ups-boards
#1541
Posté 30 août 2024 - 11:09
#1542
Posté 05 septembre 2024 - 15:24
Symptom:
When the battery runs empty, the electronics turn on and off repeatedly up to ~2x per second.
For «WalterJakob» vigiUPS v1:
clicking noise, LEDs turn on and off. Sometimes a servo moves with a click.
For «Lucky» vigiUPS v2:
The motor turned on clicks until i added a low-voltage cutoff.
Problem:
1) Battery voltage drops under load to 2.4V -> the 18650 PCM cuts off.
2) Battery voltage recovers to ~2.8V -> the PCM turns on.
3) this repeats for 5-20 min.
possible solutions:
1) low voltage cutoff at 3V with release voltage of 3.5V. (lithium take damage when below 3V.)
2) if power is lost once, the electronics should not turn on again automatically.
#1546
Posté 05 septembre 2024 - 20:29
#1548
Posté 22 septembre 2024 - 12:53
Can someone check if i made a mistake?:
Short: UPS turns off sporadically because its poweroff pin is connected to GPIO 6 (pull-up on boot) !?!?
Long:
Expected: hold push button for 3s to turn UPS on or off. With "auto-ups" switch: off.
Problem: UPS turns off during boot or after up to 1h.
https://wiki.geekworm.com/UPS3
#1552
Posté 22 septembre 2024 - 13:06
INPUT (50k pull-up)
> GPIOs up to 8: default state is 1 (HIGH, or close to 3.3V).
> GPIOs 9 to 27: default state is 0 (LOW, or close to 0V).
<https://roboticsback...erry_Pis_GPIOs>
#1554
Posté 22 septembre 2024 - 13:13
The UPS poweroff pin is pulled down and pulled up at the same time.
Sporadically it will be HIGH long enough to turn off the UPS.
I removed the solder bridge on AluBot and it has not turned off anymore since.
Can this be true,
Bad design choice from geekworm,
Can someone confirm?
Who else has a geekworm v3 @Garfield2142 @Serveurperso ?
#1555
Posté 22 septembre 2024 - 22:45
#1556
Posté 23 septembre 2024 - 19:28
-fix low voltage on-off loop (discussed above).
-no fan necessary.
-3.3V active buzzer onboard.
-sturdy on off through hole (or similar) switch or push button (not SMD, it breaks off too easily).
-breakout only 10-15 gpio servo connectors would be sufficient (instead every gpio).
(-might not work: onboard LED at the front for driving?)
(-a single LED (or rotating warning light) at the rear-side, that can be configured to PWM blink to show when someone is controlling the robot.)
#1559
Posté 04 octobre 2024 - 17:47
A top pcb with leds and audio chip and a small screen.
A pcb for the ups with pins to connect servos and other stuff.
A middle pcb for the motor driver and mounting the pololu motors on it...
#1560
Posté 02 décembre 2024 - 19:56
