Problème reconnaissance vocale CMU Sphinx
Aucune réponse à ce sujet
#1 R2D21995
R2D21995
  • 385 messages
Posté 30 août 2017 - 07:02
Je suis en train d'utiliser pocketsphinx-python pour faire de la reconnaissance vocale.
Je tourne sur raspberry. Après quelques recherches j'ai trouvé un exemple. Le problème c'est que quand je le lance il me dit
ERROR: "pocketsphinx.c", line 1129: Utterance is not started
Traceback (most recent call last):
  File "reco.py", line 66, in <module>
    decoder.end_utt()
mport sys, os
from pocketsphinx.pocketsphinx import *
from sphinxbase.sphinxbase import *
import pyaudio
import wave
import time
# constants
SAMPLE_RATE = 16000
CHUNK_SIZE = 1024
print("Setting directories")
# Set directories
modeldir = "/home/pi/sphinx/fr-fr"
dictdir = "/home/pi/sphinx/fr-fr"
# Create a decoder configeration
config = Decoder.default_config()
config.set_string('-hmm', os.path.join(modeldir, 'fr'))
config.set_string('-lm', os.path.join(modeldir, 'fr-small.lm.bin'))
config.set_string('-dict', os.path.join(dictdir, 'fr.dict'))
config.set_string('-keyphrase', 'talkin to')
config.set_float('-kws_threshold', 1e-5)
# create decoder
decoder = Decoder(config)
# open the wav file
print("Opening Wav file")
wf = wave.open('/home/pi/sphinx/datas.wav', 'rb');
# extract data from wav file
filesize = wf.getnframes() * 2
decoder.start_utt()
print "decong"
# tracking variables
index = 0
detected_times = 0
# loop for all chunks until the end of the file
while index < filesize:
    # set number of bytes to CHUNK_SIZE unless that would overrun file size
    if (index + 1024) > filesize:
        count = (filesize - index)
    else:
        count = CHUNK_SIZE
        # take sub set of the data
        temp_data = data[index:(index+count)]
        # process this subset
        decoder.process_raw(temp_data, False, False)
        if decoder.hyp() != None:
            #increment the keywords detected count
            detected_times = detected_times + 1
            # print out some debug
            print("Keyword detected @ ", (index / SAMPLE_RATE), "Seconds: String = ", decoder.hyp().hypstr, ": \
Best score = ", decoder.hyp().best_score, ": confidence = ", decoder.get_logmath().exp(decoder.hyp().prob))
            decoder.end_utt()
            decoder.start_utt()
            # update index to take the next subset
            index = index + count
            # print the number of keywords detected
            print("detected times = ", detected_times)
            decoder.end_utt()
