help questions
10528 réponses à ce sujet
#461 Mike118
  • 12 858 messages
Posté 09 janvier 2020 - 15:06
@Deleted User if you have your smartphone you can just press the " exit door bouton " on vigibot then cut the power supply... A new thing will be add someday with a confirmation to completely shut down a robot ... But if you do so you " kill the robot" ... Impossible to wake it up after shutdown while being distant ...
#462 Deleted_User
Deleted_User
  • 4 242 messages
Posté 09 janvier 2020 - 15:07
It's a reboot not a shutdown ?
#463 Mike118
  • 12 858 messages
Posté 09 janvier 2020 - 15:10
yes it is reboot.
this is why you should manually disconnect power supply right after making the reboot.
#464 Deleted_User
Deleted_User
  • 4 242 messages
Posté 09 janvier 2020 - 15:33
:ok:
#465 Serveurperso
Serveurperso
  • 5 097 messages
Posté 09 janvier 2020 - 21:49
Outch it's dangerous a reboot disconnect !!!!
It's more dangerous to kill a startup than a normal use !
Way more dangerous
I need to add a shutdown but it need confirmation because we have far away robots
#466 Deleted_User
Deleted_User
  • 4 242 messages
Posté 09 janvier 2020 - 21:58
@Pascal yes please
I need this button....
#467 Mike118
  • 12 858 messages
Posté 09 janvier 2020 - 22:00
else you can try this : https://www.quartokn...shutdown-button
It should work if you use a pin not used by our client.
But I did not tried this.
@Deleted User you can try it :)
#468 Deleted_User
Deleted_User
  • 4 242 messages
Posté 09 janvier 2020 - 22:03
I will have a look thanks
Pas mal.
J'y comprends pas grand chose mais je vais essayer d'approfondir
Lardon teste si ça marche tu me le fait a distance :lol:
c neuneu 2 fils pin 21 et GND un bouton un code python degeulasse et fouac
en bash c large faisable
https://fr.aliexpres...rchweb201603_53
C'est le code le problème pour moi
Jamais fait sur raspberry
ben c du python quoi
#469 Mike118
  • 12 858 messages
Posté 09 janvier 2020 - 22:12
il est fourni sur le lien :)
#470 Snyp54
Snyp54
  • 416 messages
Posté 09 janvier 2020 - 22:37
Il n'y a que ce qui font rien qui ne font pas de bêtise.
#471 Deleted_User
Deleted_User
  • 4 242 messages
Posté 09 janvier 2020 - 23:09
#472 _lartishow
_lartishow
  • 142 messages
Posté 12 janvier 2020 - 21:53
Bonsoir
petite question
les infra rouges de ma caméra chauffe beaucoup,
c'est normal?
#473 Deleted_User
Deleted_User
  • 4 242 messages
Posté 12 janvier 2020 - 22:09
Il faut régler le potard !
C'est toi le potard !
#474 _lartishow
_lartishow
  • 142 messages
Posté 12 janvier 2020 - 22:32
Merci pour l'info, je vais regarder ca. Comment savoit quand ils sont bien réglés?
#475 Mike118
  • 12 858 messages
Posté 13 janvier 2020 - 00:27
Le top c'est de les régler à la limite. Que genre si tu tourne un peu plus la led s'éteint et si tu tourne un peu moins tu vois que visuellement les led éclaire un chouilla plus ...
#476 firened
firened
  • 2 122 messages
Posté 13 janvier 2020 - 10:40
@Pascal
i saw radiobot has a voltage range of 12V to 16.8V. did you use a voltage divider and a MAX17043 fuel gauge there? (because the maximum voltage for MAX17043 is less than 5V)
#477 Mike118
  • 12 858 messages
Posté 13 janvier 2020 - 10:52
No there is an arduino like board performing analog reading with a resistor voltage divider
#478 firened
firened
  • 2 122 messages
Posté 13 janvier 2020 - 11:14
ah okay.
i will use the MAX17043 with a voltage divider. that should work too
#479 Deleted_User
Deleted_User
  • 4 242 messages
Posté 13 janvier 2020 - 11:16
MAX17043 is compatible with the PI without arduino ?
#480 Mike118
  • 12 858 messages
Yes
11 utilisateur(s) li(sen)t ce sujet
0 members, 11 guests, 0 anonymous users
