rdk-technical-support
1110 réponses à ce sujet
#801 _coronavirus
_coronavirus
  • 30 messages
Posté 21 janvier 2026 - 12:31
:cjk_unified_ideograph-5f53::cjk_unified_ideograph-672c::cjk_unified_ideograph-4eba::cjk_unified_ideograph-7f6e::cjk_unified_ideograph-8eab::cjk_unified_ideograph-4e8e::cjk_unified_ideograph-5176::cjk_unified_ideograph-524d::cjk_unified_ideograph-65b9::cjk_unified_ideograph-7ea6:30:cjk_unified_ideograph-5398::cjk_unified_ideograph-7c73::cjk_unified_ideograph-5904::cjk_unified_ideograph-65f6::fullwidth_comma::cjk_unified_ideograph-7ed3::cjk_unified_ideograph-679c::cjk_unified_ideograph-5982::cjk_unified_ideograph-4e0b::ideographic_full_stop: Fichier joint  image.png   328,24 Ko   0 téléchargement(s)
#802 _coronavirus
_coronavirus
  • 30 messages
Posté 21 janvier 2026 - 12:33
:cjk_unified_ideograph-5e76::cjk_unified_ideograph-975e::cjk_unified_ideograph-523b::cjk_unified_ideograph-610f::cjk_unified_ideograph-50ac::cjk_unified_ideograph-4fc3::fullwidth_comma::cjk_unified_ideograph-53ea::cjk_unified_ideograph-662f::cjk_unified_ideograph-60f3::cjk_unified_ideograph-8bf7::cjk_unified_ideograph-6559::cjk_unified_ideograph-76ee::cjk_unified_ideograph-524d::cjk_unified_ideograph-662f::cjk_unified_ideograph-5426::cjk_unified_ideograph-6709::cjk_unified_ideograph-53ef::cjk_unified_ideograph-884c::cjk_unified_ideograph-7684::cjk_unified_ideograph-4fee::cjk_unified_ideograph-590d::cjk_unified_ideograph-65b9::cjk_unified_ideograph-6cd5::fullwidth_question_mark::cjk_unified_ideograph-56e0::cjk_unified_ideograph-9879::cjk_unified_ideograph-76ee::cjk_unified_ideograph-5468::cjk_unified_ideograph-4e94::cjk_unified_ideograph-5230::cjk_unified_ideograph-671f::fullwidth_comma::cjk_unified_ideograph-82e5::cjk_unified_ideograph-80fd::cjk_unified_ideograph-5c06:3:cjk_unified_ideograph-7c73::cjk_unified_ideograph-8303::cjk_unified_ideograph-56f4::cjk_unified_ideograph-5185::cjk_unified_ideograph-7684::cjk_unified_ideograph-7cbe::cjk_unified_ideograph-5ea6::cjk_unified_ideograph-8c03::cjk_unified_ideograph-6574::cjk_unified_ideograph-8fbe::cjk_unified_ideograph-6807::fullwidth_comma::cjk_unified_ideograph-5bf9::cjk_unified_ideograph-6211::cjk_unified_ideograph-6765::cjk_unified_ideograph-8bf4::cjk_unified_ideograph-4fbf::cjk_unified_ideograph-5df2::cjk_unified_ideograph-8db3::cjk_unified_ideograph-591f::fullwidth_comma::cjk_unified_ideograph-975e::cjk_unified_ideograph-5e38::cjk_unified_ideograph-611f::cjk_unified_ideograph-8c22::cjk_unified_ideograph-60a8::cjk_unified_ideograph-7684::cjk_unified_ideograph-534f::cjk_unified_ideograph-52a9::ideographic_full_stop:
#803 _coronavirus
_coronavirus
  • 30 messages
Posté 21 janvier 2026 - 05:14
#804 _coronavirus
_coronavirus
  • 30 messages
Posté 22 janvier 2026 - 03:39
When I run ros2 launch hobot_stereonet stereonet_model_web_visual_v2.launch.py \
mipi_image_width:=640 mipi_image_height:=352 mipi_lpwm_enable:=True \
mipi_image_framerate:=15.0 need_rectify:=False height_min:=-10.0 \
height_max:=10.0 pc_max_depth:=5.0 \
save_dir:=/home/sunrise/Desktop/calib_data/ \
save_image_all:=True \
save_freq:=150
The images that are saved (left- and right respectively,) are they the raw or calibrated images?
#805 wise_courgette_94725
  • 80 messages
Posté 22 janvier 2026 - 04:41
please wait, we'll do some investigation
#806 tototek
tototek
  • 7 messages
Posté 22 janvier 2026 - 04:27
Hi.Has anyone run xburn-gui on Windows 10? I've installed and uninstalled the last two versions and it won't run.
#807 tototek
tototek
  • 7 messages
Posté 22 janvier 2026 - 04:50
Hi .Another question about RDK X5.Is there a possibility of running Armbian or another distribution?
#808 _coronavirus
_coronavirus
  • 30 messages
Posté 22 janvier 2026 - 10:47
Don't know about that specific package, but I also had a lot of problems with my RDK X5 first. Specifically, it wouldn't run many of the demos that were pre-installed, like Stereonet. I downloaded the second oldest image/operating system.
If you find a tutorial online, they will show which version they used typically.
#809 ezhihavtumane
ezhihavtumane
  • 5 messages
Posté 22 janvier 2026 - 11:00
Can anyone help please?
#810 wise_courgette_94725
  • 80 messages
Posté 27 janvier 2026 - 10:52
Currently RDK X5 does not support other distribution unfortunately
#811 olivier
olivier
  • 26 messages
Posté 27 janvier 2026 - 12:58
Hello , im on rdk x5, I want to run YOLO inference from a USB UVC camera (OV5693, MJPEG 1080p30).
Target pipeline: UVC MJPEG :rightwards_arrow: HW JPEG decode :rightwards_arrow: VPS/VSE :rightwards_arrow: NPU (YOLO), with minimal CPU copies.
Questions:
- Is HW JPEG/MJPEG decode supported via hb_mm_mc/hbn?
- Can UVC DMABUF (VIDIOC_EXPBUF) be imported directly into codec/VPS, or is MMAP+copy required?
- Which sample is the best reference for USB camera :rightwards_arrow: inference?
- Recommended input format for YOLO (NV12 vs RGB)?
Thanks!
#812 guosheng_xu
guosheng_xu
  • 28 messages
Posté 27 janvier 2026 - 03:25
ok
#813 ansh_58656
ansh_58656
  • 21 messages
Posté 27 janvier 2026 - 03:26
#814 ansh_58656
ansh_58656
  • 21 messages
#815 chao_ma
chao_ma
  • 8 messages
Posté 28 janvier 2026 - 08:06
Your proposed pipeline is very efficient for edge AI tasks. Here are the answers to your questions and our recommendations:
1. Best Reference: TogetheROS.Bot (TROS) For the "UVC :rightwards_arrow: Decode :rightwards_arrow: YOLO" workflow, we highly recommend using our TROS (TogetheROS.Bot) functional packages. We have already encapsulated high-performance nodes for UVC capture and hardware decoding, which will significantly simplify your development compared to calling low-level C APIs.
YOLO Box Reference: https://developer.d-.../detection/yolo
Model Conversion: [For optimizing your own YOLO model for RDK X5, check our Model Zoo / Ultralytics YOLO.](https://github.com/D...ltralytics_YOLO)
2. Hardware Decoding & Memory (DMABUF)
HW Decode: RDK X5 supports hardware JPEG/MJPEG decoding. You can find the low-level implementation details and C-dev demos here: [Multi-media SP Dev API](https://developer.d-...v_api/cdev_demo).
DMABUF: Most standard UVC drivers do not support direct DMABUF export (VIDIOC_EXPBUF). Typically, an explicit memcpy is required to move the data from the UVC buffer to ION/DMABUF memory before the hardware decoder or BPU can access it.
3. Input Format (NV12 vs RGB) From a performance standpoint, we strongly recommend NV12.
The hardware decoder outputs in NV12 format directly.
The BPU is highly optimized for NV12.
#816 olivier
olivier
  • 26 messages
Posté 28 janvier 2026 - 05:36
Thanks a lot for the detailed answer, it's very helpful :thank_you:
It confirms several key points for us, especially:
MJPEG/JPEG hardware decoding support on RDK X5
NV12 being the optimal internal format
and the practical limitation of DMABUF with standard UVC drivers.
We did look at TROS and we really like ROS in general. For robotic systems and rapid prototyping, it's clearly a great and powerfull solution and pôwerfull.
For this specific project though (multi-camera edge vision, always-on appliance, tight control over latency and resources), we plan to implement a standalone C/C++ pipeline directly on top of the SP multimedia APIs and BPU inference, without ROS. This gives us finer control over scheduling, memory usage, and performance.
That said, TROS is still very valuable for us as a reference implementation, especially for understanding the recommended UVC :rightwards_arrow: HW decode :rightwards_arrow: NV12 :rightwards_arrow: YOLO workflow. We may even prototype certain parts (like UVC capture) with TROS to validate behavior, then move to a lower-level implementation.
If you don't mind, we have a few follow-up questions to make sure we align with best practices on RDK X5:
For USB UVC MJPEG input (when DMABUF export is not available), is there a recommended method to copy the bitstream into HW-accessible memory (ION / media buffer) before feeding the SP decoder?
Is there any reference sample that shows the officially recommended buffer allocation + memcpy path?
After MJPEG HW decode (NV12 output), is it recommended to always pass the frames through VPS/VSE for resize/CSC before BPU, or can the decoder output be fed directly to the BPU if the resolution already matches the model input?
In multi-camera scenarios, is there any recommended practice for BPU job scheduling (single shared context vs per-pipeline contexts), or is a user-level scheduler the intended approach?
Thanks again for the guidance and the links - they are very useful for building an efficient and well-aligned pipeline on RDK X5.
#817 _coronavirus
_coronavirus
  • 30 messages
Posté 28 janvier 2026 - 08:15
Does anybody else have a problem with the DNN module not load the proper file? When I point it towards my .bin file, it seems to ignore it and just load the standard YOLO COCO model?
#818 _coronavirus
_coronavirus
  • 30 messages
Posté 28 janvier 2026 - 11:10
Is there a DNN yolo 11 parser?
#819 _coronavirus
_coronavirus
  • 30 messages
Posté 29 janvier 2026 - 02:06
So, I am trying to run my own YOLO model. I have managed to convert it to .bin and saved a .json config file.
When I run it however, the websocket streamer shows nothing on the address it is suppossed to. I have copied the original starter.py file and hardocded the changes, as it would ignore the options I set for it.
This is the log. My YOLO model is a pre-trained YOLOv11 model with 640x640 input. When I have dump_render true, it saves a single image.
#820 wise_courgette_94725
  • 80 messages
Posté 29 janvier 2026 - 03:44
Hi it woud be helpful to paste your log file here and I'll invite expert to answer your question
