help questions
#10683
Posté 10 août 2025 - 14:19
Yup, it came back. I could've saved myself a few hours if I just checked the battery voltage first
But at least I found out that the UPS will still allow the pi to boot halfway through, even if there is not enough charge to finish booting.
It was just really strange that it always failed at the exact same part. Maybe that's when something really demanding would've happened, increasing current, and that's when the step-up gave up.
#10685
Posté 10 août 2025 - 19:13
#10686
Posté 10 août 2025 - 19:18
I might not even need this tumor anymore, I think there's plenty of room to mount the on/off switch and the magnet should stick out enough
#10687
Posté 10 août 2025 - 20:12
#10688
Posté 10 août 2025 - 20:48
Tried all sorts of cables, both magnetic and "normal" usb C cables.
So this explains why my battery was empty by the morning.
Using the built-in USB-C port, with a 67W charger (setUSB bridges are not set), I get -0.7A (discharging)
It just literally crashed the client again with the 67W charger, now I don't have ina219 again
#10689
Posté 10 août 2025 - 21:00
#10690
Posté 10 août 2025 - 21:04
Something is seriously wrong with that ina219
Are you available tomorrow for live testing? I can show you what happens with every single charger, just let me know in advance, as I literally can't keep the robot alive
#10691
Posté 11 août 2025 - 11:01
@Mike118 I wonder if it could be `9.3.8.2 Dynamic Power Management` (DPM) page 37 https://www.ti.com/l...s=1754879865898
I couldn't find any info on how to test for it or change its behavior
#10692
Posté 11 août 2025 - 18:50
#10695
Posté 17 août 2025 - 22:17
#10698
Posté 28 septembre 2025 - 08:10
Nice parts
10) can you explain what you mean, that you have 3x Li-Ion 7.4V Batteries? 18650 cells? How many single cells?
1) doesn't your RC Car already have an ESC included? Perhaps you don't have to buy a new one.
6A) The picture shows a 4S battery holder. But you'll need a 2S.
6B) what is the amperage or wattage of the motor? Some RC Car motors are very powerful and will be too much for the 18650 holders. I wouldn't go above 5A rms and 10-20 A peaks with those holders.
5) The 2x max17043 i bought from AliExpress did not work, they are counterfeit and don't work with raspberry pi. Unfortunately the original (not from AliExpress) is expensive: 10$.
5A) if you want one, "DFRobot Gravity I2C 3.7V Fuel Gauge" is available, but it's 12$.
5B) they are also single cell only. ((you can't connect it to the first Li-ion cell, because this would bridge the BMS, which switches the battery negative)). You'll need to create a voltage divider, for that you'll need e.g. 2x 100 kOhm resistors.
11) do you have some more cables at home? You'll need some awg 16 or 14 for the bms, charger and switch.
Hope that helps
#10699
Posté 28 septembre 2025 - 10:26
2)
3)
4) to measure the voltage you need a fuel gauge. But most fuel gauges only accept 1S voltage. Since you have 2S, you have to half the voltage. You're correct, it's probably not 2x 100 kOhm, because the fuel gauge might have a resistor on it as well. Values will depend on fuel gauge board.
5)
6) might work, would be good to check anyway.
Hm the WPL C24 looks like it's small. Yeah there will be a lot of added weight. I'm not sure if it will work with this car.
#10700
Posté 29 septembre 2025 - 10:09
https://aliexpress.r...8085017227.html
Yeah 18650 from AliExpress is risky.
I buy them from a local swiss store.
Up to you
You'll be able to use it for other larger motors as well, so can make sense.
Both should work fine. The WPL B24 has a "180" type motor, which is listed as compatible on the 5A ESC specifications
15 utilisateur(s) li(sen)t ce sujet
0 members, 15 guests, 0 anonymous users
