Au bistrot du coin ...
816 réponses à ce sujet
#641 Melmet
  • 1 527 messages
Posté 11 novembre 2021 - 09:27
Non, je ne sais pas !
Tu pourrais nous faire une petite présentation ?
Pas un tutorial, juste une ou deux vidéos qui montreraient des possibilités équivalentes à l'HuskyLens. En particulier, le suiveur de ligne.
Moi non, je pourrais pas car j'en ai pas encore acheter.
Mais j'ai déjà vu des videos la dessus: ESP32 CAM  ; Suivre objets
Y a aussi OpenCV....
#642 Oracid
Posté 12 novembre 2021 - 08:21
Tu sais que l'ESP32 Cam fait cela aussi?
J'ai posé la question au YouTuber DroneBot pour savoir quelle différence il y avait entre une ESP32 Cam et un HuskyLens, voici sa réponse.
They are by no means the same. While the 32-bit ESP32-CAM is capable of simple recognition tasks, it has nowhere the power of the 64-bit Kendryte K210.  It certainly can't recognize a cow, and programming it to track an object is difficult (but not impossible).
Also, the HuskyLens is meant to be used as an external sensor, while the ESP32-CAM is a microcontroller with I/O ports, WiFi and Bluetooth. So they aren't even really in the same category.
A better comparison would be to compare the HuskyLens with the Pixy 2 camera, a much older technology. The HuskyLens is much more powerful, and cheaper too.
Not to mention that the ESP32-CAM doesn't come with a 2-inch display, which is where a lot of the cost of the HuskyLens is incorporated.
But your friend is correct about one thing, the ESP32-CAM is much cheaper. You can buy five of them for the price of one HuskyLens. But, again, you are really comparing two different categories of device.
The real beauty of a device like the HuskyLens is what I referred to at the beginning of the video - it's an "edge computing" device. So it does all the hard work, making it easier for the microcontroller.
I'll be reviewing some more similar sensors that use the Kendryte K210, these are from Seeedstudio, and they bring out many of the K210 I/O pins. I have three of them, and one of them even has an ESP-32 onboard for wireless connectivity.
#643 Melmet
  • 1 527 messages
Posté 14 novembre 2021 - 08:39
Autant pour moi , au moins comme cela on sais :)
#644 Oracid
Posté 14 novembre 2021 - 14:13
J'ai regardé quelques vidéos sur l'ESP32 Cam. Alors, c'est vrai, on peut faire de la reconnaissance faciale, du tracking et même du suivi de ligne.
Mais l'ESP32, c'est un 32 bit, comme son nom l'indique, et c'est un microcontrôleur, pas un capteur.
Alors que le Kendrite K210 est un 64 bit, spécialisé dans le son et l'image. Et ça, ça change tout dans la facilité d'utilisation.
J'ai vu d'autres vidéos, depuis, et c'est au delà de ce que l'on peut imaginer.
Quand je dis que je pourrais mettre le HuskyLens sur mon quadrupède, à la prochaine TRR . . . , c'est parce que aujourd'hui, c'est extrêmement facile à faire avec un simple Nano.
Ceci dit, un quadrupède, ça tangue pas mal, il faudra peut-être que je le mette sur un Gimbal, ce qui serait dommage.
#645 Oracid
Posté 08 décembre 2021 - 15:03
Cela vient de sortir. Une solution pour le positionnement en intérieur. A voir !
https://www.makerfab...a-wideband.html
#646 Melmet
  • 1 527 messages
Posté 08 décembre 2021 - 19:54
HOOOoooo :) C'est exactement ce qu'il me fallait :)
Merci du partage :) :thank_you: :thank_you: :thank_you: :thank_you: :thank_you: :thank_you: :thank_you:
#647 Oracid
Posté 08 décembre 2021 - 20:56
Tu nous donneras des nouvelles, j'espère.
#648 Melmet
  • 1 527 messages
Posté 09 décembre 2021 - 07:44
c'est un projet pro, c'est pas encore pour de suite.
Mais je vais bien reussir a faire joujou avec :)
#649 Oracid
Posté 09 décembre 2021 - 18:42
Attention, ça décoiffe !
#650 Forthman
  • 1 504 messages
Posté 09 décembre 2021 - 20:39
c'est un centre 5 axes sur lequel on a greffé une buse d'imprimante :Koshechka_08:
#651 TNERA
TNERA
  • 138 messages
Posté 22 janvier 2022 - 15:02
Bonjour!
has there been any news about a future Toulouse Robot Race?
I am hopeful!
#652 Oracid
Posté 22 janvier 2022 - 17:56
Bonjour!
I am hopeful!
I contacted them, but without success.
I will contact them again. I hope they are all well.
#653 Melmet
  • 1 527 messages
Posté 14 février 2022 - 08:44
Chenille de tank :
#654 Oracid
Posté 08 avril 2022 - 20:33
Peut-être la solution d'avenir ! Pourquoi choisir entre un roulant ou un volant.
L'intérêt ? Et bien, quand ça roule, ça consomme moins, beaucoup moins !
Et ça vaut ? 89€ !!!  https://xerall.com/f...roduit/modeles/
#655 Melmet
  • 1 527 messages
Posté 09 avril 2022 - 08:47
Mouais, le systeme reste étrange. Je comprend pas a quoi sert la couroie puisque les roue sont plus épaisse...
Mais sinon le principe je dit oui :)
#656 Oracid
Posté 09 avril 2022 - 12:51
Euhhhh, il y a une roue dentée entre chaque paire de roue . . .  :whistle2:
Je pense que c'est juste pour le coté tout terrain, mais sinon il roule sur les roues.
A mon avis, ce principe permet d'économiser du courant sur un sol dur comme un parquet ou du ciment.
Une chenille, c'est bien, mais ça frotte.
#657 Oracid
Posté 28 avril 2022 - 18:36
Le futur, c'est maintenant . . .
#658 Oracid
Posté 15 juin 2022 - 06:42
Je savais que cela existait, mais je ne l'avais jamais vu.
Vous pouvez télécharger les sons, ici : https://oscilloscope...watch.php#album
#659 Melmet
  • 1 527 messages
Posté 15 juin 2022 - 12:15
Mais c'est bon ca :)
J'ai cru reconnaitre DaftPunk à un moment :)
#660 Oracid
Posté 08 juillet 2022 - 13:35
Histoire de causer et de partager.
Quand je pars en vacances, sans Arduino, je m'ennuie un peu, le matin à l'aube, surtout en zone blanche. Oui, je me réveille assez tôt.
Et donc, depuis longtemps, je me suis fait ce petit montage d'un Nano avec un adaptateur que je connecte à mon PC. Cela ne prend pas beaucoup de place dans la valise. D'ailleurs, j'utilise très couramment ce montage à la maison, lorsque je n'ai pas besoin du robot pour tester un programme.
Vous remarquerez le petit bouton poussoir que j'ai soudé entre le GND et la pin 0(RX). Ce n'est pas très orthodoxe, mais ça fonctionne.
J'aime bien maitriser le lancement ou l'arrêt de mon programme. Aujourd'hui, en réel, j'utilise plutôt la pin A0.
Bonne vacances à tous.
Cliquez moi.
