help questions
11000 réponses à ce sujet
#10881 firened
firened
  • 2 124 messages
Posté 11 février 2026 - 15:34
Follow the wires, check the flight controller pinout to see which pins it's plugged in
#10882 neartmy
neartmy
  • 4 messages
Posté 13 février 2026 - 13:45
How to connect the lights to MinusBot?
I followed the guide on GitHub and mounted the LEDs to the camera using metal screws and nuts.
When I measured the voltage on them, it showed 3.3V, but nothing is lighting up.
Am I doing something wrong? Is there something else I need to connect?
#10883 firened
firened
  • 2 124 messages
Posté 13 février 2026 - 13:59
Those are infrared lights and they have a illumination sensor and turn on automatically when it's dark. You can see IR with a camera.
I suggest to leave them as they are. as infrared lights.
If you want, it's possible to do modifications, but it will add another point of failure. Specifically, the wire will be bent when looking around with the camera and the cable will fail with time. But the options would be:
1) wire the IR LEDs to a gpio to gain software control <https://www.robot-ma...-ir-via-gpio/>. use a zip tie base to mechanically relieve the solder joint from mechanical forces.
2) replace the IR LED with a white LED <https://www.robot-ma...leds-blanches/>
3) or buy a white LED PCB, not sure if they are still available.
I'd suggest to lower the brightness to the minimum as more will make them get quite hot
#10884 Mike118
  • 12 871 messages
Posté 13 février 2026 - 18:18
About 3) they will be available soon. White led and IR led versions.
#10885 robobobob_
robobobob_
  • 19 messages
Posté 21 février 2026 - 07:28
ok question about making a robot, i have an android phone and a bluetooth rc car that supports the weight of my phone and i want people to control my car while it moves around outside. do you guys think that would be possible?
peak
#10886 wowhik1
wowhik1
  • 177 messages
Posté 21 février 2026 - 07:56
Possibly, but it's not very convenient. Technically, your machine cannot be on Vigibot.
#10887 robobobob_
robobobob_
  • 19 messages
Posté 21 février 2026 - 07:57
dang i gotta make a whole different type of website to make this project a thing ill let you guys play with it when i finish
#10888 Mike118
  • 12 871 messages
Posté 21 février 2026 - 17:51
Vigibot robots are raspberry pi robots running the opensource vigibot client connected to the vigibot server @Rigby Cat
If you can use a raspberry pi to control your car you can update the open-source vigibot client to run your car with vigibot @Rigby Cat
#10889 wowhik1
wowhik1
  • 177 messages
Posté 21 février 2026 - 17:55
He probably doesn't have a Raspberry Pi, just like me:beaming_face:
#10890 ralph_62550
ralph_62550
  • 11 messages
Posté 02 mars 2026 - 19:29
On https://www.robot-ma...ipper-assembly/ I find this sentence about the servos:
" (Any angular defect less than one notch of the servomotor shaft position can be corrected later on the site.) "
With which value can this offset be correctet? Is this the backslash value?
#10891 firened
firened
  • 2 124 messages
Posté 02 mars 2026 - 19:41
You can offset it by adding or subtracting the same value from the 3 entries `init, min, max` :yes:
In RC-config (wrench icon)
#10892 ralph_62550
ralph_62550
  • 11 messages
Posté 02 mars 2026 - 20:28
Maybe something for the FAQ on the Github Botkins Documentation?
#10893 Mike118
  • 12 871 messages
Posté 03 mars 2026 - 00:06
Depending of what issue is needed to be solved you can also configure it in the hardware config. And most ofvthe time this is the first place to look for modifications.
@Ralph
#10894 ralph_62550
ralph_62550
  • 11 messages
Posté 03 mars 2026 - 15:56
The issue I tried to solve: there was a gap between the gripper fingers. I solved it by changing in the remote controller configuration
COMMANDS16[2 = "Gripper X"] -> MIN from "-30" to "-42". What would you recommend to solve the issue? I'm happy to try whatever you suggest.
#10895 jose_luu
jose_luu
  • 30 messages
Posté 08 mars 2026 - 01:09
Hi all, my bot does not seem to receive COMMAND8 for forward or backard motion I inserted traces in the code on the receiving side. There may be some configuration on ther server side that I am missing.
#10896 Mike118
  • 12 871 messages
Posté 08 mars 2026 - 01:12
What is the robot name
@jose luu can you set me as friend on your robot ?
#10897 jose_luu
jose_luu
  • 30 messages
Posté 08 mars 2026 - 01:13
Satoshicam
done friend
#10898 Mike118
  • 12 871 messages
Posté 08 mars 2026 - 01:15
Ok so what kind of robot is it ?
I can help you set the config if I understand what you need / what hardware is used
#10899 jose_luu
jose_luu
  • 30 messages
Posté 08 mars 2026 - 01:16
Standard vigibot kit with VIgiboard v1.1, L298N H bridege
#10900 Mike118
  • 12 871 messages
Ok
What pi gpio are used for l298 ?
5 utilisateur(s) li(sen)t ce sujet
0 members, 5 guests, 0 anonymous users
