problème avec arduino
3 réponses à ce sujet
#1 wadzi
wadzi
  • 4 messages
Posté 18 juillet 2010 - 08:08
quand je lance arduino sous mon ubuntu 10.04 j'ai ce message d'erreur et ce que quelqu'un a déjà connu ce genre de souci?
Cordialement.
bacar@bacar-laptop:~$ arduino &
[1] 3108
bacar@bacar-laptop:~$ Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
*** buffer overflow detected ***: java terminated
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x50)[0x222390]
/lib/tls/i686/cmov/libc.so.6(+0xe12ca)[0x2212ca]
/lib/tls/i686/cmov/libc.so.6(+0xe0a08)[0x220a08]
/lib/tls/i686/cmov/libc.so.6(_IO_default_xsputn+0x9e)[0x1a9afe]
/lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x368a)[0x18029a]
/lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xad)[0x220abd]
/lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0x2209fd]
/usr/lib/librxtxSerial-2.1-7.so(fhs_lock+0x1ac)[0xe218cc]
/usr/lib/librxtxSerial-2.1-7.so(Java_gnu_io_RXTXCommDriver_testRead+0x6d)[0xe226bd]
[0x4475f1d]
[0x446efcd]
[0x446eda1]
[0x446eda1]
[0x446f27d]
[0x446c2cc]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1e01d5)[0x111a1d5]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x2c2f69)[0x11fcf69]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1df0cf)[0x11190cf]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1bb5db)[0x10f55db]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1bb641)[0x10f5641]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1be46c)[0x10f846c]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1be9e6)[0x10f89e6]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x28b302)[0x11c5302]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x28c0c3)[0x11c60c3]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x28c159)[0x11c6159]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1dbdd2)[0x1115dd2]
[0x447c0af]
[0x446eda1]
[0x446ef07]
[0x446eda1]
[0x446eda1]
[0x446ef07]
[0x446efcd]
[0x446eda1]
[0x446c2cc]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1e8b1c)[0x1122b1c]
/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so(+0x1ed49d)[0x112749d]
java(JavaMain+0xd4d)[0x804b21d]
/lib/tls/i686/cmov/libpthread.so.0(+0x596e)[0x6be96e]
/lib/tls/i686/cmov/libc.so.6(clone+0x5e)[0x20da4e]
======= Memory map: ========
00110000-00116000 r-xp 00000000 08:01 529071 /lib/tls/i686/cmov/libnss_compat-2.11.1.so
00116000-00117000 r--p 00006000 08:01 529071 /lib/tls/i686/cmov/libnss_compat-2.11.1.so
00117000-00118000 rw-p 00007000 08:01 529071 /lib/tls/i686/cmov/libnss_compat-2.11.1.so
00118000-00120000 r-xp 00000000 08:01 529075 /lib/tls/i686/cmov/libnss_nis-2.11.1.so
00120000-00121000 r--p 00007000 08:01 529075 /lib/tls/i686/cmov/libnss_nis-2.11.1.so
00121000-00122000 rw-p 00008000 08:01 529075 /lib/tls/i686/cmov/libnss_nis-2.11.1.so
00122000-00129000 r-xp 00000000 08:01 2101497 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
00129000-0012a000 r--p 00006000 08:01 2101497 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
0012a000-0012b000 rw-p 00007000 08:01 2101497 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
0012b000-00130000 rwxp 00000000 00:00 0
00130000-0013e000 r-xp 00000000 08:01 1575728 /usr/lib/libXext.so.6.4.0
0013e000-0013f000 r--p 0000d000 08:01 1575728 /usr/lib/libXext.so.6.4.0
0013f000-00140000 rw-p 0000e000 08:01 1575728 /usr/lib/libXext.so.6.4.0
00140000-00293000 r-xp 00000000 08:01 529064 /lib/tls/i686/cmov/libc-2.11.1.so
00293000-00294000 ---p 00153000 08:01 529064 /lib/tls/i686/cmov/libc-2.11.1.so
00294000-00296000 r--p 00153000 08:01 529064 /lib/tls/i686/cmov/libc-2.11.1.so
00296000-00297000 rw-p 00155000 08:01 529064 /lib/tls/i686/cmov/libc-2.11.1.so
00297000-0029a000 rw-p 00000000 00:00 0
0029a000-0029e000 rwxp 00000000 00:00 0
0029e000-0031a000 rwxp 00000000 00:00 0
0031a000-0031b000 rwxp 00000000 00:00 0
0031b000-0032d000 rwxp 00000000 00:00 0
0032d000-00330000 rwxp 00000000 00:00 0
00330000-0041a000 rwxp 00000000 00:00 0
0041a000-00420000 rwxp 00000000 00:00 0
00420000-0043a000 rwxp 00000000 00:00 0
0043a000-0044c000 rwxp 00000000 00:00 0
0044c000-00466000 rwxp 00000000 00:00 0
00466000-0046a000 r-xp 00000000 08:01 1575726 /usr/lib/libXdmcp.so.6.0.0
0046a000-0046b000 r--p 00003000 08:01 1575726 /usr/lib/libXdmcp.so.6.0.0
0046b000-0046c000 rw-p 00004000 08:01 1575726 /usr/lib/libXdmcp.so.6.0.0
0046c000-00470000 r-xp 00000000 08:01 1575730 /usr/lib/libXfixes.so.3.1.0
00470000-00471000 r--p 00003000 08:01 1575730 /usr/lib/libXfixes.so.3.1.0
00471000-00472000 rw-p 00004000 08:01 1575730 /usr/lib/libXfixes.so.3.1.0
00472000-00473000 r--p 00000000 00:00 0
00475000-0047f000 r-xp 00000000 08:01 529073 /lib/tls/i686/cmov/libnss_files-2.11.1.so
0047f000-00480000 r--p 00009000 08:01 529073 /lib/tls/i686/cmov/libnss_files-2.11.1.so
00480000-00481000 rw-p 0000a000 08:01 529073 /lib/tls/i686/cmov/libnss_files-2.11.1.so
00481000-00506000 r-xp 00000000 08:01 2101471 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
00506000-00507000 r--p 00084000 08:01 2101471 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
00507000-0050d000 rw-p 00085000 08:01 2101471 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
0050d000-00532000 rw-p 00000000 00:00 0
00533000-0054e000 r-xp 00000000 08:01 528777 /lib/ld-2.11.1.so
0054e000-0054f000 r--p 0001a000 08:01 528777 /lib/ld-2.11.1.so
0054f000-00550000 rw-p 0001b000 08:01 528777 /lib/ld-2.11.1.so
00550000-00568000 r-xp 00000000 08:01 1577751 /usr/lib/libgdk_pixbuf-2.0.so.0.2000.1
00568000-00569000 r--p 00017000 08:01 1577751 /usr/lib/libgdk_pixbuf-2.0.so.0.2000.1
00569000-0056a000 rw-p 00018000 08:01 1577751 /usr/lib/libgdk_pixbuf-2.0.so.0.2000.1
0056a000-0056c000 r-xp 00000000 08:01 1575720 /usr/lib/libXcomposite.so.1.0.0
0056c000-0056d000 r--p 00001000 08:01 1575720 /usr/lib/libXcomposite.so.1.0.0
0056d000-0056e000 rw-p 00002000 08:01 1575720 /usr/lib/libXcomposite.so.1.0.0
00570000-00576000 r-xp 00000000 08:01 1575748 /usr/lib/libXrandr.so.2.2.0
00576000-00577000 r--p 00005000 08:01 1575748 /usr/lib/libXrandr.so.2.2.0
00577000-00578000 rw-p 00006000 08:01 1575748 /usr/lib/libXrandr.so.2.2.0
00578000-0057a000 r-xp 00000000 08:01 1575724 /usr/lib/libXdamage.so.1.1.0
0057a000-0057b000 r--p 00001000 08:01 1575724 /usr/lib/libXdamage.so.1.1.0
0057b000-0057c000 rw-p 00002000 08:01 1575724 /usr/lib/libXdamage.so.1.1.0
0057c000-00580000 r-xp 00000000 08:01 1572914 /usr/lib/libgthread-2.0.so.0.2400.1
00580000-00581000 r--p 00003000 08:01 1572914 /usr/lib/libgthread-2.0.so.0.2400.1
00581000-00582000 rw-p 00004000 08:01 1572914 /usr/lib/libgthread-2.0.so.0.2400.1
00582000-00583000 r-xp 00000000 00:00 0 [vdso]
00583000-0058d000 r-xp 00000000 08:01 1576458 /usr/lib/libpangocairo-1.0.so.0.2800.0
0058d000-0058e000 r--p 00009000 08:01 1576458 /usr/lib/libpangocairo-1.0.so.0.2800.0Aborted
#2 Dr.Calvin
Dr.Calvin
  • 474 messages
  • Gender:Female
Posté 18 juillet 2010 - 08:14
Bienvenu wadzi,
une petite présentation pour faire connaissance ;) ?
Tu pourrais donner plus de précision sur les circonstances du bug ? quand tu "lances" arduino, est-il isolé ou branché à un circuit ? Et dans ce cas, quel est le programme et dans quel circuit ? Parce que hors contexte, il y a beaucoup de raisons possibles pour un seul bug :wacko:
#3 Inounx
Inounx
  • 111 messages
Posté 21 juillet 2010 - 07:01
Au vu de son message je pense qu'il parle de l'IDE Arduino et non pas d'un programme dans sa carte arduino.
wadzi tu as essayé de suivre les explications fournies ici ? Install Arduino ubuntu
Tu as installé ton IDE en passant par les repository Ubuntu, ou tu as récupéré un package et installé à la main ?
Mon blog : InounxProjects - Projet en cours : Robert
"All the world's a stage, And all the men and women merely players." - William Shakespeare
#4 alienx
alienx
  • 8 messages
Posté 27 juillet 2010 - 06:06
C'est une version 64Bit ton ubuntu ?
Si oui ca vient de la librairie RXTX qui est utilisé par Java pour communiqué sur le port série.
Et la version 2.1.7 de rxtx ne fonctionne pas sur Ubuntu X64 >= 9.10.
Edit:
Solution n°1: Regarder si il n'y a pas une version plus récente de l'IDE ardurino qui inclue le version 2.2 de RXTX.
Solution n°2: Trouver le moyen de la mettre à jours par toi même directement dans les librairies de Java, sûrement installé par l'ide ardurino :P .
Edit n°2:
Je viens de voir que tu n'es pas sur une arch 64bits, mais le problème vient bien de la librairie RXTX qu'il faut mettre à jours vers la version 2.2 qui prend bien en charge Ubuntu 10.04
http://rxtx.qbang.org/wiki/index.php/Download
