speaker-mic
218 réponses à ce sujet
#21 Serveurperso
Serveurperso
  • 3 428 messages
Posté 22 mars 2020 - 04:32
Oui dans l'ancien stock Vinchator y avais quelques rares micro fonctionnels avec un bon gain, la majorité son sourd, et le nouveau stock ne fonctionne plus sous Linux
Sur IMX219 j'ai exactement le même que toi, ancien stock qui fonctionne top
#22 beurre6666398
beurre6666398
  • 383 messages
Posté 17 juin 2020 - 01:32
Nickel le micro orange, reçu ce jour :)
#23 Deleted_User
Deleted_User
  • 2 487 messages
SAUTE
#24 beurre6666398
beurre6666398
  • 383 messages
Posté 17 juin 2020 - 01:33
c'est fait, et maintenant ?
#25 Deleted_User
Deleted_User
  • 2 487 messages
3 pas à droite
#26 firened
firened
  • 1 781 messages
Posté 20 juin 2020 - 10:48
(continuing here) @Pascal
ok yes that makes sense.
anyone tried a speaker without amplifier on the jack plug? how silent is it?
also there are PAM amplifier boards with filter, maybe they could be used on the GPIO audio output pins. (not sure how well this would work...)
#27 Serveurperso
Serveurperso
  • 3 428 messages
Posté 20 juin 2020 - 10:49
yes there is a dedicated channel I forgot lol
speaker without amp is very weak... not interesting for tts
the one I posted is the best
tiny class d amp 3W
#28 firened
firened
  • 1 781 messages
Posté 20 juin 2020 - 03:28
i built an amplified speaker with a 3W PAM module 2 years ago. i had the problem of very loud buzzing as soon as it was plugged in.
it only happened when being powered from the same device as the audio was from.
it was as if the audio input was not AC coupled.
i had to power it from a separate power source.
yours looks like it has some filtering on-board. it should work.
#29 Serveurperso
Serveurperso
  • 3 428 messages
Posté 20 juin 2020 - 03:43
No problem with PAM on jack of any raspberry PI
Just respect 1 ground at PI GND and 5V at PI 5V and no noise problem
#30 firened
firened
  • 1 781 messages
Posté 20 juin 2020 - 03:56
ok perfect :yes:
#31 firened
firened
  • 1 781 messages
Posté 21 juin 2020 - 09:48
ok yes. i remembered it wrong.
the PAM 3W amp works using the same power source as the audio signal is from.
the problem with my PAM speaker is the noise it makes all the time. Microrupteur had the idea that my speaker could be too small.
PAM: 3W amp
speaker: 0.25W
#32 beurre6666398
beurre6666398
  • 383 messages
Posté 21 juin 2020 - 12:35
I have this sort of speaker 3" 3w 4ohm https://weffsas.com/...att-1314-03.jpg
But yes, it's a bit big :)
but good sound and loud
#33 firened
firened
  • 1 781 messages
Posté 22 juin 2020 - 02:15
maybe this product could work too. but instead batteries one could use 2 AAA battery dummies (or just wires) connected to Vbat.
the reviews are pretty bad though...
https://a.aliexpress.com/_BTp1tK
#34 Deleted_User
Deleted_User
  • 2 487 messages
Posté 22 juin 2020 - 02:19
Ouai déjà vu mais pour un robot qui roule ça a trop de poids ..
#35 Deleted_User
Deleted_User
  • 2 487 messages
Posté 25 juin 2020 - 11:57
Hello quel ampli me conseillez vous pour brancher une enceinte dessus avec 2 fils ? Ampli usb ça existe ou sinon ben 5v de la pi mais ça me fais ch...
#36 Mike118
  • 12 509 messages
Posté 25 juin 2020 - 11:58
ça ? https://www.robot-ma...dio-5v-420.html
#37 beurre6666398
beurre6666398
  • 383 messages
Posté 26 juin 2020 - 12:00
+1 marche nikel ce petit ampli, boost a mort :)
faudrai que tu vendes aussi une jack a souder
#38 Mike118
  • 12 509 messages
Oui ... c'est prévu ...
Mais pas en stock pour le moment
j'hésitais en 3 poles et 4 poles d'ailleurs ... Et je pense prendre les 4 poles ...
#39 Deleted_User
Deleted_User
  • 2 487 messages
Posté 26 juin 2020 - 12:05
Un bon vendeur le jojo pas mal
Et un ampli 16v :lol:
Si je met direct sur la batterie quoi
C pour mon gros lardon
#40 beurre6666398
beurre6666398
  • 383 messages
Posté 26 juin 2020 - 12:08
le 5v est nikel
