help questions
#10343
Posté 22 décembre 2025 - 14:32
#10346
Posté 22 décembre 2025 - 14:42
then you can login with pi / raspberry
then you can type this commande to check if h264 is available : sudo v4l2-ctl --list-formats-ext -d /dev/video0
#10348
Posté 22 décembre 2025 - 14:46
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YU12' (Planar YUV 4:2:0)
Size: Stepwise 32x32 - 2592x1944 with step 2/2
[1]: 'YUYV' (YUYV 4:2:2)
[2]: 'RGB3' (24-bit RGB 8-8-8)
[3]: 'JPEG' (JFIF JPEG, compressed)
[4]: 'H264' (H.264, compressed)
[5]: 'MJPG' (Motion-JPEG, compressed)
[6]: 'YVYU' (YVYU 4:2:2)
[7]: 'VYUY' (VYUY 4:2:2)
[8]: 'UYVY' (UYVY 4:2:2)
[9]: 'NV12' (Y/CbCr 4:2:0)
[10]: 'BGR3' (24-bit BGR 8-8-8)
[11]: 'YV12' (Planar YVU 4:2:0)
[12]: 'NV21' (Y/CrCb 4:2:0)
[13]: 'RX24' (32-bit XBGR 8-8-8-8)
#10350
Posté 22 décembre 2025 - 14:51
#10352
Posté 22 décembre 2025 - 14:59
sudo nano /usr/local/vigiclient/sys.json
Can you try to add the following lines below the line "CMDDIFFUSION": [
"/usr/bin/v4l2-ctl",
" -d /dev/video0",
" --set-fmt-video=width=WIDTH,height=HEIGHT,pixelformat=H264",
" --set-parm=FPS",
" --set-ctrl=video_bitrate=BITRATE,h264_profile=0,repeat_sequence_header=1",
" && /usr/local/vigiclient/processdiffusion /dev/video0",
" | /bin/nc 127.0.0.1 VIDEOLOCALPORT",
" -w 2"
#10353
Posté 22 décembre 2025 - 15:09
The camera is so cheap, it could certainly be broken or not supported. $ 3
https://a.aliexpress.com/_EJGtE72
@QuantumFlip The Chillet You wouldn't have an original camera or the one from the Vigibot partlist?
#10359
Posté 23 décembre 2025 - 08:34
So to recap, there are multiple questions, and i do not know the best way forward yet:
- camera is detected but doesn't work on Vigibot.
- framebuffer doesn't work. Why doesn't this work.. Why are we expecting the camera to work if not even the framebuffer works.. -> we're missing something even more basic here. But what
Q1) Do you use the vigimage.img or the manual install script?
Q2) did you let it undisturbed for ~ 15 min on first boot until it showed up by itself?
Q3) where does this antenna-looking thing connect to? Did you solder it yourself? (Shouldn't have any effect on the problem though). Did you make any other hardware changes?
Q4) what browser are you using?
Possible steps:
1) SSH access would be handy, there are multiple commands that can help us here and typing them in manually can be tedious for you. Here's a guide (ssh is already enabled) https://sslinsights....o-raspberry-pi/
2) take a picture manually with the command above.
3) create a new robot on Vigibot to make sure you're starting with the default config.
5 utilisateur(s) li(sen)t ce sujet
0 members, 5 guests, 0 anonymous users
