power-stations
341 réponses à ce sujet
#221 Serveurperso
Serveurperso
  • 3 428 messages
Posté 18 octobre 2020 - 09:43
cheap & cool, i order some
before I must test if the led work @ 9V without kill
I think yes
because there is a large resistor inside
it work a few mA and @ 9V if it's less than 10mA it's good for the led !
but for 24/7 low usage robots 5V is perfect, but for 1 very used robot a very fast charger is good
We can put only 1 fast charger for all robot, and all other charger @ 5V
#222 firened
firened
  • 1 783 messages
Posté 18 octobre 2020 - 10:16
yeah if the robot supports it it's nice.
the IP2312 charger which is on the vigiUPS is QC3.0 and supports 5V, 9V and 12V.
i do not know what happens if it receives 12V from the start without negotiation??
the limiting factor is often the Amperage, due to the wire and plug resistance.
when using a higher voltage the Amperage limit stays the same. this results in a much higher charge power :yes:
#223 Serveurperso
Serveurperso
  • 3 428 messages
No problem.
This is not a step-up, it's a buck-boost converter
@fire_ned Yes 100% agree
#224 firened
firened
  • 1 783 messages
Posté 18 octobre 2020 - 10:24
:white_smiling_face:
i cannot find any higher voltage usb charger than 20V with 4.3A.
but our limit is the magnetic plug with a maximum of around 2.4A. that yields 48W.
that could work well for 4S or less. I'll probably try this on my next multicell robot.
#225 Serveurperso
Serveurperso
  • 3 428 messages
Posté 18 octobre 2020 - 11:31
A magnet can't go over 1.6A @ 5V because of VDROP "fake self protection" but with more voltage this limitation disapear (and you get instant burn :burn:). Also 1.6A is already out of spec for the 1A pogo on middle, if you run @ 2A + 20V for sure the connector :burn: :burn:
But this can take some time before the spark erode the pogopin @ 40 watts can work but not safe !!!
We must kill some magnet connector to find the maximum usable power before . lol the neodimium magnet are resistive and very subject to oxydation. this is why we add Nickel (Ni-Cu-Ni) coating
This coating is very thin and too mutch power kill it.
if the NiCuNi coating disapear the remaining Nd is very resistive ! contact point make spark and become very hot for sure :burn: !
On magnet cable the maximum of 5V 1.6A = 8W become 9V 3A = 27W this is already very high, but interesting to test, I suggest to not go over 9V for safe use !
Also we must try 12V on the geekworm v3; because the maximum current of the power supply never asked by the geekworm itself.
#226 firened
firened
  • 1 783 messages
Posté 18 octobre 2020 - 01:52
yes 12V sounds interesting.
yeah to reduce heat generation it's best to use higher voltage and lower amperage, because heat generation depends solely on amperage. :yes:
#227 Serveurperso
Serveurperso
  • 3 428 messages
Posté 18 octobre 2020 - 03:07
The Geekworm v3 work perfectly from 5V to 12V now power is no more a problem for vigibot
robot with higher voltage than 5V are easy to get reliable
#228 firened
firened
  • 1 783 messages
Posté 26 octobre 2020 - 10:23
how i get rid of the charge cable lights :lol:
(please note: all exposed metal parts on the cable, adapter and plugs can be under mains voltage, contact can be life threatening!)
#229 beurre6666398
beurre6666398
  • 383 messages
Posté 26 octobre 2020 - 10:39
u r crazy
#230 Serveurperso
Serveurperso
  • 3 428 messages
Posté 26 octobre 2020 - 05:14
PTDR JPP
But why you want to kill the led light ? they cool !
And support high voltage Power Delivery and QC2/3
#231 firened
firened
  • 1 783 messages
Posté 26 octobre 2020 - 05:51
I don't like lights at night when i sleep
#232 Serveurperso
Serveurperso
  • 3 428 messages
Posté 26 octobre 2020 - 05:54
ah yes !!!
#233 Deleted_User
Deleted_User
  • 2 487 messages
Posté 26 octobre 2020 - 06:50
I put a thermal heatsrink around it... It's a safer method lol
#234 firened
firened
  • 1 783 messages
Posté 27 octobre 2020 - 03:28
i plan on using a (up to 15V) pd charger, magnetic cable with data pins, and a pd decoy module to get 15V to a robot to charge 3S.
all 15V pd chargers use type-c. standard usb (type-a) maximum seems to be 12V.
and there is no type-c magnetic cable.
i wonder if i could use a type-c OTG adapter?
like this:
https://a.aliexpress.com/_mqOIheV
https://a.aliexpress.com/_mrvUqbF
https://a.aliexpress.com/_mOuFh2d
#235 firened
firened
  • 1 783 messages
Posté 28 octobre 2020 - 11:23
there are BMS boards with UART for multicell battery monitoring. i wonder how difficult it would be to use them.
https://a.aliexpress.com/_BOZmnS
#236 Deleted_User
Deleted_User
  • 2 487 messages
Posté 29 octobre 2020 - 07:20
Nice !!
#237 beurre6666398
beurre6666398
  • 383 messages
Posté 29 octobre 2020 - 07:33
10x more expensive than standard BMS oO
#238 firened
firened
  • 1 783 messages
Posté 29 octobre 2020 - 08:16
yesyes :D
#239 Serveurperso
Serveurperso
  • 3 428 messages
Posté 16 novembre 2020 - 10:47
https://www.amazon.f...b_sb_ss_sc_2_14
new usb-c magnetic cables with about 80W of power 4.5A
versus all our current max 1.5A
#240 Deleted_User
Deleted_User
  • 2 487 messages
Posté 16 novembre 2020 - 10:52
La vache
Ta pas mis le bon lien..
