help questions
11000 réponses à ce sujet
#10701 firened
firened
  • 2 124 messages
Posté 10 octobre 2025 - 19:11
Nice.
"Flash drive"? Like an USB flash drive? (It should still work though)
Try running `tail /var/log/vigiclient.log`
Do you have a screenshot with blurred out password of /boot/robot.json
Very cool you're writing a lot of info and what you tried :yes:
Much easier to help this way :)
#10702 Mike118
  • 12 871 messages
Posté 10 octobre 2025 - 19:13
What kind of raspberry pi are you using ?
Yes you can try that.
#10703 firened
firened
  • 2 124 messages
Posté 10 octobre 2025 - 19:20
After the first boot it can take quite a while until it shows up on Vigibot. How long did you wait until you rebooted?
It can take up to 30 min, because it updates every installed software package, I'm not sure if it's true that a reboot will stop the update process and it won't come online at all even after a reboot.
Yes looks like vigiclient isn't properly running.
You can try to reflash the image again, best to leave the "Public" in robot.json and see if it comes onlinr after 30 min.
Looks good :yes:
#10704 firened
firened
  • 2 124 messages
Posté 11 octobre 2025 - 12:26
Bravo :clapping:
#10705 bruh0755_89537
bruh0755_89537
  • 3 messages
Posté 11 octobre 2025 - 20:01
How much does a raspberry pi cost so i can use a ptz camera to stream to vigibot for you guys?
#10706 garfield2142
garfield2142
  • 379 messages
Posté 11 octobre 2025 - 20:04
I had good experience with this seller https://www.aliexpre....1f351802APXYsj
#10707 bruh0755_89537
bruh0755_89537
  • 3 messages
Posté 11 octobre 2025 - 20:08
Holy thats expensive!!
#10708 firened
firened
  • 2 124 messages
Posté 14 octobre 2025 - 15:20
@HyperS To control the Camera LED you have to solder a wire. This is easy and will give control of the IR LED.
However, the LEDs are Infrared only. If you want White LED you'll have to desolder the IR led and solder on a 1-3W white LED.
https://www.robot-ma...s/?fromsearch=1
The gpio control for IR led is easy if that's all you want. I can't find instructions for only this step currently
#10709 firened
firened
  • 2 124 messages
Posté 15 octobre 2025 - 07:38
@HyperS for pi power failures, you can try:
Use a shorter usb cable.
Lower the IR LEDs brightness by turning the tiny potentiometer and observing the led with a smartphone camera, which can see IR.
Add a capacitor to the pi's 5V rail.
#10710 garfield2142
garfield2142
  • 379 messages
Posté 19 octobre 2025 - 09:39
Is it this one? If it's this one, I've had some problems with it. It only likes to charge xiaomi devices correctly. Everything else will either charge really slow, or constantly start and stop charging.
#10711 firened
firened
  • 2 124 messages
Posté 19 octobre 2025 - 12:37
It's common. Mine show warnings too sometimes.
#10712 firened
firened
  • 2 124 messages
Posté 21 octobre 2025 - 20:23
@Bruh! are you Dunne on Vigi?
Do you already have a raspberry pi?
There's a way to get a PTZ camera stream to Vigibot, it will however have quite some lag.
1) If you install the Raspbian Desktop image,
2) then install Vigibot.
3) You can then open a browser on the raspberry and
5) stream the desktop to Vigibot using the framebuffer source.
#10713 firened
firened
  • 2 124 messages
Posté 03 novembre 2025 - 18:51
Hm
#10714 garfield2142
garfield2142
  • 379 messages
Can you show a picture of the pi and the buck converter together?
#10715 firened
firened
  • 2 124 messages
Posté 03 novembre 2025 - 19:25
That looks correct. What is the input voltage and amperage rating you give the DCDC converter?
Does the raspberry pi's red power led light up or blink or stays off?
When you measured 5.2V, you did this without the pi running, correct?
If yes, then something cannot deliver enough power under load.
It can be the wiring like you said, but also a broken dcdc converter or an empty battery too.
Or the fuse. They xan have bad contacts sometimes. I melted some before.
#10716 garfield2142
garfield2142
  • 379 messages
Posté 03 novembre 2025 - 19:44
And you're using a 2S li-ion, right?
Can you measure the batteries voltage? Just to be sure
#10717 firened
firened
  • 2 124 messages
Posté 03 novembre 2025 - 19:52
I'm impressed with how much you learn and already know. It's cool :yes:
- the dcdc is inside the heat shrink tubing, where do you measure the voltage under load?
- both raspberry 5V pins are covered from the 3 pin plug, where do you measure the raspberry 5V voltage?
- you can also measure the 3.3V pin on the raspberry to check if there's too little too.
- try without the IR LEDs, if you haven't adjusted the brightness yet, they can use too much power already.
#10718 firened
firened
  • 2 124 messages
Posté 03 novembre 2025 - 20:07
Hm the IR LED forward voltage is 1.8V so i don't understand how it can be less :o
That's normal :yes:
I've been there 100s of times
Sounds great :D
#10719 garfield2142
garfield2142
  • 379 messages
Posté 03 novembre 2025 - 20:11
Congrats! I'm happy that you solved it :D
#10720 firened
firened
  • 2 124 messages
Posté 09 novembre 2025 - 15:23
The magenta / purple color?
That's without the IR filter. Strong shocks can flick the filter off from the camera and put it into Night mode accidentally.
Repower the robot or put it in a dark place.
Looks like this when it's mechanically flicked.
Try repowering the Pi.
Hehe
14 utilisateur(s) li(sen)t ce sujet
0 members, 14 guests, 0 anonymous users
