help questions
#10882
Posté 13 février 2026 - 13:45
I followed the guide on GitHub and mounted the LEDs to the camera using metal screws and nuts.
When I measured the voltage on them, it showed 3.3V, but nothing is lighting up.
Am I doing something wrong? Is there something else I need to connect?
#10883
Posté 13 février 2026 - 13:59
I suggest to leave them as they are. as infrared lights.
If you want, it's possible to do modifications, but it will add another point of failure. Specifically, the wire will be bent when looking around with the camera and the cable will fail with time. But the options would be:
1) wire the IR LEDs to a gpio to gain software control <https://www.robot-ma...-ir-via-gpio/>. use a zip tie base to mechanically relieve the solder joint from mechanical forces.
2) replace the IR LED with a white LED <https://www.robot-ma...leds-blanches/>
3) or buy a white LED PCB, not sure if they are still available.
I'd suggest to lower the brightness to the minimum as more will make them get quite hot
#10884
Posté 13 février 2026 - 18:18
#10888
Posté 21 février 2026 - 17:51
If you can use a raspberry pi to control your car you can update the open-source vigibot client to run your car with vigibot @Rigby Cat
#10890
Posté 02 mars 2026 - 19:29
" (Any angular defect less than one notch of the servomotor shaft position can be corrected later on the site.) "
With which value can this offset be correctet? Is this the backslash value?
#10893
Posté 03 mars 2026 - 00:06
@Ralph
#10894
Posté 03 mars 2026 - 15:56
COMMANDS16[2 = "Gripper X"] -> MIN from "-30" to "-42". What would you recommend to solve the issue? I'm happy to try whatever you suggest.
#10896
Posté 08 mars 2026 - 01:12
@jose luu can you set me as friend on your robot ?
#10898
Posté 08 mars 2026 - 01:15
I can help you set the config if I understand what you need / what hardware is used
#10900
Posté 08 mars 2026 - 01:16
What pi gpio are used for l298 ?
7 utilisateur(s) li(sen)t ce sujet
0 members, 7 guests, 0 anonymous users
