How to use stepper motor with Arduino & AccelStepper library
1 réponse à ce sujet
#1 Snyp54
Snyp54
  • 32 messages
Posté 05 août 2020 - 02:22
Hi,
this is a code for use stepper motor on vigibot using an Arduino and AccelStepper library.
I use a A4988 stepper motor driver., two wire is needed between driver and Arduino ( Step & Dir).
 * Vigibot Pi to Arduino Uart default remote configuration example by Mike118
#include <AccelStepper.h>
// Meta Type :
typedef struct {
 union {
  struct {
   int16_t x;
   int16_t y;
  int16_t coordonnees[2];
  uint8_t bytes[4];
} Point;
typedef struct {
 union {
  struct {
   int8_t x;
   int8_t y;
   int8_t z;
  uint8_t bytes[3];
} Vitesses;
// CONFIG
#define PISERIAL Serial
#define NBPOSITIONS 2
#define FAILSAFE 250 // ms
// TTS
#define TTSBUFFERSIZE 255
uint8_t ttsBuffer[TTSBUFFERSIZE];
uint8_t ttsCurseur = 0;
// TX
#define TXFRAMESIZE (NBPOSITIONS * 4 + 17)
typedef struct {
 union {
  struct {
   uint8_t sync[4];               // 4
   Point positions[NBPOSITIONS];  // NBPOSITIONS * 4
   uint16_t val16[2];             // 2 * 2
   uint8_t choixCameras;          // 1
   Vitesses vitesses;             // 3
   uint8_t interrupteurs;         // 1
   uint8_t val8[4];               // 4
  uint8_t bytes[TXFRAMESIZE];
} TrameTx;
// RX
#define RXFRAMESIZE (NBPOSITIONS * 4 + 9)
typedef struct {
 union {
  struct {                       // Sizes
  uint8_t bytes[RXFRAMESIZE];
} TrameRx;
TrameTx trameTx;
TrameRx trameRx;
uint32_t lastTrameTimestamp = millis();
AccelStepper Xaxis(1, 2, 6);
AccelStepper Yaxis(1, 4, 7);
  PISERIAL.begin(115200);
  // add all your init here
  Xaxis.setMaxSpeed(400);
  Yaxis.setMaxSpeed(400);
  Xaxis.setSpeed(0);
  Yaxis.setSpeed(0);
  if(readPiSerial()) {
    // each time we receive a full trame run repeatedly:
    // use values inside trameRx to tell your robot how to move ...
    // trameRx.vitesses.x , trameRx.vitesses.y, trameRx.vitesses.z
    // trameRx.positions[i].x trameRx.positions[i].y  etc....
    writePiSerial();
    updateSteppers();
  if( millis() - lastTrameTimestamp > FAILSAFE ) {
    // Stop the robot in case the robot lost connection with the Pi
    stopSteppers();
  } else {
    // put your main code here, to run repeatedly:
    // avoid abstacle, run speed ...
    runSteppers();
bool readPiSerial() {
 uint8_t current;
 static uint8_t lastType = 0;
 static uint8_t n = 0;
 static uint8_t frame[RXFRAMESIZE];
 while(PISERIAL.available()) {
  current = PISERIAL.read();
  switch(n) {
   case 0:
    if(current == '$')
     n = 1;
    break;
   case 1:
    if(current != 'T' && lastType == 'T')
     writeTtsBuffer('\0');
    if(current == 'S' || current == 'T') {
     lastType = current;
     n = 2;
    } else
     n = 0;
    break;
    default:
    frame[n++] = current;
    if(n == RXFRAMESIZE) {
     if(lastType == 'T') {
      for(uint8_t i = 4; i < RXFRAMESIZE; i++) // Do not send the 4 sync data in tts
       writeTtsBuffer(frame[i]);
     } else if(lastType == 'S') {
      for(uint8_t p = 0; p < RXFRAMESIZE; p++)
       trameRx.bytes[p] = frame[p];
     n = 0;
     return true;
 return false;
void writePiSerial() {
 // Header, do not modify
 trameTx.sync[0] = '$';
 trameTx.sync[1] = 'R';
 trameTx.sync[2] = ' ';
 trameTx.sync[3] = ' ';
 // modify the feedback according your need. By default we copy the trameRx content ...
 for(uint8_t i = 0; i < NBPOSITIONS; i++) {
  trameTx.positions[i].x = trameRx.positions[i].x;
  trameTx.positions[i].y = trameRx.positions[i].y;
 trameTx.val16[0] = 0;   // Voltage (will be updated by Raspberry pi)
 trameTx.val16[1] = 0;   // Percent (will be updated by Raspberry pi)
 trameTx.choixCameras = trameRx.choixCameras;
 trameTx.vitesses.x = trameRx.vitesses.x;
 trameTx.vitesses.y = trameRx.vitesses.y;
 trameTx.vitesses.z = trameRx.vitesses.z;
 trameTx.interrupteurs = trameRx.interrupteurs;
 trameTx.val8[0] = 0;   // CPU load (will be updated by Raspberry pi)
 trameTx.val8[1] = 0;   // Soc temp (will be updated by Raspberry pi)
 trameTx.val8[2] = 0;   // link (will be updated by Raspberry pi)
 trameTx.val8[3] = 0;   // RSSI (will be updated by Raspberry pi)
 for( uint8_t i = 0; i < TXFRAMESIZE; i++)
  PISERIAL.write(trameTx.bytes[i]);
void displayTtsBuffer (uint8_t * ttsBuffer, uint8_t bufferSize) {
  // you can modify this function to display text on a screen depending on your hardware...
  for( uint8_t i = 0; i < bufferSize; i++)
    Serial.write(ttsBuffer[i]);
  Serial.println("");
void writeTtsBuffer( uint8_t ttsChar) {
  static uint8_t ttsCurseur = 0;
  if( ttsCurseur < TTSBUFFERSIZE && ttsChar != '\0') {
    ttsBuffer[ttsCurseur] = ttsChar;
    ttsCurseur ++;
  if( ttsCurseur == TTSBUFFERSIZE || ttsChar == '\0') {
    displayTtsBuffer (ttsBuffer, ttsCurseur);
    ttsCurseur = 0;
void stopSteppers() {
  Xaxis.setSpeed(0);
  Yaxis.setSpeed(0);
  runSteppers();
void runSteppers() {
  Xaxis.runSpeed();
  Yaxis.runSpeed();
void updateSteppers() {
  Xaxis.setSpeed(trameTx.positions[0].x);
  Yaxis.setSpeed(trameTx.positions[0].y);
#2 firened
firened
  • 53 messages
Posté 07 août 2020 - 01:28
nice. thanks for sharing!
