Serial troubleshooting for titi
1 réponse à ce sujet
#1 Mike118
  • 10 295 messages
Posté 08 septembre 2020 - 08:57
First step : check that the raspberry pi provide serial outputs as expected :
To activate this in hardware config activate " WRITEUSERDEVICE " .
Nothing more is needed for this first step.
By default Raspberry serial0  is selected, this is connected to GPIO 14 (TX ) and GPIO 15 (RX )
And default baudrate is 115200 Baud.
You should check that the data is available on the TX pin ( GPIO 14 )  with an oscilloscop or just a led.
Note refer to this to double check that you are using the correct raspberry pi GPIO :
You can also use simple this arduino sketch:
// Connect RX arduino pin digital 0   to Raspberry Pi Tx Pi Gpio 14
// Connect Arduino GND and Raspberry Pi GND
// Either connect Arduino 5V to Raspberry pi 5V or connect Arduino USB on your computeur.
// If some data is received, the led will be on and text will be display on Serial monitor if arduino is connected with USB
// If no data the led will stay off.
#define LED 13
  // put your setup code here, to run once:
  Serial.begin(115200);
  pinMode(LED, OUTPUT);
  // put your main code here, to run repeatedly:
  if (Serial.available()) {  // Data received
    digitalWrite(LED, HIGH);
    int incomingByte = Serial.read();
    Serial.print("I received: ");  // Display received data
    Serial.println(incomingByte, DEC);
  } else {
    digitalWrite(LED, LOW);
#2 littletiti
littletiti
  • 4 messages
Posté 19 septembre 2020 - 10:07
Merki ;)
