ups-boards
1792 réponses à ce sujet
#1741 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 08:15
The speaker and microphone would be the most interesting to test :yes:
#1742 garfield2142
garfield2142
  • 379 messages
Posté 15 mars 2026 - 08:54
picoTTS was definitely one of them, I'll take a look.
#1743 garfield2142
garfield2142
  • 379 messages
Posté 15 mars 2026 - 10:06
#1744 garfield2142
garfield2142
  • 379 messages
Posté 15 mars 2026 - 10:10
I downloaded the packages manually with wget and installed the dependencies separately, and the script then ran fine without problems, I didn't need to remove anything from the apt install list. The speaker is really not that loud. I'm sitting in a quiet room right next to it, but if there's any noise, you have no chance of understanding what it says. Very boxy sounding.
#1745 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 10:27
Oh wow it works!!
#1746 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 10:28
Garfield The Man!! :flexed_biceps::flexed_biceps:
#1747 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 10:29
Is it possible to make it louder? Or to use a different speaker
#1748 garfield2142
garfield2142
  • 379 messages
Posté 15 mars 2026 - 10:41
It's at 100% on alsamixer. I'll have to try to crimp a new connector on the 3W speakers that we love and use, and test that as well.
#1749 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 11:31
Hm. I'm not sure if alsamixer is still used
#1750 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 11:32
The fusionhat uses pulseaudio, it might bypass alsa
#1751 garfield2142
garfield2142
  • 379 messages
Posté 15 mars 2026 - 17:30
This is going to be so much harder to get working than I initially thought. The hat uses GPIOS 19, 18, 21, 20 for audio. Vigiclient claims exclusive control over every GPIO. If you toggle GPIO 21, you can generate really bad smells with the speaker. It's a challenge to deny vigiclient access to the GPIOs that the fusionhat uses.
#1752 firened
firened
  • 2 124 messages
Posté 15 mars 2026 - 17:48
Interesting
#1753 Mike118
  • 12 871 messages
Posté 15 mars 2026 - 20:54
@fire_ned @Garfield2142 I have received my last revision of the ups with the new charge ic I will test it this week. If all is going well I plan to send it one pcs to you for more final testings :)
#1754 firened
firened
  • 2 124 messages
Posté 16 mars 2026 - 08:25
You could already send one, we can help test. It'll be quicker.
There are about 5 makers waiting
#1755 Mike118
  • 12 871 messages
Posté 16 mars 2026 - 10:59
I can also send 3 like the one I already sent you firened if you think this can be ok.
#1756 firened
firened
  • 2 124 messages
Posté 16 mars 2026 - 14:47
The previous revision could be used i guess. Needs a resistor soldered and then it may not charge when the pi is off. Other than that it worked well.
I don't have the capacity to solder that though.
#1757 ralph_62550
ralph_62550
  • 11 messages
Posté 20 mars 2026 - 21:58
I could to the soldering, no problem.
#1758 firened
firened
  • 2 124 messages
Posté 30 mars 2026 - 08:32
@blacksmith CoG data is here
#1759 garfield2142
garfield2142
  • 379 messages
Posté 30 mars 2026 - 16:54
I was looking at the Pisugar UPSes datasheet, and this part is kinda goofy ... "voltage in mA" xd
#1760 garfield2142
garfield2142
  • 379 messages
Posté 30 mars 2026 - 18:35
The Sunfounder UPS is way too hard to get working, even if you install it on a fresh raspbian image without vigibot. Even their official installation script requires "hacks" to get working, so I advise not to get it. The audio uses up precious GPIO pins, and the speaker isn't loud enough to be useful if you're not in a dead silent room right next to it. I didn't bother to get the microphone or motors working, the whole UPS is just fighting against me every little step of the way. Stay away from it.
I ordered the pisugar 3 plus to test next.
https://www.pisugar....aspberry-pi-ups
