help questions
#10661
Posté 05 août 2025 - 21:10
#10662
Posté 05 août 2025 - 23:06
This is the charge crash problem. But I still have no clue about the second kind of crash yet. Do you tested without your BMS ?
#10663
Posté 05 août 2025 - 23:43
#10666
Posté 06 août 2025 - 14:01
#10667
Posté 06 août 2025 - 15:06
Alright, it definitely behaves differently now. If I push it strong enough and at low enough voltage, I can shut off the entire UPS and I have to switch off and back on, but I guess I'm pushing it past what's normal now. I'll plug the battery back in, and stress test climbing some slopes
Unfortunately, setting VUSB to 9V made no difference to fast charging, the client still crashes.
#10669
Posté 06 août 2025 - 19:52
What battery are you using ? You have a second robot. Does it have the same motors? Can you crash it the same way ? Can you switch some hardware between both ?
#10671
Posté 06 août 2025 - 20:14
Can you switch them easily ?
#10673
Posté 06 août 2025 - 20:18
#10674
Posté 06 août 2025 - 21:53
#10675
Posté 06 août 2025 - 22:50
One of the three module should be the issue... you already shorted the ina resistor. I think it was the biggest issue...
I think that now you shorted the ina resistor you might just manage to pull too much current fot the battery protection...
this is the battery protection on the robot
I forget to mention that VBAT also go through BQ25792RQMR before being VBAT OUT... It might be the second one causing limitations.
#10676
Posté 09 août 2025 - 21:33
#10677
Posté 09 août 2025 - 23:56
@Garfield2142
#10678
Posté 10 août 2025 - 09:25
-Turned on i2c in raspi-config
-Robot started bootlooping (Camera clicking and lights turning on and off every few seconds).
-Unplugged every servo and camera
-Still bootlooping
-Took raspi out of the UPS and powered it directly from USB
-Plugged in HDMI
-Completely dead, no signal...
-Insert new SD card with brand new fresh image, reset my Panther HW and remote control config to factory settings.
-Plugged raspi into UPS and HDMI monitor.
-Raspi works, and stops at exactly the same part in booting, then restarts, repeat forever.
-Took raspi out of the UPS, powered only with USB.
-Boots completely fine
Here's my raspi 3B+ bootlooping while plugged into the vigiUPS
And here's the exact same raspi 3B+ without the UPS, booting normally
After a successful boot without the UPS, I plug the pi back into the UPS, the same bootloop happens, so it's not a "first boot setup" sequence
#10679
Posté 10 août 2025 - 11:29
-Sudo update, sudo upgrade, raspi now bootloops faster
-Changed ina219 address in sys.json to 68 to avoid detection, no difference.
-Disabled i2c in raspi-config, no difference
Swapped out the raspi 3B+ (Panther) to raspi4 (Pluto), same thing, can't boot.
16 utilisateur(s) li(sen)t ce sujet
0 members, 16 guests, 0 anonymous users
