You are welcome.
"Qui veut voyager loin ménage sa monture"
Arduino ?
Soon, I will make a picture with all separate parts and details so it will be easier to you to mount the tank.
Posté 06 octobre 2021 - 12:59
You are welcome.
Arduino ?
Posté 13 octobre 2021 - 10:25
Posté 13 octobre 2021 - 05:04
Bonjour Oracid,
Posté 13 octobre 2021 - 06:16
Very colored !
Good idea for the Lego motors from China ! They are very cheap and powerfull.
Did you command the CADA remote control ?
Posté 18 octobre 2021 - 03:52
Posté 18 octobre 2021 - 08:20
Posté 19 octobre 2021 - 01:05
Posté 19 octobre 2021 - 06:31
So is the height I cut okay or do I have to cut even further along?
You must test with 58mm. If it is ok, then you cut the all thread.
Here a picture. It is the same as before, but bigger.
Don't hesitate to ask, you are welcome.
Click on me.
Posté 29 octobre 2021 - 03:27
Posté 29 octobre 2021 - 05:49
Ah ! Ah ! I am afraid, I don't understand what you want to do.
Anyway, the tank looks good.
When you do an horizontal video, the camera must be too horizontal on your cellular.
Why you don't put here, the links of the videos ?
Posté 29 octobre 2021 - 07:01
I had put auto rotation on the mobile and it looks like the camera hasn't like it.
I wanted to attach them, but since I couldn't I uploaded them to the Drive so I could share them as I haven't uploaded them anywhere else.
To all this, I will obviously reference your designs and I will thank you for your help in my work, for that reason I would to know your full name.
Posté 29 octobre 2021 - 08:06
The idea would be to replicate this platform . . .
Not easy, don't forget a tank has a track. You could do that if this platform is upper the track.
Posté 29 octobre 2021 - 08:53
Exactly! On the tank there will be another platform where it will be and be fixed the wheelchair.
Posté 01 novembre 2023 - 04:13
I guess those trains are made by Alsthom or Bombardier. Please tell me. I used them in my all life when I was working.With nose or without nose ! This is very important ! The problem is for the first step. Then every steps are alyke.Without nose, the tank could be flat, which is easier. With nose, the tank must have an inclined front side, which is heavier, longer and more complex.Please have a look at this video to understand what I mean.
Je voudrais m'aider de votre travail pour fabriquer la structure de mon robot afin qu'il puisse monter des escaliers. Pourriez-vous mentionner les dimensions des chenilles inclinées qu'il y à l'avant de votre robot dans la deuxième vidéo ?
Merci d'avance
Posté 01 novembre 2023 - 06:54
Le petit bras supportant la chenille inclinée fait 17L ( le L=8mm est l'unité Lego ). Cela nous fait donc, entre axes, 16 x 8 = 128mm.
Mais je ne suis pas certain que ce tank soit le meilleur exemple à suivre.
A mon avis, tu devrais plutôt t'inspirer de ma dernière réalisation, dans ce domaine, ici : https://www.robot-ma...impeur/?p=95454
