Wave HC et Servo
4 réponses à ce sujet
#1 dydylan
dydylan
  • 66 messages
Posté 01 septembre 2012 - 07:11
Bonjour, alors voila mon robot utilise la bibliothèque Wave HC pour faire chanter mon robot :music2:, mais voila je veux aussi faire bouger 5 servomoteurs en même temps que la musique mais ça marche pas...
je vous montre le code et l'erreur:
 * This example plays every .WAV file it finds on the SD card in a loop
#include <WaveHC.h>
#include <WaveUtil.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the volumes root directory
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
 * Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
// Function definitions (we define them here, but the code is below)
void play(FatReader &dir);
//////////////////////////////////// SETUP
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
  putstring_nl("\nWave test!");  // say we woke up!
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(FreeRam());
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    error("Card init. failed!");  // Something went wrong, lets print out why
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {   // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                           // we found one, lets bail
  if (part == 5) {                     // if we ended up not finding one  <img src='http://www.robot-maker.com/forum/public/style_emoticons/<#EMO_DIR#>/sad.gif' class='bbc_emoticon' alt=':(' />
    error("No valid FAT partition!");  // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(), DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    error("Can't open root dir!");      // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Files found (* = fragmented):");
  // Print out all of the files in all the directories.
  root.ls(LS_R | LS_FLAG_FRAGMENTED);
//////////////////////////////////// LOOP
  root.rewind();
  play(root);
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
/////////////////////////////////// HELPERS
 * print error message and halt
void error_P(const char *str) {
  PgmPrint("Error: ");
  SerialPrint_P(str);
  sdErrorCheck();
  while(1);
 * print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void) {
  if (!card.errorCode()) return;
  PgmPrint("\r\nSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  PgmPrint(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
 * play recursively - possible stack overflow if subdirectories too nested
void play(FatReader &dir) {
  FatReader file;
  while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
    // Skip it if not a subdirectory and not a .WAV file
    if (!DIR_IS_SUBDIR(dirBuf)
         && strncmp_P((char *)&dirBuf.name[8], PSTR("WAV"), 3)) {
      continue;
    Serial.println();            // clear out a new line
    for (uint8_t i = 0; i < dirLevel; i++) {
       Serial.write(' ');       // this is for prettyprinting, put spaces in front
    if (!file.open(vol, dirBuf)) {        // open the file in the directory
      error("file.open failed");          // something went wrong
    if (file.isDir()) {                   // check if we opened a new directory
      putstring("Subdir: ");
      printEntryName(dirBuf);
      Serial.println();
      dirLevel += 2;                      // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
    else {
      // Aha! we found a file that isnt a directory
      putstring("Playing ");
      printEntryName(dirBuf);              // print it out
      if (!wave.create(file)) {            // Figure out, is it a WAV proper?
        putstring(" Not a valid WAV");     // ok skip it
      } else {
        Serial.println();                  // Hooray it IS a WAV proper!
        wave.play();                       // make some noise!
        uint8_t n = 0;
        while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
          putstring(".");
          if (!(++n % 32))Serial.println();
          delay(100);
        sdErrorCheck();                    // everything OK?
        // if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
erreur
daphc.cpp: In function 'void loop()':
daphc.pde:-1: error: a function-definition is not allowed here before '{' token
daphc.pde:-1: error: expected `}' at end of input
définition de mon robot "un petit bout de vie dans une boite de conserve"
#2 R1D1
  • 1 212 messages
Posté 01 septembre 2012 - 08:45
  root.rewind();
  play(root);
Ou sont les accolades d'ouverture et de fermeture de la fonction loop() ?
#3 dydylan
dydylan
  • 66 messages
Posté 02 septembre 2012 - 09:51
merci pour ta réponse R1D1 mais quand je le fait il y a une autre erreur
sketch_sep02a.cpp: In function 'void loop()':
sketch_sep02a:106: error: a function-definition is not allowed here before '{' token
sketch_sep02a:175: error: expected `}' at end of input
#4 R1D1
  • 1 212 messages
Posté 02 septembre 2012 - 12:24
C'est bien de nous donner les lignes de l'erreur, mais vu que le code ne les présente pas, c'est pas très utile.
Quelques commentaires pour essayer de te faire comprendre l'erreur :
      root.rewind();
      play(root);
/* Fin loop */
{ //<-- ? A quoi sert cette accolade ouvrante ?
// Deux boucles hors de la fonction loop, je doute qu'elles soient exécutées un jour ni que le compilo aime ça ...
Et sinon : http://bit.ly/OI9ic6
Utiliser la fonction loop() - Anglais
#5 dydylan
dydylan
  • 66 messages
Posté 15 septembre 2012 - 01:34
#include <WaveHC.h>
#include <Servo.h>
  uint8_t part;
  root.rewind();
  play(root);
  SerialPrint_P(str);
  sdErrorCheck();
  while(1);
  PgmPrint(", ");
  while(1);
  FatReader file;
      continue;
      Serial.println();
      dirLevel -= 2;
    else {
      } else {
        uint8_t n = 0;
          putstring(".");
          delay(100);
donc comme vous pouvez voir j'ai fait les modifications qui s'imposer, mais mais ça ne marche toujours pas, voici l'erreur:
Servo\Servo.cpp.o: In function `__vector_11':
C:\Documents and Settings\Dylan\Mes documents\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Servo/Servo.cpp:103: multiple definition of `__vector_11'
WaveHC\WaveHC.cpp.o:C:\Documents and Settings\Dylan\Mes documents\Downloads\arduino-1.0-windows\arduino-1.0\libraries\WaveHC/WaveHC.cpp:41: first defined here
Merci de m'aider ^_^
