help questions
10528 réponses à ce sujet
#481 Deleted_User
Deleted_User
  • 4 242 messages
Posté 13 janvier 2020 - 11:17
Good and Can I use x3 of them ?
It is a common ground ?
#482 Mike118
  • 12 858 messages
But I don't recommend MAX17043 with voltage divider on a 3S battery ...
#483 Deleted_User
Deleted_User
  • 4 242 messages
No but one per cell
(If the ground is not common...)
On the battery port
#484 Mike118
  • 12 858 messages
Posté 13 janvier 2020 - 11:20
The problem will be with I2C ... If the chips you use don't have common gnd you need to make a proper insulation between I2C lines ... using optoelectronics or thing like that.
#485 Deleted_User
Deleted_User
  • 4 242 messages
Posté 13 janvier 2020 - 11:21
Ok it's too complicated. I this I will take 1 and measure only the first cell...
on 3S
It's just to have an fuel info, the BMS will protect anyway
#486 Mike118
  • 12 858 messages
Posté 13 janvier 2020 - 11:22
This way it will work yes.
#487 Deleted_User
Deleted_User
  • 4 242 messages
Posté 13 janvier 2020 - 11:24
:yes:
#488 firened
firened
  • 2 122 messages
Posté 13 janvier 2020 - 11:41
the voltage divider across all cells isn't perfect because it drains some current at all times. do you have a better alternative @Mike118 apart from measuring only the first cell?
#489 Serveurperso
Serveurperso
  • 5 097 messages
Posté 13 janvier 2020 - 12:17
you just need a basic ADC to measure any type of multi cell battery
we need a basic i2c ADC support o'and vigibot
*on
#490 Mike118
  • 12 858 messages
Posté 13 janvier 2020 - 12:28
With High resistors value the current drains will be very very low... And even when you measure only the first sell there is a little drain on this cell ...
instead of using a standard 3S battery the best is to set up your own pack and use BMS protecting each cells independently ...
#491 Serveurperso
Serveurperso
  • 5 097 messages
Posté 13 janvier 2020 - 12:51
BMS with equilibrium circuitry are mandatory (cheap)
#492 firened
firened
  • 2 122 messages
Posté 13 janvier 2020 - 12:52
the MAX17043 can be used as a basic ADC as far as i know. the fuel gauge percentage feature is optional.
#493 Serveurperso
Serveurperso
  • 5 097 messages
equalized charge are mandatory, but not needed in discharge
#494 firened
firened
  • 2 122 messages
Posté 13 janvier 2020 - 12:53
yes my battery is protected and balanced :yes:
but I would like to see the voltage on vigibot and make the raspberry shutdown on low voltage
#495 Serveurperso
Serveurperso
  • 5 097 messages
a lithium management as ADC is a bit crap
an real adc is better
we must add an ADC support on the raspberry pi client
#496 _lartishow
_lartishow
  • 142 messages
Posté 14 janvier 2020 - 21:39
Other little question,
On which pin can I plug my turret?
#497 firened
firened
  • 2 122 messages
Posté 14 janvier 2020 - 23:04
camera pan and tilt servo are GPIO 5 and 6.
gripper servo are GPIO 7 and 8.
got it from here: :ok:
https://www.robot-ma...bot-on-vigibot/
#498 _lartishow
_lartishow
  • 142 messages
Posté 14 janvier 2020 - 23:29
:ok:
#499 Mike118
  • 12 858 messages
Posté 15 janvier 2020 - 06:18
This is default config for now. :) (But all can be configured =))
#500 _lartishow
_lartishow
  • 142 messages
Posté 15 janvier 2020 - 21:05
Thanks!
How did you manage ground of both servo?
12 utilisateur(s) li(sen)t ce sujet
0 members, 12 guests, 0 anonymous users
