]);
  Serial1.println("");
void writeTtsBuffer( uint8_t ttsChar) {
  static uint8_t ttsCurseur = 0;
  if( ttsCurseur < TTSBUFFERSIZE && ttsChar != '\0') {
    ttsBuffer[ttsCurseur] = ttsChar;
    ttsCurseur ++;
  if( ttsCurseur == TTSBUFFERSIZE || ttsChar == '\0') {
    displayTtsBuffer (ttsBuffer, ttsCurseur);
    ttsCurseur = 0;
Note :
EN
You will need change the -1 WRITEUSERDEVICE value  and replace it by the serial connection number you want use ( by default use 0 ) to tell the raspberryPi to send data to the arduino and same for READUSERDEVICE if you want the Pi to read information sent by the arduino on Vigibot. ( To do this open the management tab, open the hardware config and enable them in the effective configuration tab)
To connect your arduino to the Pi, you need to connect Arduino TX pin on Pi RX pin and Arduino Rx pin on TX Pi pin.
Plus, you need to connect ground between Arduino and Pi .
Warning:
Pi is working with a 3.3V logic level. If using a 5V arduino board ( like uno, nano or mega) you should use a logic level converter
FR
Vous devrez changer le WRITEUSERDEVICE -1 et mettre le numero du serial que vous souhaiter utiliser pour dire à la Raspberry pi d'envoyer des données à l'arduino ( en général par défaut le numéro à mettre est 0 ) et Idem avec READUSERDEVICE pour dire à la Raspberry pi de lire les informations envoyée par l'arduino sur Vigibot. ( pour le faire ouvrez la fenêtre de Gestion, puis la fenêtre de configuration matériel et activez les options souhaitées dans " configuration effective " )
Pour relier une arduino à un pi en Serial il faut connecter le TX de l'arduino au RX de la raspberry pi et inversement le RX de l'arduino au TX de la raspberry pi.
De plus, la masse de l'arduino et de la raspberry pi doit être commune...
Attention rappel :
La raspberry pi est en niveau logique 3.3V.
Si vous utilisez une arduino en 5V (arduino uno, mega, nano ) il faudra utiliser un convertisseur de niveau logique
#2 Marmont
Marmont
  • 2 messages
Posté 04 décembre 2019 - 15:02
Hello here,
I have tested the code with a pololu zumo, work like a charm!
The advantage here is if you have a robot wich is already driven by arduino, it can be easily modified to work with vigibot:
1) Connect the UART :
  • Ardu.pin0 RX <-> PI GPIO14 TX
  • Ardu.pin1 TX <-> PI GPIO15 RX
  • GND <-> GND
2) Modify the code above to work with your bot, in the main loop you can get the most importants variables:
trameRx.vitesses.y -> Speed in main axis of the robot send by the server
trameRx.vitesses.z - Rotation around the vertical axis send by the server
With theses moves requests you can program your motors to feet the particularity of the robot. Here the exemple with a classical differential driven robot, the Zumo.
    // mixage pour obtenir les vitesses moteurs
    left_speed = (trameRx.vitesses.y * MAX_SPEED / SPEED_RANGE) - (trameRx.vitesses.z * MAX_SPEED / SPEED_RANGE);
    right_speed = (trameRx.vitesses.y * MAX_SPEED / SPEED_RANGE) + (trameRx.vitesses.z * MAX_SPEED / SPEED_RANGE);
    // Saturation des vitesses
    left_speed = min(max(left_speed, -MAX_SPEED), MAX_SPEED);
    right_speed = min(max(right_speed, -MAX_SPEED), MAX_SPEED);
Then you can send the right speed to your motors, in my case: (I use a library to drive the zumo)
    ZumoMotors::setSpeeds(left_speed, right_speed);
Here the complete code :
 * Completed by Marmont to work with a Zumo
#include <ZumoShield.h>
// Meta Type :
typedef struct {
 union {
  struct {
   uint16_t x;
   uint16_t y;
  uint16_t coordonnees[2];
  uint8_t bytes[4];
} Point;
typedef struct {
 union {
  struct {
   int8_t x;
   int8_t y;
   int8_t z;
  uint8_t bytes[3];
} Vitesses;
// CONFIG
#define MAX_SPEED              400 // max motor speed
#define SPEED_RANGE            128 //
// TTS
// TX
typedef struct {
 union {
  struct {
} TrameTx;
// RX
typedef struct {
 union {
  struct {                       // Sizes
   Point positions[NBPOSITION];  // NBPOSITIONS * 4
} TrameRx;
TrameTx trameTx;
TrameRx trameRx;
    // use values inside TrameRx to tell your robot how to move ...
    writePiSerial();
  } else {
    int left_speed, right_speed;
 uint8_t current;
  switch(n) {
   case 0:
    if(current == '$')
     n = 1;
    break;
   case 1:
     lastType = current;
     n = 2;
    } else
     n = 0;
    break;
    default:
      for(uint8_t i = 4; i < RXFRAMESIZE; i++) // 4 to not send the sync data into tts
     n = 0;
     return true;
 return false;
    ttsCurseur ++;
    ttsCurseur = 0;
Very easy, very fonctionnal, a lot more functionnality to investigate!
Thk to mikes118 for the great work.
Marmont
#3 Snyp54
Snyp54
  • 416 messages
Posté 10 janvier 2020 - 22:14
Hi all,
With Mike118 ( and only Mike118 ^^ ), we have make a code for use FEETECH SCS15 servo to work with Vigibot.
The full code
#include <SCServo.h>
SCSCL sc;
int uint16toSCS15( uint16_t value ) {
  return (value - 32768)* 512 * 180 / (100 * 32768) + 512;
uint8_t servoId[4] {2, 3 , 4, 5};
// Meta Type :
struct Point {
 union {
  struct {
   uint16_t x;
   uint16_t y;
  uint8_t bytes[4];
struct  Vitesses{
 union {
  struct {
   int8_t x;
   int8_t y;
   int8_t z;
  uint8_t bytes[3];
// CONFIG
#define PISERIAL Serial2
#define FAILSAFE 200 // ms
// TTS
// TX
struct TrameTx {
 union {
  struct {
// RX
#define RXFRAMESIZE (NBPOSITIONS* 4 + 9)
struct TrameRx{
 union {
  struct {                        // Sizes
   uint8_t sync[2];               // 4
TrameTx trameTx;
TrameRx trameRx;
Point oldPositions[NBPOSITIONS];        // NBPOSITIONS * 4
  Serial1.begin(1000000);
  sc.pSerial = &Serial1;
    writePiSerial();
  } else {
    updateServo();
void updateServo() {
    for(uint8_t j = 0; j < 2 ; j++) {
      if(oldPositions[i].coordonnees[j] != trameRx.positions[i].coordonnees[j]) {
        sc.WritePos(servoId[i + j], uint16toSCS15(trameRx.positions[i].coordonnees[j]), 200);
        oldPositions[i].coordonnees[j] = trameRx.positions[i].coordonnees[j];
 uint8_t current;
  switch(n) {
   case 0:
    if(current == '$')
     n = 1;
    break;
   case 1:
     lastType = current;
     n = 2;
    } else
     n = 0;
    break;
    default:
      for(uint8_t i = 2; i < RXFRAMESIZE; i++)
     n = 0;
     return true;
 return false;
  // you can modify this function to display text on a screen depending on your hardware...
    Serial.write(ttsBuffer[i]);
  Serial.println("");
    ttsCurseur ++;
    ttsCurseur = 0;
Add SCS Library and convert 0 65535 -> -180° à 180° to 0 1023 -> -100° à 100°:
SCSCL sc;
Configure ID servo with POSITIONS: ( sc.WritePos(IDSERVO, uint16toSCS15(trameRx.positions[0].y), 200);
And voila!
#4 Mike118
  • 12 871 messages
Posté 13 février 2020 - 21:29
How to add your custom return value ?
Chose if you want return a val8  ( 8bits value ) or a val16 ( 16bits value )
For example I want add a voltage value as val8.
=> I will need to configure vigibot to activate devCommande and devTelemetrie  and add a val8 in RX config
=> I will need to modify the arduino code to add my val8 in the trameTx structure and update TXFRAMESIZE.
#define TXFRAMESIZE (NBPOSITIONS * 4 + 18)   // NBPOSITIONS * 4 + 17 by default + 1 for the val8 added ( we would add 2 for  val16)
struct TrameTx {
 union {
  struct {
   uint8_t val8[5];               // 4 by default => Now set to 5 = 4 +1
Then I will be able to make the line somewhere in the code : ( can be done in writePiSerial() but can be done elsewhere... )
trameTx.val8[4] = yourCustomValue;  // change yourCustomValue according your need.
See a full code example here : https://www.robot-ma...gibot/?p=107522
#5 Gamepigeek
Gamepigeek
  • 61 messages
  • Interests:Robots, Electronique, Informatique.
Posté 05 mai 2021 - 13:15
Hello everyone !
Je vais Vigiboter mon train légo. Pour ce faire, j'utilise un ESP32.
J'ai donc repris le code d'exemple de @Mike118 que j'ai adapté :
#include <WiFi.h>
#include <ESPmDNS.h>
#include "esp32-hal-ledc.h"
const char* ssid = "ssid";
const char* pass = "mdp";
// Set your Static IP address
IPAddress local_IP(192, 168, 0, 61);
// Set your Gateway IP address
IPAddress gateway(192, 168, 0, 254);
IPAddress subnet(255, 255, 255, 0);
// Meta Type :
typedef struct {
  union {
    struct {
      int16_t x;
      int16_t y;
    uint8_t bytes[4];
} Point;
typedef struct {
  union {
    struct {
      int8_t x;
      int8_t y;
      int8_t z;
    uint8_t bytes[3];
} Vitesses;
// CONFIG
//#define PISERIAL Serial
#define MAX_SPEED              1275 // max motor speed
#define SPEED_RANGE            256 //
// TTS
// TX
typedef struct {
  union {
    struct {
} TrameTx;
// RX
typedef struct {
  union {
    struct {                       // Sizes
} TrameRx;
TrameTx trameTx;
TrameRx trameRx;
uint32_t lastSleepBeacon;
WiFiServer server(7070);  //ESP server port
WiFiClient client;
  Serial.begin(115200);
  ledcSetup(1, 50, 16); // channel 1, 50 Hz, 16-bit width
  ledcAttachPin(13, 1);   // GPIO 13 assigned to channel 1
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.config(local_IP, gateway, subnet);
  WiFi.setHostname("Vigibot_ESP_0");
  WiFi.begin(ssid, pass);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Connection Failed! Rebooting...");    delay(5000);
    ESP.restart();
  server.begin();
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
    Serial.println("WLAN Connection Failed! reconnecting...");
    delay(10000);
  if (readPiSerial()) {
    writePiSerial();
  if ( millis() - lastTrameTimestamp > FAILSAFE ) {
    if ((millis() - lastSleepBeacon > 10000) ) { // every 10 seconds
      writePiSerial();                        // Beacon to say that the robot is alive
      lastSleepBeacon = millis();
    ledcWrite(1, 0); //stop the train
  } else {
    int speed;
    speed = min(max(speed, -MAX_SPEED), MAX_SPEED);
    ledcWrite(1, speed);
  uint8_t current;
  static byte lastClientState = 0;
  if (client.connected()) {
    if (!lastClientState) {
      lastClientState = 1;
      Serial.println("New Client.");
    while (client.available()) {
      current = client.read();
      //Serial.write(current); //debug
      switch (n) {
        case 0:
          if (current == '$')
            n = 1;
          break;
        case 1:
          if (current != 'T' && lastType == 'T')
            writeTtsBuffer('\n');
          if (current == 'S' || current == 'T') {
            lastType = current;
            n = 2;
          } else
            n = 0;
          break;
        default:
          if (n == RXFRAMESIZE) {
            if (lastType == 'T') {
              for (uint8_t i = 4; i < RXFRAMESIZE; i++) // Do not send the 4 sync data in tts
            } else if (lastType == 'S') {
              for (uint8_t p = 0; p < RXFRAMESIZE; p++)
            n = 0;
            return true;
          //break;
  } else { //if current client is not actively connected anymore, disconnect and wait for new client
    if (lastClientState) {
      // close the connection:
      client.stop();
      Serial.println("Client Disconnected.");
    client = server.available();   // listen for incoming clients
  return false;
  for (uint8_t i = 0; i < NBPOSITIONS; i++) {
  for ( uint8_t i = 0; i < TXFRAMESIZE; i++)
    client.write(trameTx.bytes[i]);
  for ( uint8_t i = 0; i < bufferSize; i++) {
  Serial.println("");
  if ( ttsCurseur < TTSBUFFERSIZE && ttsChar != '\n') {
    ttsCurseur ++;
  if ( ttsCurseur == TTSBUFFERSIZE || ttsChar == '\n') {
    ttsCurseur = 0;
Ca fonctionne parfaitement sauf que quand j'accélère sur Vigibot ca n'avance pas comme je veux vu que les math n'ont pas été faites.
Je parle de :
ou/et de :
en sachant que vigibot envoi les consignes moteurs en 8 bit ..
Je n'ai pas encore le niveau pour améliorer comme je veux ce genre de réglage PWM Hertz etc..
Le calcul reste le meme que pour Zumo.
Merci de votre aide !
Pierre
Pierre
Pour visiter mon site perso auto hébergé, cliquez sur ce : Lien.
Je possède des robots sur Vigibot, n'hésitez pas a y faire un tour et demander l'accès au pilotage x).
#6 firened
firened
  • 2 124 messages
Posté 05 mai 2021 - 19:07
Hi Pierre
Good job with the ledc functions, it's not easy to learn that!
i only found this, could be a problem:
int speed;
integer is only -32'xxx to + 32'xxx, your calculation with maximum values (127 * 1275) will exceed that value. consider using a single factor like this to get somewhere close (only natural numbers, no 10.1 or so) :
int speed;
    speed = (trameRx.vitesses.y * 10) - (trameRx.vitesses.z * 10);
and also make sure `IPAddress gateway(192, 168, 0, 254);` is the IP of your Router.
let me know if it helps. if not: is the motor speed random or always the same when not stopped?
#7 Gamepigeek
Gamepigeek
  • 61 messages
Posté 07 mai 2021 - 10:25
Hello,
I finished my code with the help of Mike118 and Firened ! Thank you so much
#include <WiFi.h>
int pwmChannel = 0; //Choisit le canal 0
int frequence = 50; //Fréquence PWM de 5 KHz
int resolution = 16; //Résolution de 16 bits, 65535 valeurs possibles
int pwmPin = 13;
int MaxRev = 8192;// duty cycle pour avancer fond
int MaxFor = 1638;// duty cycle pour reculer a fond
const char* ssid = "My Wifi";
const char* pass = "My Pass";
// Meta Type :
typedef struct {
  union {
    struct {
      int16_t x;
      int16_t y;
    uint8_t bytes[4];
} Point;
typedef struct {
  union {
    struct {
      int8_t x;
      int8_t y;
      int8_t z;
    uint8_t bytes[3];
} Vitesses;
// CONFIG
// TTS
// TX
typedef struct {
  union {
    struct {
} TrameTx;
// RX
typedef struct {
  union {
    struct {                       // Sizes
} TrameRx;
TrameTx trameTx;
TrameRx trameRx;
WiFiClient client;
  ledcSetup(pwmChannel, frequence, resolution);
  ledcAttachPin(pwmPin, pwmChannel);
    ESP.restart();
  server.begin();
    delay(10000);
    writePiSerial();
    ledcWrite(pwmChannel, 0); //stop the train
  } else {
    int speed = map(trameRx.vitesses.y, -128, 128, MaxFor, MaxRev); // 128 recu par vigibot
    ledcWrite(pwmChannel, speed); //envoyer la consigne vitesse au moteur via la lib
  uint8_t current;
      switch (n) {
        case 0:
          if (current == '$')
            n = 1;
          break;
        case 1:
            lastType = current;
            n = 2;
          } else
            n = 0;
          break;
        default:
            n = 0;
            return true;
          //break;
      client.stop();
  return false;
  Serial.println("");
    ttsCurseur ++;
    ttsCurseur = 0;
Pierre
