Lego pour les enfants
3 réponses à ce sujet
#1 KentHerrera
KentHerrera
  • 1 messages
Posté 07 août 2021 - 12:23
Janome Memory Craft 550E vs. Elna eXpressive 830L: Which is The Best Embroidery Machine to Buy?
As an experienced embroiderer and contributor at CraftsSelection, I've had the privilege of working with a wide array of embroidery machines, witnessing firsthand the evolution of technology in this craft. Today, I'm thrilled to delve into a comparison that has sparked considerable interest among embroidery enthusiasts: Janome Memory Craft 550E vs. Elna eXpressive 830L. This comparison is particularly exciting because it pits two of thed7PQkfv.gifbest computerized embroidery machines against each other, both renowned for their advanced features, reliability, and the exceptional quality of work they produce.
Janome Memory Craft 550E Home Embroidery Machine
The Janome Memory Craft 550E is a high-quality embroidery machine that will amaze you with its features and capabilities below:
  • Large embroidery area of 7.9” x 14.2”
  • Maximum speed of 860 stitches per minute
  • 180 built-in embroidery designs and 6 fonts
  • On-screen editing features
  • Adjustable hoop positioning
Elna eXpressive 830L Computerized Embroidery Machine
The Elna eXpressive 830L is undoubtedly the best home embroidery machine XxHxp2r.gifwith various user-friendly features. Prepare to be astounded by its remarkable features and capabilities listed below:
  • Large embroidery area of 200 x 360 mm (7.8” x 14.1”)
  • Automatic thread cutter
Janome Memory Craft 550E vs. Elna eXpressive 830L: Choosing the Best Embroidery Machine for You
When people talk about the top embroidery machines out there, the Elna eXpressive 830L and the Janome Memory Craft 550E always come up. They're pretty similar, having the same size for embroidery work, the same speed, and even use the same needles and hoops. The Elna eXpressive 830L has a bit of Swiss design that makes it look a little fancier than the Janome. But, when it comes down to what they can do, both these machines are on the same level. They perform really well, offering everything an embroidery lover could want for creating amazing projects with ease and confidence, no matter if it's under the Elna or Janome name.
Conclusion
Looking for the27428159927_1caac58d27_o.gifbest home embroidery machine? Look no further! The Janome Memory Craft 550E and Elna eXpressive 830L are both top-notch options. Packed with advanced features and stitching capabilities, they'll take your embroidery projects to new heights. Consider factors like price, stitching area, speed, and connectivity options to find your perfect match. Get ready for a thrilling stitching adventure with remarkable results!
Whether you're a beginner embarking on your first embroidery project or a seasoned professional seeking to upgrade your equipment, CraftsSelection caters to all levels of expertise with its detailed and unbiased embroidery machine reviews. By leveraging this treasure trove of information, you'll not only learn about the Elna eXpressive 830L and Janome Memory Craft 550E in greater detail but also discover how they stack up against other top contenders in the market. Visit CraftsSelection today and arm yourself with the knowledge needed to choose wisely among the best embroidery machines.
#2 Oracid
Posté 07 août 2021 - 02:04
Et bien, en fait, tu n'as pas vraiment le choix.
La dernière version du Mindstorms de Lego, c'est le Robot Inventor, boite 51515, https://www.lego.com...-inventor-51515, à 360€
Il y a énormément de vidéos sur YouTube, tu devrais y jeter un coup d'oeil pour te faire une idée.
En voici une :
#3 pmdd
pmdd
  • 1 159 messages
Posté 04 octobre 2021 - 02:26
En voici une :
Bonjour Oracid, tu t'es mis au 5151 ? un retour d'expérience ?
Que faire des 5 briques EV3 que j'ai dans ce cas là sans parler des dizaines de capteurs, moteurs...etc ?
Tu gères comment ?
Cordialement
#4 Oracid
Posté 04 octobre 2021 - 05:56
Tu gères comment ?
Cordialement
Non, je ne me suis pas mis au 51515.
Comme je te l'expliquais ici, https://www.robot-ma...rs-la/?p=114327, j'ai choisi l'association des technos Lego, Arduino et servo RC.
Je t'invite à allez voir mes dernières vidéos. Aujourd'hui, j'ai terminé un quadrupède avec 12DOF qui fonctionne très bien. Bientôt, la vidéo.
Ce n'est pas pour me vanter, mais c'est quand même pas mal de faire un quadrupède 12DOF quand on est passionné de robotique.
Je suis profondément convaincu que mon orientation est la bonne. Quand je dis Arduino, ce n'est pas restrictif, n'importe quel microcontrôleur ou RasBpi peut faire l'affaire.
Il y a également le M5Stack pour lequel il existe un Shield pour les gros servos Lego, https://www.robot-ma.../13342-m5stack/. J'ai ce type de matériel, mais je n'ai jamais réussi à l'utiliser et ça dort dans un coin.
Moi aussi, j'ai beaucoup de matériel que je n'utilise plus, et cela va en augmentant. Si tu penses que tu ne va plus utiliser tes EV3, essaye de les vendre.
Je pense qu'il faut aller de l'avant sans trop se retourner. La robotique, c'est de la mécanique, de l'électronique et de l'informatique. Ces 3 disciplines évoluent à une très grande vitesse. Cela fait 50 ans que j'essaye de suivre. Aujourd'hui, je suis un peu essoufflé, mais je suis encore debout.
