rdk-technical-support
#921
Posté 11 mai 2026 - 05:11
#922
Posté 14 mai 2026 - 04:00
#923
Posté 16 mai 2026 - 09:08
#924
Posté 19 mai 2026 - 04:40
#925
Posté 19 mai 2026 - 04:41
#926
Posté 19 mai 2026 - 05:11
#927
Posté 19 mai 2026 - 05:13
#928
#929
Posté 19 mai 2026 - 07:05
#930
Posté 22 mai 2026 - 07:09
Deleted web casche and re tried, but cannot proceed to next page:triste:
Some issue will be shown
#931
Posté 22 mai 2026 - 10:46
#932
Posté 22 mai 2026 - 01:15
#933
Posté 22 mai 2026 - 03:13
#934
Posté 23 mai 2026 - 07:04
#935
Posté 23 mai 2026 - 07:08
#936
Posté 25 mai 2026 - 04:44
You can troubleshoot this issue by first confirming your RDK S100 has entered the correct flashing mode by pressing the recovery button before powering on the device, then checking your hardware connection by trying a different proper USB port on your computer and ensuring you are using the USB Type-C (Flash/Debug) port on the S100, completely uninstalling existing drivers then reinstalling the official RDK S100 drivers, verifying you have selected the correct product type and connection mode in your Xburn software settings, restarting both your device and computer, and if the issue still persists you can post your detailed problem with related screenshots and logs on the D-Robotics community for further professional technical support.
#937
Posté 26 mai 2026 - 01:10
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCSNOTICE: Welcome to Horizon X5 ASIC BOOTROM - V4.1
NOTICE: OTP config:
NOTICE: otp exist: true
NOTICE: test region size: 304
NOTICE: secure region size: 120
NOTICE: none secure region size: 56
NOTICE: Disable MMU
NOTICE: Booting Trusted Firmware
NOTICE: BL1: v2.8(release):
NOTICE: BL1: Built : 17:42:12, Oct 19 2023
NOTICE: Enter SPI NAND-FLASH Mode......
NOTICE: Nand PAGE_SIZE_2K
NOTICE: Nand is_dummy = true
NOTICE: Nand CLK_12M
NOTICE: SPI baudrate is set to 12000000Hz
NOTICE: Nand reset
NOTICE: reg_status should = 0x18
NOTICE: Invalid enable flash buffer mode
NOTICE: Manufacturer ID 0xc8 Device ID 0x41c8
NOTICE: Enter media_source_select process(5).
NOTICE: SPI Nand flash set quad PASS
NOTICE: Get S1PK
NOTICE: [verify_signature] pass.
NOTICE: [verify_hash] pass.
NOTICE: [auth_decrypt] pass.
NOTICE: BL1: BL2 memory layout address = 0x1fe9f000
NOTICE: BL1: Booting BL2
NOTICE: OTP config:
NOTICE: BL2: v2.8(release):v1.0.8-86-g58eb0b179
NOTICE: BL2: Built : 19:55:47, Jan 22 2026
ERROR: Invalid boot device: 7
PANIC at PC : 0x000000001feb481c
#938
Posté 26 mai 2026 - 01:28
#939
Posté 26 mai 2026 - 03:17
#940
Posté 27 mai 2026 - 03:22
Here is the recommended solution:
1. **Flash via USB**:
* Use the official Horizon **burning tool** (e.g., `hb_tool` or Windows Burn Tool) on your PC.
* Select the correct **Secure Firmware** package (since `otp exist: true`).
* Flash the complete image to the onboard NAND/eMMC.
2. **Verify**:
* Once flashing completes, reboot normally. The green light should proceed to full boot.
20 utilisateur(s) li(sen)t ce sujet
0 members, 20 guests, 0 anonymous users
