rdk-technical-support
1110 réponses à ce sujet
#1001 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 11:08
Hi! Mohshen, could you try connecting the HDMI directly to a monitor first instead of using an HDMI capture card with OBS? We haven't tested that specific setup. If you need a remote display, we recommend using tools like VNC, NoMachine, or the built-in remote desktop feature in RDK Studio.
#1002 ahnaf_mohshen
ahnaf_mohshen
  • 16 messages
Posté 17 juin 2026 - 11:09
I have tested. But same result
#1003 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 11:12
Got it. Since you're getting the same result, could you check a few more things? What is the LED indicator doing right now? Also, did you make sure to flash a desktop image, and are you able to connect to the board via SSH?
#1004 ahnaf_mohshen
ahnaf_mohshen
  • 16 messages
Posté 17 juin 2026 - 11:17
Both green and orange are working.
#1005 ahnaf_mohshen
ahnaf_mohshen
  • 16 messages
Posté 17 juin 2026 - 11:19
#1006 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 11:30
You can use rdk studio to connect your board via quick link and using remote Desktop feature to access your desktop for a quick check, here is the doc: https://developer.d-...ice/typec-flash
#1007 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 11:33
If the remote desktop works successfully, we can rule out the board or the OS image. That would mean the issue is strictly with the physical HDMI cable or the display connection itself
#1008 mrsirlrd
mrsirlrd
  • 15 messages
Posté 17 juin 2026 - 01:01
except i'm not using ROS...
#1009 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 02:16
If you are not using ros, you can follow this guide to use mipi camerahttps://developer.d-robotics.cc/rdk_doc/en/Basic_Application/vision/RDK_X5/mipi_camera
#1010 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 02:23
And could you please share which repository and branch you are using?
#1011 ahnaf_mohshen
ahnaf_mohshen
  • 16 messages
Posté 17 juin 2026 - 02:55
How to connect rdk x5 via ssh without monitor
#1012 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 03:03
you can follow this guide https://developer.d-...rt/remote_login
#1013 shockley6668
shockley6668
  • 128 messages
Posté 17 juin 2026 - 03:04
@RDK-Moss How to connect rdk x5 via ssh without monitor
#1014 ahnaf_mohshen
ahnaf_mohshen
  • 16 messages
Posté 17 juin 2026 - 06:22
My rdk x5 orange led is blinking. What does it mean.
#1015 vishal095015
vishal095015
  • 98 messages
Posté 17 juin 2026 - 06:23
It means it's working now
#1016 ahnaf_mohshen
ahnaf_mohshen
  • 16 messages
Posté 17 juin 2026 - 06:25
does it mean booting is successful
#1017 vishal095015
vishal095015
  • 98 messages
Posté 17 juin 2026 - 06:26
Yes
#1018 mrsirlrd
mrsirlrd
  • 15 messages
Posté 18 juin 2026 - 12:03
Yes, this is exactly what I was doing when I found this issue...
#1019 mowgli_49016
mowgli_49016
  • 22 messages
Posté 19 juin 2026 - 04:11
I updated rdk-studio to 1.2.3 and now it seems to have lost default Moss AI model info.
#1020 mowgli_49016
mowgli_49016
  • 22 messages
