help questions
10528 réponses à ce sujet
#10361 firened
firened
  • 2 122 messages
Posté 23 décembre 2025 - 08:48
Chrome, edge, opera and brave work best as they're chromium based :yes:
#10362 Mike118
  • 12 857 messages
Posté 23 décembre 2025 - 09:12
This is not the issue ... but right now I don't understand why you have an issue.
And yes the disturbing fact is that framebuffer doesn't work either... this is why I think this is not a camera issue.
#10363 wowhik1
wowhik1
  • 176 messages
Posté 23 décembre 2025 - 10:05
:clapping:
#10364 flipthechillet
flipthechillet
  • 33 messages
Posté 23 décembre 2025 - 10:51
I wonder what the problem could be then:huh:
#10365 wowhik1
wowhik1
  • 176 messages
Posté 23 décembre 2025 - 11:20
@QuantumFlip The Chillet
From the logs, I see that Vigibot is explicitly trying to use the Legacy OpenMAX stack (-c: v h264_omx in the ffmpeg arguments defined in sys.json).
Even if Vigibot provides a legacy OS image, the fact that the process starts and immediately crashes indicates that the h264_omx encoder is not initializing correctly. This often happens if the vc4-kms -v3d driver is active in /boot/ config. txt, which conflicts with the legacy stack. This would explain both failures:
1. The camera fails because omx cannot access the GPU.
2. The framebuffer (/dev/fb0) fails because the KMS driver takes over the display output.
The fix likely involves checking /boot/ config.txt to ensure the legacy camera stack is enabled and KMS is configured correctly (or disabled), OR modifying sys. json to use a different encoder (like h264_v412m2m or libx264) if the hardware supports it.
#10366 flipthechillet
flipthechillet
  • 33 messages
Posté 23 décembre 2025 - 11:23
So how do I fix it as I am not very good at coding.
#10367 wowhik1
wowhik1
  • 176 messages
Posté 23 décembre 2025 - 14:09
I don't know how else to say it, ask
@fire_ned @Mike118 @Garfield2142
#10368 firened
firened
  • 2 122 messages
Posté 23 décembre 2025 - 16:23
@QuantumFlip The Chillet thank you for answering question 4.
What do you think about the other questions and the possibile steps i wrote?
Would you be able to answer and do those?
I wish i could help more, but i need more info, else it's getting difficult to help.
Thank you for asking ChatGPT for us ;)
vc4-fkms-v3d is enabled on IcecreamTruck too, it shouldn't be a problem :)
#10369 wowhik1
wowhik1
  • 176 messages
Posté 23 décembre 2025 - 16:33
Not exactly ChatGPT - I use a local neural network, GPT-OSS 20B. It's really good:blush:
I think I've already said that I have a close connection with AI
I think AI will soon communicate instead of me, that would be cool :clapping::clapping::clapping:
#10370 firened
firened
  • 2 122 messages
Posté 28 décembre 2025 - 17:57
@Garfield2142 aye, here
#10371 wowhik1
wowhik1
  • 176 messages
Posté 29 décembre 2025 - 15:45
My logic: buy Red Dead Redemption 2 :white_heavy_check_mark:
Save up for a Raspberry Pi 3B+ or a Pi Zero 2 :cross_mark:
:saluting_face::saluting_face::saluting_face:
#10372 flipthechillet
flipthechillet
  • 33 messages
Posté 05 janvier 2026 - 08:27
Hello again, I recently got a motor control controller to go with my raspberry pi but I don't know how to set it up properly. I've got all the connections done. I just need to know how to get it to work.
#10373 firened
firened
  • 2 122 messages
Posté 05 janvier 2026 - 08:39
Yeah B)
What type? Link?
#10374 flipthechillet
flipthechillet
  • 33 messages
Posté 05 janvier 2026 - 08:51
It's the L298N Dual Motor Module For Arduino but it should still work with the raspberry pi 4b.
#10375 Mike118
  • 12 857 messages
Posté 05 janvier 2026 - 09:16
Hello, yes l298 works well. You need to check this tutorial to know how to configure on vigibot. https://www.robot-ma...elays-and-leds/
You set the l298n driver with two wires per motor = pwmpwm type.
If you need help, I can configure it for you. You just need to add me in your friend list on the robot. My pseudo on vigibot is Mike118
#10376 flipthechillet
flipthechillet
  • 33 messages
Posté 05 janvier 2026 - 09:22
Yes please that would be great.
#10377 Mike118
  • 12 857 messages
Posté 05 janvier 2026 - 09:25
Ok, what gpio do you used for right motor ? And what gpio for left motor ?
#10378 flipthechillet
flipthechillet
  • 33 messages
Posté 05 janvier 2026 - 09:32
The right motor is attached to outputs one and two on the controller. The left motor is attached to outputs three and four. input one on the controller is attached to pin 11 on the pi input two is attached to pin 13 on the pi input three is attached to pin 15 on the pi and input four is attached to pin 16 on the pi
#10379 wowhik1
wowhik1
  • 176 messages
Posté 05 janvier 2026 - 09:49
#10380 Mike118
  • 12 857 messages
Posté 05 janvier 2026 - 09:57
I updated the config but I since the camera is not working I don't know if it is working well.
Can you test ?
5 utilisateur(s) li(sen)t ce sujet
0 members, 5 guests, 0 anonymous users
