help questions
#10202
Posté 06 août 2025 - 20:14
Can you switch them easily ?
#10204
Posté 06 août 2025 - 20:18
#10205
Posté 06 août 2025 - 21:53
#10206
Posté 06 août 2025 - 22:50
One of the three module should be the issue... you already shorted the ina resistor. I think it was the biggest issue...
I think that now you shorted the ina resistor you might just manage to pull too much current fot the battery protection...
this is the battery protection on the robot
I forget to mention that VBAT also go through BQ25792RQMR before being VBAT OUT... It might be the second one causing limitations.
#10207
Posté 09 août 2025 - 21:33
#10208
Posté 09 août 2025 - 23:56
@Garfield2142
#10209
Posté 10 août 2025 - 09:25
-Turned on i2c in raspi-config
-Robot started bootlooping (Camera clicking and lights turning on and off every few seconds).
-Unplugged every servo and camera
-Still bootlooping
-Took raspi out of the UPS and powered it directly from USB
-Plugged in HDMI
-Completely dead, no signal...
-Insert new SD card with brand new fresh image, reset my Panther HW and remote control config to factory settings.
-Plugged raspi into UPS and HDMI monitor.
-Raspi works, and stops at exactly the same part in booting, then restarts, repeat forever.
-Took raspi out of the UPS, powered only with USB.
-Boots completely fine
Here's my raspi 3B+ bootlooping while plugged into the vigiUPS
And here's the exact same raspi 3B+ without the UPS, booting normally
After a successful boot without the UPS, I plug the pi back into the UPS, the same bootloop happens, so it's not a "first boot setup" sequence
#10210
Posté 10 août 2025 - 11:29
-Sudo update, sudo upgrade, raspi now bootloops faster
-Changed ina219 address in sys.json to 68 to avoid detection, no difference.
-Disabled i2c in raspi-config, no difference
Swapped out the raspi 3B+ (Panther) to raspi4 (Pluto), same thing, can't boot.
#10214
Posté 10 août 2025 - 14:19
Yup, it came back. I could've saved myself a few hours if I just checked the battery voltage first
But at least I found out that the UPS will still allow the pi to boot halfway through, even if there is not enough charge to finish booting.
It was just really strange that it always failed at the exact same part. Maybe that's when something really demanding would've happened, increasing current, and that's when the step-up gave up.
#10216
Posté 10 août 2025 - 19:13
#10217
Posté 10 août 2025 - 19:18
I might not even need this tumor anymore, I think there's plenty of room to mount the on/off switch and the magnet should stick out enough
#10218
Posté 10 août 2025 - 20:12
#10219
Posté 10 août 2025 - 20:48
Tried all sorts of cables, both magnetic and "normal" usb C cables.
So this explains why my battery was empty by the morning.
Using the built-in USB-C port, with a 67W charger (setUSB bridges are not set), I get -0.7A (discharging)
It just literally crashed the client again with the 67W charger, now I don't have ina219 again
#10220
Posté 10 août 2025 - 21:00
4 utilisateur(s) li(sen)t ce sujet
0 members, 4 guests, 0 anonymous users
