help questions
10528 réponses à ce sujet
#10401 kamonmark
kamonmark
  • 9 messages
Posté 21 janvier 2026 - 09:46
Mission (mostly) successful!
I've got a few firmware changes I need to make, but I've got everything moving and streaming. This platform and you all are great! Thank you for the help ane encouragment.
#10402 firened
firened
  • 2 122 messages
Posté 21 janvier 2026 - 10:14
So cool. Do you have pictures of your bot? Always cool to see new robots :beaming_face:
#10403 kamonmark
kamonmark
  • 9 messages
Posté 22 janvier 2026 - 04:04
I put one in #:robot:|bots , I'll be posting some more soon
#10404 french_storm972
french_storm972
  • 60 messages
Posté 05 février 2026 - 10:32
I have a problem with my remote control radio; it turns on and then off. Could you help me?
@Mike118@fire_ned
#10405 garfield2142
garfield2142
  • 379 messages
Posté 05 février 2026 - 10:45
It could be low on battery
#10406 french_storm972
french_storm972
  • 60 messages
Posté 05 février 2026 - 11:00
I charged all night.
I'm going to test another charger
is workkkkkk
#10407 french_storm972
french_storm972
  • 60 messages
Posté 11 février 2026 - 12:09
3 questions 1 Why is the camera reception strange?
2. Why isn't the gimbal resetting?
3. I can't move the GoPro
@fire_ned @Mike118
#10408 firened
firened
  • 2 122 messages
Posté 11 février 2026 - 14:21
Hi
Not sure.
1: looks similar to using the wrong VRX channel.
2 & 3: i don't know. How will you control the gimbal? Do you have that many TX channels?
#10409 french_storm972
french_storm972
  • 60 messages
Posté 11 février 2026 - 14:26
I think
#10410 firened
firened
  • 2 122 messages
Posté 11 février 2026 - 14:28
Check how and to what channels the gopro is connected, maybe it'll help
#10411 french_storm972
french_storm972
  • 60 messages
Posté 11 février 2026 - 14:33
how
#10412 firened
firened
  • 2 122 messages
Posté 11 février 2026 - 15:34
Follow the wires, check the flight controller pinout to see which pins it's plugged in
#10413 neartmy
neartmy
  • 4 messages
Posté 13 février 2026 - 13:45
How to connect the lights to MinusBot?
I followed the guide on GitHub and mounted the LEDs to the camera using metal screws and nuts.
When I measured the voltage on them, it showed 3.3V, but nothing is lighting up.
Am I doing something wrong? Is there something else I need to connect?
#10414 firened
firened
  • 2 122 messages
Posté 13 février 2026 - 13:59
Those are infrared lights and they have a illumination sensor and turn on automatically when it's dark. You can see IR with a camera.
I suggest to leave them as they are. as infrared lights.
If you want, it's possible to do modifications, but it will add another point of failure. Specifically, the wire will be bent when looking around with the camera and the cable will fail with time. But the options would be:
1) wire the IR LEDs to a gpio to gain software control <https://www.robot-ma...-ir-via-gpio/>. use a zip tie base to mechanically relieve the solder joint from mechanical forces.
2) replace the IR LED with a white LED <https://www.robot-ma...leds-blanches/>
3) or buy a white LED PCB, not sure if they are still available.
I'd suggest to lower the brightness to the minimum as more will make them get quite hot
#10415 Mike118
  • 12 857 messages
Posté 13 février 2026 - 18:18
About 3) they will be available soon. White led and IR led versions.
#10416 robobobob_
robobobob_
  • 19 messages
Posté 21 février 2026 - 07:28
ok question about making a robot, i have an android phone and a bluetooth rc car that supports the weight of my phone and i want people to control my car while it moves around outside. do you guys think that would be possible?
peak
#10417 wowhik1
wowhik1
  • 176 messages
Posté 21 février 2026 - 07:56
Possibly, but it's not very convenient. Technically, your machine cannot be on Vigibot.
#10418 robobobob_
robobobob_
  • 19 messages
Posté 21 février 2026 - 07:57
dang i gotta make a whole different type of website to make this project a thing ill let you guys play with it when i finish
#10419 Mike118
  • 12 857 messages
Posté 21 février 2026 - 17:51
Vigibot robots are raspberry pi robots running the opensource vigibot client connected to the vigibot server @Rigby Cat
If you can use a raspberry pi to control your car you can update the open-source vigibot client to run your car with vigibot @Rigby Cat
#10420 wowhik1
wowhik1
  • 176 messages
Posté 21 février 2026 - 17:55
He probably doesn't have a Raspberry Pi, just like me:beaming_face:
4 utilisateur(s) li(sen)t ce sujet
0 members, 4 guests, 0 anonymous users
