Off-road Robot
#22
Posté 05 juillet 2022 - 02:47
#24
Posté 05 juillet 2022 - 02:26
this battery is 23.1 Lbs.
keep in mind that with a differential drive the wheels get actually dragged sideways across the ground when turning.
adding that much weight will result in a lot of forces on the frame, and if you plan on a suspension the forces on it will be high.
however, if you actually consider an SLA battery, then you can pay your local moto or car mechanics a visit and ask nicely if they have a leftover used battery you could have. i got some for free that way too. don't expect more than 50% capacity, but it will give you a way to try it out. if it's too heavy you can get a li-ion, li-po or LiFePO4
#25
Posté 05 juillet 2022 - 02:27
might stick with the lifepo then
although I've heard that lifepo ecosaver battery or whatever it was called has a terrible BMS in it.
i would have just done RC car type steering but idk how i would scale that up and make it work with suspension. just seems overly complicated for something like that.
#26
Posté 05 juillet 2022 - 02:33
with the heavy SLA, around 300W.
20mph is 6 times as fast as icecream, if using the same motors (total power of 150W), the slow rpm precision is still going to be 6 times worse. that's one reference i based my thoughts on.
the other being the trx-4 that has a 190W to reach 21mph, while weighting only a couple pounds...
perhaps my estimates are even conservative.
anyway, it's possible, just needs power
ps: Brushless motors have better power, and less losses, but poor low rpm precision.
#33
Posté 05 juillet 2022 - 02:39
This is 50 watts but seems awfully small.
https://www.amazon.c...,aps,219&sr=8-6
isn't that the same kind of motor found in the TRX4?
#34
Posté 05 juillet 2022 - 02:46
#36
Posté 05 juillet 2022 - 02:50
#37
= 533 m/min
533 m/min divided by (example) 500 rpm = 1.07m wheel circumference
1.07m / [U+03C0] = 34cm wheel diameter
that's the proportion: [U+2205] 34cm wheel at 500 rpm
if you double the rpm, the [U+2205] wheel halfes - and vise versa. it's inverse proportional.
that should help you find something suitable.
if you find a [U+2205] 20cm wheel you'll need 850rpm motors. makes sense?
i hope it's correct what i wrote.
#38
Posté 05 juillet 2022 - 02:51
#40
Posté 05 juillet 2022 - 02:52
