ups-boards
1792 réponses à ce sujet
#1581 firened
firened
  • 2 124 messages
Posté 09 janvier 2025 - 19:27
Looks like it's a charger only, Not an ups, oops.
#1582 firened
firened
  • 2 124 messages
Posté 16 janvier 2025 - 18:19
Another suggestion:
- if it has an on off switch, it should cut power to the servos too, but still allow charging. (Servos drain my battery within 5 days when robot is off.)
#1583 Mike118
  • 12 871 messages
Posté 17 janvier 2025 - 12:21
This is already the case on vigiups v2.
#1584 garfield2142
garfield2142
  • 379 messages
Posté 18 janvier 2025 - 11:54
https://www.robot-ma...y=ups&results=3 Is this the vigiUPS v2?
#1585 Mike118
  • 12 871 messages
Posté 18 janvier 2025 - 14:49
Yes. Missing pictures because I don't want to promote it too much I am working on v3.
#1586 garfield2142
garfield2142
  • 379 messages
Posté 18 janvier 2025 - 18:24
I was about to ask for a picture of it to see what it looks like, and maybe buy one
#1587 Mike118
  • 12 871 messages
Posté 18 janvier 2025 - 19:06
If you can wait few month I recommend to wait next version. Else I can send you few pictures of this v2.
#1588 garfield2142
garfield2142
  • 379 messages
Posté 19 janvier 2025 - 09:36
Yes, I'd like some pictures please. Are there any in stock?
#1589 firened
firened
  • 2 124 messages
Posté 19 janvier 2025 - 18:59
Not so great ideas:
- charging to 4.0V only, and discharging to 3.2V (no lower than 3V) would increase battery lifetime. Might not be worth or possible to implement though..
- a rotation base & tilt mechanism like they use on PTZ cameras would be sturdy - but reduce movement speed and increase risk of it getting stuck..
#1590 firened
firened
  • 2 124 messages
Posté 19 janvier 2025 - 19:49
(- most fuel gauges need constant battery voltage for the % value to work.)
#1591 firened
firened
  • 2 124 messages
Posté 30 juin 2025 - 14:02
@Mike118 yes i think the "battery runs out behavior" was the main problem.
I added a large hysteresis low voltage cutoff (i don't remember the exact values, maybe something like: Off: <3V. On: >3,5V)
#1592 Mike118
  • 12 871 messages
Posté 30 juin 2025 - 14:05
We will need to test this and verify that the new design solve this problem :)
#1593 garfield2142
garfield2142
  • 379 messages
Posté 01 juillet 2025 - 11:34
Testing power usage with a variable power supply, on a raspberry pi 4
#1594 garfield2142
garfield2142
  • 379 messages
Posté 01 juillet 2025 - 11:38
Going down to 3.5 volts
#1595 garfield2142
garfield2142
  • 379 messages
Posté 01 juillet 2025 - 11:40
Limiting current to 3.0A then 2.5A, which crashes the pi.
#1596 firened
firened
  • 2 124 messages
Posté 01 juillet 2025 - 12:16
Nice power supply :yes:
#1597 firened
firened
  • 2 124 messages
Posté 01 juillet 2025 - 12:17
Crazy to see it actually using 1,5A on idle.... No wonder 1A chargers aren't sufficient.
#1598 firened
firened
  • 2 124 messages
Posté 01 juillet 2025 - 12:22
Yeah you got it right.
The reason why Vigibot shows 3,2V while the power supply shows 3,5V is the resistance of the thin cables and ... how many? 3 dupont plugs?
That easily adds considerable resistance.
In your case: R = U / I = 0.3V / 1.5A = 0.2 [U+03A9]
#1599 firened
firened
  • 2 124 messages
Posté 01 juillet 2025 - 12:24
Yeah 3A is too low. However most 18650 have a 3A PCM, but since there's 2 cells in parallel you'll get 6A max.
#1600 garfield2142
garfield2142
  • 379 messages
Posté 01 juillet 2025 - 13:01
I made my own dupont terminated cables from a PC power supply, they are thick compared to the cheap chinese cables. (They are so cheap, they use iron, and can be picked up with a magnet.) For my next test I'll measure a raspberry pi 3b+.
