Robots-open
733 réponses à ce sujet
#521 dino6344
dino6344
  • 6 messages
Posté 19 octobre 2021 - 01:07
Sure give me a moment.
#522 Mike118
  • 10 567 messages
Posté 19 octobre 2021 - 02:09
It should works out of the box if modem compatible with the raspberry pi.
#523 OdorousWo1f
OdorousWo1f
  • 36 messages
Posté 19 octobre 2021 - 02:14
or just linux
#524 dino6344
dino6344
  • 6 messages
Posté 19 octobre 2021 - 11:50
The modem works great(so far) using the tello cell plan.Have had no issues with modem and it was just plug and play.I first plugged it into my windows 10 so I could look at the zte dashboard and turn the modem "on".Which I may or may not have had to do??I did turn on the wlan in the robots config.was that needed?
#525 firened
firened
  • 178 messages
Posté 20 octobre 2021 - 10:01
not the same brand, but the Huawei e3372 modems work right away, as long as the SIM pin has been disabled the modem can connect by itself.
you can run `ifconfig` and should see a new (3rd) network adapter, e3372 shows up as eth1, so it gets detected as an Ethernet port, enabling wlan is not necessary.
#526 Serveurperso
Serveurperso
  • 576 messages
Posté 20 octobre 2021 - 10:19
the e3372 is a router. it emulate a standard network interface with integrated DHCP server and no need for configuration under linux (and other os)
#527 Deleted_User
Deleted_User
  • 227 messages
Posté 21 octobre 2021 - 12:25
It's a configuration bug
Just reset your robot configuration hard and soft
#528 Serveurperso
Serveurperso
  • 576 messages
Posté 21 octobre 2021 - 03:48
je crois pas que ce soit pertinent @Deleted User si la clé 4G n'est pas un routeur il faut faire toute une conf manuelle sous Linux pour que ça fonctionne
#529 Deleted_User
Deleted_User
  • 227 messages
Posté 21 octobre 2021 - 04:26
Effectivement bug de cerveau :lol:
#530 Serveurperso
Serveurperso
  • 576 messages
Posté 21 octobre 2021 - 06:12
dans le doute, reboot, si ça rate, format :ptdr:
#531 fredj21
fredj21
  • 66 messages
Posté 23 octobre 2021 - 08:15
Hello !
Explorer is Open @ Tech in Vitré
#532 soumyarobo
soumyarobo
  • 1 messages
Posté 23 novembre 2021 - 08:33
hello
#533 Mike118
  • 10 567 messages
Posté 23 novembre 2021 - 12:31
Hello :)
#534 fredj21
fredj21
  • 66 messages
Posté 19 mars 2022 - 01:18
Hello
Explorer Open , en 4G @ MakerFight à Mulhouse
#535 Mike118
  • 10 567 messages
Posté 19 mars 2022 - 01:29
Fait un coucou à barbatronic de ma part ! :P tu devrais repérer l'autocollant Robot Maker sur son robot ;)
#536 firened
firened
  • 178 messages
Posté 27 mai 2022 - 04:50
@Misatou what's the robots name that will launch a drone?
#537 misatou
misatou
  • 2 messages
Posté 27 mai 2022 - 09:42
Titan
#538 Deleted_User
Deleted_User
  • 227 messages
Posté 28 mai 2022 - 02:09
we'll try to launch it again on Wednesday
#539 firened
firened
  • 178 messages
Posté 01 juin 2022 - 03:08
i think drone is about to launch on Titian
#540 OdorousWo1f
OdorousWo1f
  • 36 messages
Posté 01 juin 2022 - 03:41
take a screen capture for me
