Running Leg Mechanism
9 réponses à ce sujet
#1 TNERA
TNERA
  • 138 messages
Posté 11 septembre 2022 - 10:57
Hi All,
I am still in search of a good mechanism for the TRR#2022!  ;)
I was not able to get the 5-bar mechanism (with 2-3 servos) to work well enough to lift the robot chassis reliably. I do believe elastic bands would have helped considerably. However it would have required a significant adjustment to my design.
My design thoughts have wandered. Now I am looking at a running mechanism that was used in a scholarly paper.  It will use two parallel linkages that are driven by a rotating motor. The motion is enough to move and lift the leg of the mechanism. I will be trying to use a single actuator per leg. I will be using 3D printed parts and recycled printer motors, this is part of my overall design philosophy of simplicity, reuse, and recycling of commonly available parts.
Here is what I have so far:
The picture does depict the initial foot 'path'. With some adjustment, the current prototype has a more typical leveled profile.
Here is a video of it in motion:
I am now working to convert this 2D prototype into something more 3D to handle the side loads.
Any thought or suggestions?  you guys are great for that! :)
#2 Oracid
Posté 11 septembre 2022 - 01:28
With this type of mechanism, you will definitely win at the TRR.
You could even use just one motor for all 4 legs, with a 180° phase shift between front and back, and right and left.
For the straight line, it's the fastest !
Very original, the shoe.
#3 TNERA
TNERA
  • 138 messages
Posté 13 septembre 2022 - 08:18
Thanks for the encouragement!
I think I am still a very long way from winning, ha ha!  Frist I have to get 4 feet on the ground. So we will see.
I am working on making it 3D now. Updates soon, I hope.
#4 TNERA
TNERA
  • 138 messages
Posté 17 septembre 2022 - 09:30
Here is an update,
I have built it out to be thicker, more 3D.  Also starting to fit it for the driving motor.  Here I am using a 12v brushed motor from a recycled printer. It is connected with a 3D printed gearbox for reduction and torque.
Here is a short video of it in motion.
The motor really 'throws' the leg, making a bit of motion.  That motion will be challenging. There will be a second leg that is out of phase, this should hopefully reduce that motion.
Next steps - keep building out for stability, mounting the motor, improving the joints/connectors.
#5 Mike118
  • 10 303 messages
Posté 18 septembre 2022 - 01:38
Will we see you at TRR2022 ? =)
#6 TNERA
TNERA
  • 138 messages
Posté 25 septembre 2022 - 11:51
I sure hope so, @Mike118
but first I need to get a working robot!  8)
here is my latest update.  I am working on getting the motor set with the legs.  Also doing minor improvement to the leg components.
yes, it is running backwards, I flipped the motor at the last minute. haha
#7 TNERA
TNERA
  • 138 messages
Posté 03 octobre 2022 - 01:32
Hi all,
here is a quick update for the progress this week.  Design on the leg is looking complete.  It is still very prototype, in the video only 1 leg is the current version, the skinny leg is older.  I was able to hack-together a mount for the motor/gearbox. It is still running off of 'shore power' - a wall plug.
here is a quick video:
#8 Oracid
Posté 03 octobre 2022 - 06:29
Almost 3500 views in one day.
Congratulations.  :drinks:
#9 TNERA
TNERA
  • 138 messages
Posté 04 octobre 2022 - 09:13
Thanks!  I was surprised myself with the number of views.
This might be a topic for another board (YouTube algorithms?). There is some crazy stuff going on with YouTube now with the 'shorts' format.
@oracid, I know you have a lot more experiences here. maybe in a different thread?
#10 Oracid
Posté 04 octobre 2022 - 11:11
https://www.robot-ma...ts-sur-youtube/
