ups-boards
#122
Posté 14 mai 2020 - 10:47
#124
Posté 14 mai 2020 - 12:48
#125
Posté 14 mai 2020 - 13:59
the PEN or RUN pin could be used to achieve the same as the switch. to keep a pi shut off (except some mA), and to get it out of a discharged state.
raspberry pi 2 B+ and newer have a RUN pin.
raspberry pi 3 B+ and newer have RUN and PEN.
I don't know whether the PEN or RUN pin uses less power..
they are both pulled high. if we connect a switch from one of those pins to GND it will disable the pi.
all in all, cutting a trace on the UPS would not be necessary this way, but it still uses a tiny bit of power (6Ah charge last 24 days @ 10mA).
and it's still a manual solution for when the battery is empty.
#126
Posté 14 mai 2020 - 14:01
PEN is general power disable
RUN and PEN are pull-up to VCC
RUN GND = 100mA
PEN GND = 10mA
#127
Posté 14 mai 2020 - 14:02
#128
Posté 14 mai 2020 - 14:03
remaining 10mA is for the red leds
#130
A pulse to RUN is like Reset on any microcontroller
PEN is like a hardware power off
without current requierment on a bigger switch
#132
Posté 14 mai 2020 - 14:05
everywhere
https://www.google.c...Q4dUDCAY&uact=5
https://www.raspberr...ic.php?t=207961
interesting. a real poweroff from software
GPIO to PEN
linux halt = full poweroff
dtoverlay=gpio-poweroff,active_low=y
which will safely shutdown raspbian, then finally bring GPIO26 / PEN low to shut off power.
11mA measured
and poweron pulse button
this is the missing featue on our PI
a real poweroff and pulse to power on
now an UPS can auto poweron @ 10% battery and no more problem
and serious design
like any ATX computer
a power switch on low voltage is a bad desig
n
The power LED will probably be consuming about 4mA, the PEN pull-up about 2.5mA, the Transorb over-voltage protector, the PMIC and high-side switch for HDMI 5V should not be drawing much. So there's about 4-5mA unaccounted for.
the other solution is small solid state relay
https://fr.farnell.c...s-de-relais=cms
A good one = https://fr.farnell.c...t-no/dp/1608203
4.5A 0.1ohm
#134
Posté 17 mai 2020 - 11:29
#135
Posté 17 mai 2020 - 15:05
-the pololu pushbutton switch looks like a possibility too. CTRL pin probably wants clear signals, so maybe also the alarm pin from the CW2015?
from the pololu pushbutton spec:
"Switch can lose its state when power is disconnected (the switch typically defaults to being off when power is first applied, but it can default to being on near the upper end of the operating range)"
would that be a problem or how many days will the battery last after the pololu switch turned off?
#136
Posté 17 mai 2020 - 15:47
#137
Posté 17 mai 2020 - 16:11
@Pascal do you have a discharged battery (at around 2.4V) that you can test with your 4 diodes?
with 4 x 0.6V diodes the voltage will get stuck at 2.6V and will never reach 3.0V to actually start charging the battery.
either way. I'm not a fan of this, i think it's dangerous and advise against using it.
this is the correct group here to discuss this i think.
#138
Posté 17 mai 2020 - 16:56
#139
Posté 17 mai 2020 - 17:00
0.75V because load
yes 4 diode is too much !!!
3 diode look perfect
but i need to measure the CC part @ the begin of charge
remember two 18650 can handle a charge up to max 10A without problem !!!
5 better
we are limited with the charger, the low voltage, and wire vdrop !!!
and current is BMS limited also !
#140
Posté 17 mai 2020 - 17:05
