help questions
#10263
Posté 12 novembre 2025 - 17:05
Or perhaps ask around in your friend- and relative-circles. At least here in Switzerland i think many people might have old rc cars they no longer need.
Also remember that there's no rush. Electronics is often not about reaching an end goal at all, but more about the journey, learning, soldering, breaking things and making mistakes.
#10265
Posté 12 novembre 2025 - 19:26
I am working on "industrialisation" to make them easier to build and solving issues ...
Nerf vigibot
#10267
Posté 12 novembre 2025 - 20:26
#10269
Posté 12 novembre 2025 - 20:27
#10274
Posté 12 novembre 2025 - 20:42
#10277
Posté 12 novembre 2025 - 21:48
How many wires are in the cable?
Can you measure if any of the wires for the button have a voltage? How much?
Ok.
2.4V ok. The positive is probably connected to an input of an IC with a pull-up resistor to either 3.3V or Vbat. Because your DMM has a resistance too, it can lower the reading.
If you touch the wires together it beeps, correct?
On the wires you measured the voltage between GND and the positive wire.
Now, Can you measure the voltage between the positive wire and Vbat? It will tell us whether the positive wire is connected to Vbat (reads about 0.5V) or 3.3V (reads 0.0V).
it's a little trick, i hope it works
If it's 3.3V you can connect it to the Pi without damaging the Pi.
If it's Vbat then you will need a transitor (BJT, FET) or relais.
I gotta sleep now.
#10279
Posté 18 novembre 2025 - 14:18
Vcc to 3.3V.
Do you already know how to use the INA power pins V+ and V-?
Oh no wait
The INA measures current so all the current has to go through it. There's a low Ohm "shunt resistor" on it, over which it can measure the small voltage drop and with it the current.
So the INA V+, V- have to go inline with the load like this:
(Later some vigi website config changes are required.)
#10280
Posté 19 novembre 2025 - 08:40
Find the correct spot and insert
"NAME": "Current",
"INIT": 0,
"SCALEMIN": -3,
"SCALEMAX": 3,
"MIN": -3,
"MAX": 3,
"SIGNED": true,
"NBDIGITS": 3,
"UNIT": " A"
Make sure the comma `,` is there too.
4 utilisateur(s) li(sen)t ce sujet
0 members, 4 guests, 0 anonymous users
