rdk-technical-support
1110 réponses à ce sujet
#781 aiyaz3007
aiyaz3007
  • 30 messages
Posté 16 janvier 2026 - 01:06
Okay got you
#782 dd2mf
dd2mf
  • 261 messages
ight
#783 dd2mf
dd2mf
  • 261 messages
try it and tell me how it goes
#784 dd2mf
dd2mf
  • 261 messages
man I should really make a llm chat bot for these technical support stuff
#785 dd2mf
dd2mf
  • 261 messages
Posté 16 janvier 2026 - 01:07
gotta put those 3090s to use
#786 aiyaz3007
aiyaz3007
  • 30 messages
Sure, I will do and let you know
#787 _coronavirus
_coronavirus
  • 30 messages
Posté 17 janvier 2026 - 06:56
Hey, did the stereonet work out-of-the-box with you guys? I have the official stereocamera, but it is quite inaccurate with the pre-made calibrations.
#788 _coronavirus
_coronavirus
  • 30 messages
Posté 17 janvier 2026 - 06:57
Its accuracy drops off before 2m
#789 _coronavirus
_coronavirus
  • 30 messages
Posté 17 janvier 2026 - 07:10
@help
#790 _coronavirus
_coronavirus
  • 30 messages
Posté 18 janvier 2026 - 01:03
Can you help me, fellow Chinese man? :slightly_frowning_face:
#791 ezhihavtumane
ezhihavtumane
  • 5 messages
Posté 18 janvier 2026 - 04:24
Hi, I'm trying to connect DS3231 to my rdk x5.
which pins correspond to SDA and SCL? I tried pins 3/5 and 27/28 but none of the buses detect it. I'm looking for address 68
#792 wise_courgette_94725
  • 80 messages
Posté 19 janvier 2026 - 09:17
Hi CoronaVirus, what exactly is your effect?
#793 _coronavirus
_coronavirus
  • 30 messages
Posté 19 janvier 2026 - 02:03
My effect? The problem is, that the stereonet model is accurate to within 1.7m, but beyond that it says that an object at 3m is at 1.7m. Or an object at 5 meters is at 3.
#794 _coronavirus
_coronavirus
  • 30 messages
Posté 19 janvier 2026 - 02:04
I am going to try and calibrate it, but I am curios to know, if there is a better fix and if this is a known issue?
#795 _coronavirus
_coronavirus
  • 30 messages
Posté 19 janvier 2026 - 02:05
:cjk_unified_ideograph-8981::cjk_unified_ideograph-4e0d::cjk_unified_ideograph-6211::cjk_unified_ideograph-4eec::cjk_unified_ideograph-76f4::cjk_unified_ideograph-63a5::cjk_unified_ideograph-8bf4::cjk_unified_ideograph-4e2d::cjk_unified_ideograph-6587::cjk_unified_ideograph-5427::fullwidth_question_mark::cjk_unified_ideograph-8fd8::cjk_unified_ideograph-662f::cjk_unified_ideograph-8bf4::cjk_unified_ideograph-8fd9::cjk_unified_ideograph-4e2a::cjk_unified_ideograph-8bba::cjk_unified_ideograph-575b::cjk_unified_ideograph-4e0d::cjk_unified_ideograph-8ba9::fullwidth_question_mark:
#796 philipx115
philipx115
  • 3 messages
Posté 19 janvier 2026 - 08:29
Hey :bye:
I'm an AI & Full-Stack Engineer working on production AI systems and automation.
I build LLM-powered features, RAG pipelines, and workflow automation, and ship them as real web and mobile products.
Stack- **AI / Data**: LLMs, RAG, embeddings, vector search, Whisper, CLIP
- **Backend**: Node.js, Python, Django, FastAPI, Laravel, REST APIs, async jobs
- **Frontend**: React, Next.js, TypeScript, Tailwind
- **Automation**: Slack/Notion APIs, webhooks, cron, background workers
- **Infra**: AWS (Lambda, S3), Docker, CI/CD
- **Mobile**: Flutter, Swift, React Native
Open to projects or collaboration - DM anytime :yes:
#797 wise_courgette_94725
  • 80 messages
Posté 20 janvier 2026 - 04:20
:cjk_unified_ideograph-628a::cjk_unified_ideograph-4f60::cjk_unified_ideograph-7684::cjk_unified_ideograph-6548::cjk_unified_ideograph-679c::cjk_unified_ideograph-56fe::cjk_unified_ideograph-8d34::cjk_unified_ideograph-51fa::cjk_unified_ideograph-6765::cjk_unified_ideograph-770b::cjk_unified_ideograph-770b:
#798 wise_courgette_94725
  • 80 messages
:cjk_unified_ideograph-76ee::cjk_unified_ideograph-524d::cjk_unified_ideograph-6765::cjk_unified_ideograph-770b:3:cjk_unified_ideograph-7c73::cjk_unified_ideograph-5185::cjk_unified_ideograph-7cbe::cjk_unified_ideograph-5ea6::cjk_unified_ideograph-5e94::cjk_unified_ideograph-8be5::cjk_unified_ideograph-662f::cjk_unified_ideograph-6ca1::cjk_unified_ideograph-95ee::cjk_unified_ideograph-9898::cjk_unified_ideograph-7684:
#799 _coronavirus
_coronavirus
  • 30 messages
Posté 21 janvier 2026 - 12:27
:cjk_unified_ideograph-6211::cjk_unified_ideograph-8fd0::cjk_unified_ideograph-884c::cjk_unified_ideograph-4e86::cjk_unified_ideograph-4ee5::cjk_unified_ideograph-4e0b::cjk_unified_ideograph-547d::cjk_unified_ideograph-4ee4::fullwidth_colon:
ros2 launch hobot_stereonet stereonet_model_web_visual_v2.launch.py \ mipi_image_width:=640 mipi_image_height:=352 mipi_lpwm_enable:=True mipi_image_framerate:=30.0 \ need_rectify:=False height_min:=-10.0 height_max:=10.0 pc_max_depth:=5.0
:cjk_unified_ideograph-7ed3::cjk_unified_ideograph-679c::cjk_unified_ideograph-5982::cjk_unified_ideograph-4e0b::fullwidth_colon:
:cjk_unified_ideograph-6905::cjk_unified_ideograph-5b50::cjk_unified_ideograph-8ddd::cjk_unified_ideograph-79bb::cjk_unified_ideograph-76f8::cjk_unified_ideograph-673a::cjk_unified_ideograph-5927::cjk_unified_ideograph-7ea6: 1 :cjk_unified_ideograph-7c73::ideographic_full_stop: Fichier joint  image.png   798,23 Ko   0 téléchargement(s)
#800 _coronavirus
_coronavirus
  • 30 messages
Posté 21 janvier 2026 - 12:29
:cjk_unified_ideograph-8fd9::cjk_unified_ideograph-5f20::cjk_unified_ideograph-56fe::cjk_unified_ideograph-53ef::cjk_unified_ideograph-80fd::cjk_unified_ideograph-66f4::cjk_unified_ideograph-6e05::cjk_unified_ideograph-6670::cjk_unified_ideograph-4e00::cjk_unified_ideograph-4e9b::ideographic_full_stop::cjk_unified_ideograph-6211::cjk_unified_ideograph-60f3::cjk_unified_ideograph-5b83::cjk_unified_ideograph-4f30::cjk_unified_ideograph-8ba1::cjk_unified_ideograph-68cb::cjk_unified_ideograph-76d8::cjk_unified_ideograph-683c::cjk_unified_ideograph-7684::cjk_unified_ideograph-4f4d::cjk_unified_ideograph-7f6e::cjk_unified_ideograph-662f::cjk_unified_ideograph-5728: 4 :cjk_unified_ideograph-7c73::cjk_unified_ideograph-5de6::cjk_unified_ideograph-53f3::fullwidth_question_mark: Fichier joint  image.png   788,45 Ko   0 téléchargement(s)
