help questions
#10722
Posté 09 novembre 2025 - 22:12
#10724
Posté 09 novembre 2025 - 23:34
#10725
Posté 11 novembre 2025 - 09:10
A low power LED is often set to 20 mA. If it's just a "signal" then 5 mA can be enough, which would be possible to drive from the Pi without transistor.
But if you'd like to have actual light, then yeah, you'll need a driver.
How many LEDs and of what type?
Options are:
1) no soldering:
https://aliexpress.c...0298159107.html
https://aliexpress.c...0290163842.html
2) cheapest and very versatile: FET, For 3.3V good are N-CH FQP30N06L + P-CH NDP6020P + 10 kOhm resistors.
3) high power LED current driver:
https://aliexpress.c...0341086776.html
4) arduino relais
5) arduino driver boards
- the buzzer you sent looks good. (It must be an "active" buzzer for 5V or 3V)
- the LED you sent, what voltage and current do they need? Link?
The (2) second option would look like this. The "FAN" can be a motor, laser, lightbulb, amplifier, and some LEDs (only if they are already current limited. It depends on the product.)
#10726
Posté 11 novembre 2025 - 10:33
Check this out instead. It has COB LEDs, often they are brighter, but doesn't say how much. Pick one with a ServoPWM controlled LED driver.
https://aliexpress.c...5313017978.html
#10728
Posté 11 novembre 2025 - 16:20
I have it too sometimes.
Things you can do:
- make sure the camera flex cable is not close to any other cable or electronics.
- does it only happen when driving? Some motors do not have a good EMI shield, it's a metal plate around the motor.
- you can use copper tape and put it on both sides of the camera flex cable, i did this on IcecreamTruck.
I see where this is going
(old meme)
#10732
Posté 12 novembre 2025 - 17:05
Or perhaps ask around in your friend- and relative-circles. At least here in Switzerland i think many people might have old rc cars they no longer need.
Also remember that there's no rush. Electronics is often not about reaching an end goal at all, but more about the journey, learning, soldering, breaking things and making mistakes.
#10734
Posté 12 novembre 2025 - 19:26
I am working on "industrialisation" to make them easier to build and solving issues ...
Nerf vigibot
#10736
Posté 12 novembre 2025 - 20:26
#10738
Posté 12 novembre 2025 - 20:27
13 utilisateur(s) li(sen)t ce sujet
0 members, 13 guests, 0 anonymous users
