:squared_sos:|help-questions
10528 réponses à ce sujet
#9621 OdorousWo1f
OdorousWo1f
  • 1 154 messages
Posté 03 août 2023 - 09:57
oh, nice! seems relatively simple. for both levels i can just reprogram it. (and you would be right on it not driving up and down stairs, but it is manually picked up and moved a lot)
what lidars are supported?
would a pi 3a+ have enough power to process that?
#9622 Mike118
  • 12 511 messages
Posté 03 août 2023 - 10:04
Best is pi4 and lidar is ld06.
#9623 OdorousWo1f
OdorousWo1f
  • 1 154 messages
Posté 03 août 2023 - 11:06
https://www.amazon.c...B08GJJX41D?th=1
this one?
i assume it just connects directly to the serial pins (or USB) of the pi and it just works
#9624 Mike118
  • 12 511 messages
Posté 03 août 2023 - 12:30
Yes using serial pins then you need to configure vigibot and then it should works out of the box.
#9625 OdorousWo1f
OdorousWo1f
  • 1 154 messages
Posté 03 août 2023 - 03:52
oh nice, might get a lidar for myself soon.
thank you for the info
#9626 eidyn
eidyn
  • 55 messages
Posté 04 août 2023 - 03:57
Does anyone know what I can try to get the microphone working?
It's this one https://thepihut.com...-usb-microphone
#9627 levicat05
levicat05
  • 2 messages
Posté 08 août 2023 - 02:25
hey. does anyone know if vigibot web servers are down or something? I'm trying to create an account to get started however when I go to email verification it fails to send a link and im positive I've entered the correct information. when i go to log in it says incorrect password or username even though its also correct. edit: when i try to create a new account it claims i already have an account under my assigned email.
#9628 Mike118
  • 12 511 messages
Posté 08 août 2023 - 10:34
Hum ... strange... are you sure that you did not received the mail in your spam folder ? Do you have a particular mail setting with restrictions ?
@levicat05 check again and if problem is not solved contact me again and I will solve the problem for you.
It works but it is a bad quality one. This one is far better : https://www.robot-ma...ne-usb-446.html
#9629 levicat05
levicat05
  • 2 messages
Posté 08 août 2023 - 11:22
thanks for the reply. i tried registering an account using a temporary email address and it worked fine so it must have been something with my email settings like you said.
#9630 firened
firened
  • 1 784 messages
Posté 10 août 2023 - 08:42
my public robots don't show up when not logged in.
CakeOnIce, pancake, pepitobots are set to "unknown users"
run command `alsamixer` to check what number your mic is. use that as `RECORDINGDEVICE` in hwconfig
#9631 Mike118
  • 12 511 messages
Posté 10 août 2023 - 12:07
I see them when i am not logged in... so i don't understand your problem...
#9632 eidyn
eidyn
  • 55 messages
Posté 10 août 2023 - 12:08
Thank you so much, this fixed it! Vigibot was configured correctly but Alsamixer allowed me to see that the usb sound device was set to 0 volume. Increased it and everything working now!
#9633 Mike118
  • 12 511 messages
Posté 10 août 2023 - 12:09
Was it because off the closing hours set on your robots?
#9634 firened
firened
  • 1 784 messages
Posté 10 août 2023 - 12:27
yes. thank you. all good
remember to save with `sudo alsactl store`
#9635 Mike118
  • 12 511 messages
Posté 11 août 2023 - 09:23
@levicat05 if you have questions the best is to ask them here ;) and feel free to go back in time in this thread to read questions and answers ;)
#9636 paco97211
paco97211
  • 51 messages
Posté 12 août 2023 - 08:20
bonjour sais besoin d aide pour ca voir quelle batterie faux pour vigibot sur mon crawler
#9637 Mike118
  • 12 511 messages
Posté 13 août 2023 - 12:07
Il n'y a pas besoin d'avoir une batterie spécifique pour vigibot. Prend la batterie que ton crawler a besoin et met un convertisseur qui a partir de la batterie que tu auras choisis pour ton crawler fournira du 5v pour ta pi.
#9638 paco97211
paco97211
  • 51 messages
Posté 13 août 2023 - 01:38
Pour le convertisseur il se trouve sur mon crawler ? Ou il faut acheter ?
#9639 Mike118
  • 12 511 messages
Posté 13 août 2023 - 12:23
Si tu en as un qui convient sur ton crawler tu peux l'utiliser... mais je ne sais pas ce que tu as sur ton crawler. Il faudrait que tu montres des photos etc..
#9640 paco97211
paco97211
  • 51 messages
Posté 13 août 2023 - 12:25
ok
comment configurer ma Raspberry ?
6 utilisateur(s) li(sen)t ce sujet
0 members, 6 guests, 0 anonymous users
