help questions
#10325
Posté 22 décembre 2025 - 13:42
I too think the next step would be to acces to the command line using (1) a keyboard, and either hdmi monitor or framebuffer view on Vigibot, or (2) over ssh
Maybe I'm mixing up something, I'm not sure
SSH would be great, it'll help later on as well, if you need to modify something.
#10328
Posté 22 décembre 2025 - 13:47
Off-topic: my phone charging cable got damaged, and now charging goes more like a minus than a plus, and the new Type-C to Type-C cable won't arrive for another 2 weeks
I'm already stuck to the charger anyway because my battery has low capacity, so I charge my phone about 4 times a day.
#10330
Posté 22 décembre 2025 - 14:10
the server use the video feedback to check the latency but since there is no camera it says "no time correction".
#10332
Posté 22 décembre 2025 - 14:12
hum strange ...
can you add me as friend on your robot ?
#10334
Posté 22 décembre 2025 - 14:14
#10336
Posté 22 décembre 2025 - 14:16
#10338
Posté 22 décembre 2025 - 14:20
but it seems not working on your robot ...
I am trying to check what's happening
#10340
Posté 22 décembre 2025 - 14:24
22/12 14:19:20:916 | | Client | Starting the process v4l2-ctl
22/12 14:19:20:919 | | Client | /usr/bin/v4l2-ctl -v width=640,height=480,pixelformat=4 -p 30 -c h264_profile=0,repeat_sequence_header=1,rotate=0,video_bitrate=1500000,brightness=50,contrast=-5
22/12 14:19:20:926 | | Client | v4l2-ctl | 1517 | stdout | Frame rate set to 30.000 fps
22/12 14:19:20:926 | | Client | The v4l2-ctl process is stopped after 10 milliseconds with the exit code 0
22/12 14:19:20:942 | | Client | Starting the H.264 video broadcast stream
22/12 14:19:20:943 | | Client | Starting the process Diffusion
22/12 14:19:20:943 | | Client | /usr/local/vigiclient/processdiffvideo -loglevel fatal -f fbdev -i /dev/fb0 -r 30 -c:v h264_omx -profile:v baseline -b:v 1500000 -flags:v +global_header -bsf:v dump_extra -f rawvideo tcp://127.0.0.1:8043
22/12 14:19:21:483 | | Client | H.264 video streaming process is connected to tcp://127.0.0.1:8043
22/12 14:19:22:674 | | Client | H.264 video streaming process is disconnected from tcp://127.0.0.1:8043
22/12 14:19:22:674 | | Client | The Diffusion process is stopped after 31723 milliseconds with the exit code 0
22/12 14:19:22:675 | | Client | Stopping the H.264 video broadcast stream
the stream stop.
Do you changed something on the client ? Do you installed it manually ? Or do you installed the provided pre installed vigibot image ?
Since the framebuffer is not working ( and not using the camera) I can tell that it is not a camera problem.
6 utilisateur(s) li(sen)t ce sujet
0 members, 6 guests, 0 anonymous users
