ca fait deux jours que je me bats avec ce montage là je suis a bout de force et je solicite votre aide :
pic18f4550 + module YG521
le pic ne le vois pas sur son bus I2C je l ai testé sur arduino et l arduino le detecte donc mon yg521 marche
voilà mon ti code
#define MPU6050_ADDRESS 0b11010000 // Address with end write bit
#define MPU6050_RA_XG_OFFS_TC 0x00 //[7] PWR_MODE, [6:1] XG_OFFS_TC, [0] OTP_BNK_VLD
#define MPU6050_RA_YG_OFFS_TC 0x01 //[7] PWR_MODE, [6:1] YG_OFFS_TC, [0] OTP_BNK_VLD
#define MPU6050_RA_ZG_OFFS_TC 0x02 //[7] PWR_MODE, [6:1] ZG_OFFS_TC, [0] OTP_BNK_VLD
#define MPU6050_RA_X_FINE_GAIN 0x03 //[7:0] X_FINE_GAIN
#define MPU6050_RA_Y_FINE_GAIN 0x04 //[7:0] Y_FINE_GAIN
#define MPU6050_RA_Z_FINE_GAIN 0x05 //[7:0] Z_FINE_GAIN
#define MPU6050_RA_XA_OFFS_H 0x06 //[15:0] XA_OFFS
#define MPU6050_RA_XA_OFFS_L_TC 0x07
#define MPU6050_RA_YA_OFFS_H 0x08 //[15:0] YA_OFFS
#define MPU6050_RA_YA_OFFS_L_TC 0x09
#define MPU6050_RA_ZA_OFFS_H 0x0A //[15:0] ZA_OFFS
#define MPU6050_RA_ZA_OFFS_L_TC 0x0B
#define MPU6050_RA_XG_OFFS_USRH 0x13 //[15:0] XG_OFFS_USR
#define MPU6050_RA_XG_OFFS_USRL 0x14
#define MPU6050_RA_YG_OFFS_USRH 0x15 //[15:0] YG_OFFS_USR
#define MPU6050_RA_YG_OFFS_USRL 0x16
#define MPU6050_RA_ZG_OFFS_USRH 0x17 //[15:0] ZG_OFFS_USR
#define MPU6050_RA_ZG_OFFS_USRL 0x18
#define MPU6050_RA_SMPLRT_DIV 0x19
#define MPU6050_RA_CONFIG 0x1A
#define MPU6050_RA_GYRO_CONFIG 0x1B
#define MPU6050_RA_ACCEL_CONFIG 0x1C
#define MPU6050_RA_FF_THR 0x1D
#define MPU6050_RA_FF_DUR 0x1E
#define MPU6050_RA_MOT_THR 0x1F
#define MPU6050_RA_MOT_DUR 0x20
#define MPU6050_RA_ZRMOT_THR 0x21
#define MPU6050_RA_ZRMOT_DUR 0x22
#define MPU6050_RA_FIFO_EN 0x23
#define MPU6050_RA_I2C_MST_CTRL 0x24
#define MPU6050_RA_I2C_SLV0_ADDR 0x25
#define MPU6050_RA_I2C_SLV0_REG 0x26
#define MPU6050_RA_I2C_SLV0_CTRL 0x27
#define MPU6050_RA_I2C_SLV1_ADDR 0x28
#define MPU6050_RA_I2C_SLV1_REG 0x29
#define MPU6050_RA_I2C_SLV1_CTRL 0x2A
#define MPU6050_RA_I2C_SLV2_ADDR 0x2B
#define MPU6050_RA_I2C_SLV2_REG 0x2C
#define MPU6050_RA_I2C_SLV2_CTRL 0x2D
#define MPU6050_RA_I2C_SLV3_ADDR 0x2E
#define MPU6050_RA_I2C_SLV3_REG 0x2F
#define MPU6050_RA_I2C_SLV3_CTRL 0x30
#define MPU6050_RA_I2C_SLV4_ADDR 0x31
#define MPU6050_RA_I2C_SLV4_REG 0x32
#define MPU6050_RA_I2C_SLV4_DO 0x33
#define MPU6050_RA_I2C_SLV4_CTRL 0x34
#define MPU6050_RA_I2C_SLV4_DI 0x35
#define MPU6050_RA_I2C_MST_STATUS 0x36
#define MPU6050_RA_INT_PIN_CFG 0x37
#define MPU6050_RA_INT_ENABLE 0x38
#define MPU6050_RA_DMP_INT_STATUS 0x39
#define MPU6050_RA_INT_STATUS 0x3A
#define MPU6050_RA_ACCEL_XOUT_H 0x3B
#define MPU6050_RA_ACCEL_XOUT_L 0x3C
#define MPU6050_RA_ACCEL_YOUT_H 0x3D
#define MPU6050_RA_ACCEL_YOUT_L 0x3E
#define MPU6050_RA_ACCEL_ZOUT_H 0x3F
#define MPU6050_RA_ACCEL_ZOUT_L 0x40
#define MPU6050_RA_TEMP_OUT_H 0x41
#define MPU6050_RA_TEMP_OUT_L 0x42
#define MPU6050_RA_GYRO_XOUT_H 0x43
#define MPU6050_RA_GYRO_XOUT_L 0x44
#define MPU6050_RA_GYRO_YOUT_H 0x45
#define MPU6050_RA_GYRO_YOUT_L 0x46
#define MPU6050_RA_GYRO_ZOUT_H 0x47
#define MPU6050_RA_GYRO_ZOUT_L 0x48
#define MPU6050_RA_EXT_SENS_DATA_00 0x49
#define MPU6050_RA_EXT_SENS_DATA_01 0x4A
#define MPU6050_RA_EXT_SENS_DATA_02 0x4B
#define MPU6050_RA_EXT_SENS_DATA_03 0x4C
#define MPU6050_RA_EXT_SENS_DATA_04 0x4D
#define MPU6050_RA_EXT_SENS_DATA_05 0x4E
#define MPU6050_RA_EXT_SENS_DATA_06 0x4F
#define MPU6050_RA_EXT_SENS_DATA_07 0x50
#define MPU6050_RA_EXT_SENS_DATA_08 0x51
#define MPU6050_RA_EXT_SENS_DATA_09 0x52
#define MPU6050_RA_EXT_SENS_DATA_10 0x53
#define MPU6050_RA_EXT_SENS_DATA_11 0x54
#define MPU6050_RA_EXT_SENS_DATA_12 0x55
#define MPU6050_RA_EXT_SENS_DATA_13 0x56
#define MPU6050_RA_EXT_SENS_DATA_14 0x57
#define MPU6050_RA_EXT_SENS_DATA_15 0x58
#define MPU6050_RA_EXT_SENS_DATA_16 0x59
#define MPU6050_RA_EXT_SENS_DATA_17 0x5A
#define MPU6050_RA_EXT_SENS_DATA_18 0x5B
#define MPU6050_RA_EXT_SENS_DATA_19 0x5C
#define MPU6050_RA_EXT_SENS_DATA_20 0x5D
#define MPU6050_RA_EXT_SENS_DATA_21 0x5E
#define MPU6050_RA_EXT_SENS_DATA_22 0x5F
#define MPU6050_RA_EXT_SENS_DATA_23 0x60
#define MPU6050_RA_MOT_DETECT_STATUS 0x61
#define MPU6050_RA_I2C_SLV0_DO 0x63
#define MPU6050_RA_I2C_SLV1_DO 0x64
#define MPU6050_RA_I2C_SLV2_DO 0x65
#define MPU6050_RA_I2C_SLV3_DO 0x66
#define MPU6050_RA_I2C_MST_DELAY_CTRL 0x67
#define MPU6050_RA_SIGNAL_PATH_RESET 0x68
#define MPU6050_RA_MOT_DETECT_CTRL 0x69
#define MPU6050_RA_USER_CTRL 0x6A
#define MPU6050_RA_PWR_MGMT_1 0x6B
#define MPU6050_RA_PWR_MGMT_2 0x6C
#define MPU6050_RA_BANK_SEL 0x6D
#define MPU6050_RA_MEM_START_ADDR 0x6E
#define MPU6050_RA_MEM_R_W 0x6F
#define MPU6050_RA_DMP_CFG_1 0x70
#define MPU6050_RA_DMP_CFG_2 0x71
#define MPU6050_RA_FIFO_COUNTH 0x72
#define MPU6050_RA_FIFO_COUNTL 0x73
#define MPU6050_RA_FIFO_R_W 0x74
#define MPU6050_RA_WHO_AM_I 0x75
#define I2C_WRITE 0
#define I2C_READ 1
#define VITESSEI2C 1 //1 pour 100khz, 0 pour 400khz
#define BRGI2C 0x0C//
//###### usb declaration
unsigned char readbuff[64] absolute 0x500; // Buffers should be in USB RAM, please consult datasheet
unsigned char writebuff[64] absolute 0x540;
char cnt;
char kk;
char kk1;
///#################################### injection code I2C
void i2c_Wait(void){
while ( ( SSPCON2 & 0x1F ) || ( SSPSTAT & 0x04 ) );
void i2c_Start(void)
i2c_Wait();
SSPCON2.SEN=1;
void i2c_Restart(void){
i2c_Wait();
SSPCON2.RSEN=1;
void i2c_Stop(void)
i2c_Wait();
SSPCON2.PEN=1;
void i2c_Write(unsigned char data1)
i2c_Wait();
SSPBUF = data1;
void i2c_Address(unsigned char address, unsigned char mode)
unsigned char l_address;
l_address=address<<1;
l_address+=mode;
i2c_Wait();
SSPBUF = l_address;
unsigned char i2c_Read1(unsigned char ack)
i2c_Wait();
SSPCON2.RCEN=1;
i2c_Wait();
i2cReadData = SSPBUF;
i2c_Wait();
if ( ack ) SSPCON2.ACKDT=0; // Ack
else SSPCON2.ACKDT=1; // NAck
SSPCON2.ACKEN=1; // send acknowledge sequence
return( i2cReadData );
/// fin des fonction IC2########################
void interrupt(){
if (PIR1.CCP1IF ==1)
PIR1.CCP1IF =0;
kk=1;
if (PIR2.CCP2IF ==1)
PIR2.CCP2IF =0;
if (PORTC.RC1==0){
CCP2CON=0B00000101;
kk1=3;
else
CCP2CON=0B00000100;
kk1=4;
USB_Interrupt_Proc();
void main(void)
unsigned short take ;
ADCON1 = 0b00001111;
CMCON=0x07;
TRISB = 0xFF;
TRISC = 0b11111110;
PORTC= 0x00;
TRISD=0;
PIE1.CCP1IE=1;
PIE2.CCP2IE=1;
CCP1CON=0B00000101;
PORTD.RD3=1;
SSPSTAT=SSPSTAT&0x3F;
SSPCON1=0x00;
SSPCON2=0x00;
SSPSTAT.SMP=VITESSEI2C;
SSPCON1.SSPEN=1;
SSPCON1.SSPM0=0;//1000
SSPCON1.SSPM1=0;//1000
SSPCON1.SSPM2=0;//1000
SSPCON1.SSPM3=1;//1000
SSPADD=BRGI2C;
HID_Enable(&readbuff,&writebuff);
Delay_ms(1000);
kk=0;
kk1=0;
if (PORTC.RC1==0) {
writebuff[8]=233;
writebuff[7]=233;
writebuff[6]=233;
writebuff[5]=233;
writebuff[4]=233;
writebuff[3]=233;
writebuff[2]=233;
writebuff[1]=233;
PORTD=0;
writebuff[0]=233;
while(!HID_Write(&writebuff,64));
CCP1CON=0B00000101;
else
writebuff[8]=235;
writebuff[7]=235;
writebuff[6]=235;
writebuff[5]=235;
writebuff[4]=235;
writebuff[3]=235;
writebuff[2]=235;
writebuff[1]=235;
PORTD=0;
writebuff[0]=233;
CCP2CON=0B00000100;
while(1){
if (kk1==3)
writebuff[8]=230;
writebuff[7]=230;
writebuff[6]=230;
writebuff[5]=230;
writebuff[4]=230;
writebuff[3]=230;
writebuff[2]=230;
writebuff[1]=230;
PORTD=0;
writebuff[0]=233;
kk1=0;
delay_ms(500);
if (kk1==4){
writebuff[8]=227;
writebuff[7]=227;
writebuff[6]=227;
writebuff[5]=227;
writebuff[4]=227;
writebuff[3]=227;
writebuff[2]=227;
writebuff[1]=227;
PORTD=0;
writebuff[0]=233;
kk1=0;
if (kk==1){
writebuff[8]=PORTB.RB7;
writebuff[7]=PORTB.RB6;
writebuff[6]=PORTB.RB5;
writebuff[5]=PORTB.RB4;
writebuff[4]=PORTB.RB3;
writebuff[3]=PORTB.RB2;
// writebuff[2]=PORTB.RB1;
// writebuff[1]=PORTB.RB0;
writebuff[0]=205;
kk=0;
if(HID_Read()){
if (readbuff[0]==0){
PORTD.RD0=readbuff[1];
PORTD.RD1=readbuff[2];
PORTD.RD2=readbuff[3];
PORTD.RD3=readbuff[4];
PORTD.RD4=readbuff[5];
PORTD.RD5=readbuff[6];
PORTD.RD6=readbuff[7];
PORTD.RD7=readbuff[8];
if (readbuff[0]==233){
PORTD=0;
writebuff[0]=233;
if (readbuff[0]==133){
take=0;
// initialize I2C communication
i2c_Start(); // send Start
i2c_Address(MPU6050_ADDRESS, I2C_WRITE); // Send slave address - write operation
i2c_Write(MPU6050_RA_WHO_AM_I); // Set register for servo 0
i2c_Restart(); // Restart
i2c_Address(MPU6050_ADDRESS, I2C_READ); // Send slave address - read operation
take = i2c_Read1(0); // Read one byte // issue I2C start signal
i2c_Stop();
writebuff[1]=take;
writebuff[0]=153;
if (take==0x68)
PORTD.RD0=1;
PORTD.RD1=0;
else
PORTD.RD0=0;
PORTD.RD1=1;
j utilise un quartz de 20 mhz et plldiv=5 et CPUDIV=osc1_pll2
et des resistance de pull-up sur le bus de 3.6k
Merci de votre aide
