Off-road Robot
105 réponses à ce sujet
#1 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 04 juillet 2022 - 17:39
what wattage and RPM do you think i need?
must work with 12volts well as the other motors we looked at were 24 volt. maybe a lower 12v version of the motor i was looking at would work
#2 firened
firened
  • 2 124 messages
Posté 04 juillet 2022 - 18:24
we have to find the target speed. perhaps it would help if you can try some robots and get a feel for speed and handling characteristics. i can tell my dad to set out my trx-4 "Tooster" if you wish?
icecream is possible too.
maybe ask @Micro or @xhap0w or who else has a relatively fast robot for a test drive?
from estimates:
speed => we'll figure out RPM and wheel size proportions.
speed + weight => we'll figure out wattage
i have lots of assumptions in my head, can you tell me more about what you imagine and wish the robot to be like?
some keywords:
length, height, weight, push force, target terrain, suspension, sidewalk step capability, wheel grip, wheel type: air filled, solid, tire notches; cargo capacity, frame material, 3D printed,
#3 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 04 juillet 2022 - 18:25
sure. i can try tooster today.
i'm unsure about exact length and height yet. weight all together i'm guessing 15 - 25 pounds. the terrain will be sidewalks, gravil, dirt, bumpy terrain. unsure about tires yet. frame material will be out of those X frame stuff. essentially very similar to Pierre's 4x4 just bigger and with lots of different modifications
then with tooster i can get a feel for what drive settings (ramp) i'd need for a big robot
already tested icecream before. i like it's driving characteristics but again too slow. still a bit too slow (presumably) with wheels which should give us double speed because of the track resistance. would be nice to re-test to get a better feel eventually.
#4 firened
firened
  • 2 124 messages
Posté 04 juillet 2022 - 19:34
ok that's helpful.
x-frame are those aluminum square rods?
#5 OdorousWo1f
OdorousWo1f
  • 1 454 messages
yeah
#6 firened
firened
  • 2 124 messages
Posté 04 juillet 2022 - 19:35
@Pascal 's trx-4 with stock motor is insanely fast!
i think 30-35 km/h
#7 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 04 juillet 2022 - 19:36
oh wow
#8 xhap0w
xhap0w
  • 358 messages
Posté 04 juillet 2022 - 22:19
I don't have robot anyone. But it's average speed was little bit less than an human walk.
#9 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 05 juillet 2022 - 02:15
https://www.amazon.c...y,aps,81&sr=8-8
@fire_ned found a bigger battery, for cheaper! could incorporate some sort of external BMS.
with those statistics that i gave you, what sized motor do you think i need? (updated the weight to 15 - 25 lbs because of the battery)
#10 Mike118
  • 12 871 messages
Posté 05 juillet 2022 - 02:31
This is a very heavy battery... this thing alone should weight around 10kg ( around 20 lbs ) .
#11 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 05 juillet 2022 - 02:32
yeah it is heavy. it'll probably be worth it with the large capacity + larger motors
#12 Mike118
  • 12 871 messages
Posté 05 juillet 2022 - 02:33
What is your budget for this robot ? What is the wanted size ?
#13 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 05 juillet 2022 - 02:35
i don't really have a budget. maybe twice the size of pierre's 4x4. it'll be 4x4 just bigger, better, and have lots of changes.
#14 Mike118
  • 12 871 messages
Don't you think that a robot like fredj21 robot would be great for you ?
#15 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 05 juillet 2022 - 02:36
i'm going based off of pierre's 4x4. it's based off of the design of 4x4.
#16 Mike118
  • 12 871 messages
I guess that twice the pierre's 4x4 will be too big for indoor use...
And you said you also want use it indoor...
#17 OdorousWo1f
OdorousWo1f
  • 1 454 messages
Posté 05 juillet 2022 - 02:37
it's not for indoor. when did i say i would use it indoor?
if you meant the message saying i wanted motors that also control good at low RPM when i also said that'd be also good for quick indoor testing
#18 Mike118
  • 12 871 messages
Posté 05 juillet 2022 - 02:41
For exemple i have this one that is too fast for indoor x)
#19 OdorousWo1f
OdorousWo1f
  • 1 454 messages
it looks too fast for indoors.
icecreamtruck has torque to move itself at near minimum throttle. that's what i'm looking for along with decent speed. unsure if there's a motor that can do both. not a real requirement but a nice-to-have thing
#20 Mike118
  • 12 871 messages
Posté 05 juillet 2022 - 02:44
I would highly recommend you to buy a nice rc car truck and then just modify it a little to add the raspberry pi... would be way easier and less expensive for you...
