help questions
#10183
Posté 05 août 2025 - 14:02
Vin: 4.5V = 0A charging and
Vin: 5V = 2.1A charging and
(Vin: 5.5V = 3A charging.(?))
The problem is, with the robot running and using ca 1.5A, the Vin is low enough that the IP2312 only charges with 0 - 0.3 A.
I had no other idea than to build a converter, with a PD decoy requesting 9V from the PD2.0 charger then a step-down to
first ca 5.5V = 3A charging, but the magnetic plug gets too hot.
then ca 5.3V = about 0.7 A charging, together with the robot's usage of 1.5A, results in a total Current of 2.2A, which gets the magnetic plug somewhat hot still....
I wish there was a better way, and think using a higher charge voltage like the geekworm v3 (9V or 12V) would be better. @Garfield2142
#10185
Posté 05 août 2025 - 14:19
"CH224K Low-cost USB-PD Sink Controller" <https://components10...-controller-ic>
Must be it!
Then yeah, probably 12V, that should fix the charge speed and magnetic plug temperature
#10187
Posté 05 août 2025 - 17:42
For the new charger and yes it is a CH224A
@Garfield2142 this is the issue when charging :
05/08 18:59:17:257 | | Client | Reception of a text frame
05/08 18:59:17:282 | | Client | Reception of a text frame
05/08 18:59:17:316 | | Client | Reception of a text frame
05/08 18:59:17:349 | | Client | Reception of a text frame
05/08 18:59:17:382 | | Client | Reception of a text frame
05/08 18:59:17:740 | | Client | The eSpeak process is stopped after 487 milliseconds with the exit code 0
05/08 18:59:34:851 | | Client | Error: EIO, Input/output error
05/08 18:59:34:860 | | Client | at Bus.writeI2cBlockSync (/usr/local/vigiclient/node_modules/i2c-bus/i2c-bus.js:523:9)
05/08 18:59:34:860 | | Client | at Ina219.writeRegister (/usr/local/vigiclient/node_modules/ina219/ina219.js:159:12)
05/08 18:59:34:860 | | Client | at /usr/local/vigiclient/node_modules/ina219/ina219.js:374:9
05/08 18:59:34:860 | | Client | at Ina219.writeRegister (/usr/local/vigiclient/node_modules/ina219/ina219.js:160:2)
05/08 18:59:34:860 | | Client | at Ina219.calibrate32V2A (/usr/local/vigiclient/node_modules/ina219/ina219.js:364:7)
05/08 18:59:34:861 | | Client | at Timeout._onTimeout (/usr/local/vigiclient/clientrobotpi.js:1128:11)
05/08 18:59:34:861 | | Client | at ontimeout (timers.js:436:11)
05/08 18:59:34:861 | | Client | at tryOnTimeout (timers.js:300:5)
05/08 18:59:34:861 | | Client | at listOnTimeout (timers.js:263:5)
05/08 18:59:34:861 | | Client | at Timer.processTimers (timers.js:223:10)
05/08 18:59:34:861 | | Client | Following this uncaught exception, the Node.js process will be terminated automatically
05/08 18:59:35:932 | | Déconnexion du robot Socket.IO TbWmNPXVzKu5OoHIAkA1
#10191
Posté 05 août 2025 - 19:31
#10192
Posté 05 août 2025 - 21:10
#10193
Posté 05 août 2025 - 23:06
This is the charge crash problem. But I still have no clue about the second kind of crash yet. Do you tested without your BMS ?
#10194
Posté 05 août 2025 - 23:43
#10197
Posté 06 août 2025 - 14:01
#10198
Posté 06 août 2025 - 15:06
Alright, it definitely behaves differently now. If I push it strong enough and at low enough voltage, I can shut off the entire UPS and I have to switch off and back on, but I guess I'm pushing it past what's normal now. I'll plug the battery back in, and stress test climbing some slopes
Unfortunately, setting VUSB to 9V made no difference to fast charging, the client still crashes.
#10200
Posté 06 août 2025 - 19:52
What battery are you using ? You have a second robot. Does it have the same motors? Can you crash it the same way ? Can you switch some hardware between both ?
