:squared_sos:|help-questions
#9502
Posté 08 octobre 2022 - 03:10
i'm making a 6s1p battery with LG MJ1's as i will never consume more than 10a at anytime, and capacity and price is good for me.
with a maximum of a 5a load, (motor of my robot at full load, lights, and everything else) it will last about 4 hours at the absolute minimum.
https://www.amazon.c...H0U4TGVUQ&psc=1 here's the balancer + bms that I am thinking of using.
it'll support to 10s
(in case I ever need to expand)
#9503
Posté 08 octobre 2022 - 03:43
18650 are usually below 3Ah.
S multiplies Voltage [V];
P multiplies Capacity [Ah].
your 6S1P will have 25.2V like you said. but still only 3Ah.
if your motor uses 5A @ 25.2V, then your battery will last 24minutes.
it's often easier to expand with more in parallel #P, because the voltage #S will be kind of fixed with your chosen motors.
#9504
Posté 08 octobre 2022 - 03:48
how many more cells do you think I should add in parallel? i still need to maintain that voltage. i was thinking maybe a few hours at 2 amps (motor max pulls 4, 5 added with the electronics and lighting)
6s4p sounds good.
@fire_ned the bms and balancer should work with that config right?
#9515
Posté 17 octobre 2022 - 04:01
Yes servomotor signal pin can be directly hooked up to the raspberry pi gpios.
By default gpio 5 and 6 are the one used to move pan and tilt servo for the head of your robot.
I need to know what kind of hardware you are using and how it is connected on your robot in order to help you.
You can drive à lot of things on vigibot you just need to know how to configure the interface. Here is a message explaining how to configure a lot of things for " advanced users " https://www.robot-ma...ds/#entry115626 but don't worry if you are new to this we will completely help you.
#9516
Posté 18 octobre 2022 - 02:20
#9517
Posté 18 octobre 2022 - 04:29
#9518
Posté 18 octobre 2022 - 08:56
#9520
Posté 08 décembre 2022 - 07:38
9 utilisateur(s) li(sen)t ce sujet
0 members, 9 guests, 0 anonymous users
