RDK Challenge - 06/12/2026 - Richard
Débuté par richard_muhi, juin 12 2026 01:17
50 réponses à ce sujet
#21
Posté 29 juin 2026 - 04:29
Hi @Richard_muhi congratulations!
#22
@Shockley please check and leave your comments
#23
Posté 30 juin 2026 - 07:49
Hi, Richard_muhi. This is a very ambitious architecture! It really pushes the RDK X5 close to its limits by running multiple perception pipelines alongside SLAM, planning, and control. Looking forward to seeing it implemented.
One suggestion: since you're using three camera streams, you could take advantage of the RDK X5's dedicated hardware video encoder/decoder instead of relying on the CPU for video processing. That can significantly reduce CPU utilization.
Also, if you're using ROS 2, consider using shared-memory transport for image topics. It can greatly reduce memory copies and improve overall throughput when transferring high-bandwidth camera data between nodes.
Overall, this looks like a very well-thought-out Stage 2 proposal. Good luck-I can't wait to see it running!
#24
Posté 03 juillet 2026 - 15:04
#25
Posté 03 juillet 2026 - 15:05
#26
Posté 03 juillet 2026 - 15:08
I have added a lidar sensor for safety in case visual obstacle avoidance system failed.
20260630_205102.jpg 580,79 Ko
0 téléchargement(s)
0 téléchargement(s)
#27
Posté 03 juillet 2026 - 15:12
I have mounted MPU 6050 RDK X5 and L298N together. Next phase is wiring, hopefully I won't encounter magic smoke
20260701_151334.jpg 603,54 Ko
0 téléchargement(s)
20260701_151406.jpg 574,35 Ko
0 téléchargement(s)
20260701_151317.jpg 686,16 Ko
0 téléchargement(s)
0 téléchargement(s)
0 téléchargement(s)
0 téléchargement(s)
#28
Posté 07 juillet 2026 - 16:02
Power system connectors
20260704_042904.jpg 449,9 Ko
0 téléchargement(s)
20260704_042918.jpg 354,36 Ko
0 téléchargement(s)
0 téléchargement(s)
0 téléchargement(s)
#29
Posté 07 juillet 2026 - 16:03
Whole sysetem wired together
20260704_052827.jpg 794,1 Ko
0 téléchargement(s)
20260704_052844.jpg 945,78 Ko
0 téléchargement(s)
20260704_174412.jpg 722,9 Ko
0 téléchargement(s)
0 téléchargement(s)
0 téléchargement(s)
0 téléchargement(s)
#31
Posté 07 juillet 2026 - 16:08
#33
Posté 08 juillet 2026 - 18:53
Camera calibration
#35
Posté 08 juillet 2026 - 18:55
Screenshot_2026-07-08_102935.png 922,04 Ko
0 téléchargement(s)
Screenshot_2026-07-08_103114.png 887 Ko
0 téléchargement(s)
#36
Posté 08 juillet 2026 - 18:56
There result are looking good
#38
Posté 08 juillet 2026 - 18:57
Screenshot_2026-07-08_104722.png 673,06 Ko
0 téléchargement(s)
Screenshot_2026-07-08_104648.png 639,94 Ko
0 téléchargement(s)
#39
Posté 09 juillet 2026 - 10:44
Robot now is fully assembled, and left the bench for ground testing.
20260708_190303.jpg 4,25 Mo
0 téléchargement(s)
0 téléchargement(s)
