help questions
10528 réponses à ce sujet
#10521 Mike118
  • 12 857 messages
Posté 01 septembre 2026 - 08:01
You need to refresh the page your browser did not init correctly.
#10522 ximun
ximun
  • 260 messages
Posté 01 septembre 2026 - 09:37
Nope I didn't touched at the server code. Only robot side.
#10523 firened
firened
  • 2 122 messages
Posté 01 septembre 2026 - 18:48
Ok so to recap.
Garfield:
:cross_mark:Brave newest version: lags
:white_heavy_check_mark:Brave old version: ok
Hyper:
:cross_mark:Chrome mobile: lags
:cross_mark:Edge desktop: lags
Firened:
:cross_mark:Brave old version: lags
:white_heavy_check_mark:Chrome mobile: ok
Almost looks like a scissors-stone-paper thing
#10524 Mike118
  • 12 857 messages
Posté 01 septembre 2026 - 19:11
For me : Chrome ok , Microsoft edge issue.
#10525 Mike118
  • 12 857 messages
Posté 03 septembre 2026 - 00:32
Interesting video : and near 23min it mentions H264 encoding and the fact that some browser uses rust and other c++ , I am curious to dig more into this issue ... Because this look like a c memory issue
#10526 wowhik1
wowhik1
  • 176 messages
Posté 19 septembre 2026 - 19:11
Hi everyone! I'm planning to build an FPV rover based on the Wave Rover chassis ( www.waveshare.com/wiki/WAVE_ROVER ). I'll be using a Raspberry Pi 3B as the main host and want to control it via Vigibot.
Could anyone tell me if this platform is compatible with Vigibot? Are there any known issues when connecting the Pi to the onboard ESP32 via UART? Also, how difficult is it to pass the battery voltage readings from the built-in INA219 chip directly to the Vigibot UI? Finally, is this platform worth buying for this type of project, or are there better alternatives out there? Any advice would be greatly appreciated!
@Garfield2142 @Mike118 @fire_ned
#10527 Mike118
  • 12 857 messages
Posté 19 septembre 2026 - 19:34
https://www.robot-ma...cation-example/
This link should help you for this kind of project :)
#10528 wowhik1
wowhik1
  • 176 messages
Posté 19 septembre 2026 - 19:57
Thank you:thank_you:
#10529 firened
firened
  • 2 122 messages
Posté 19 septembre 2026 - 20:20
Hello Hyper. Looks like a fun robot. It should work.
I think if you feed the Waveshare control script and the control examples from /usr/local/vigiclient/opencv/minimal/ into an AI, it would probably combine them and it should work. The battery power voltage should be possible too, I don't know how easy it is.
I would definitely suggest that you check secondhand platforms like eBay if there are products like that. Sometimes they are a lot cheaper because almost nobody buys used robots from other people, so they go for very cheap.
A couple years ago I bought one secondhand, a robot kit, and I paid 150 $. If I had to buy all the parts new, it would have come out around 600 $, so that was very cheap.
Although I have not built the robot and will not build it either in the future, so I put it in my basement. I'm thinking i could send it to you if you want it. It's this one https://www.piborg.o...-1/diddyborg-v2
Doesn't look as off-road capable as your waveshare rover though.
15 utilisateur(s) li(sen)t ce sujet
0 members, 15 guests, 0 anonymous users
